10-31-2009, 08:58 PM
#641
Supporting Member
Re: 2 SASes 1 garage... Summer 2009
Got the longtubes on the 04 and the shorties back on the 99 today. I realized how much I like the bodylift today. It was a royal pain in the ars to get those longtubes stuffed up in a stock truck, but after about 4 sqaure inches of skin (off my knuckles, hands,and forarms), removing the front driveshaft, cutting off the EGR stem (not needed, so instead of putting on a block-off plate, I just chopped it and welded a patch over the hole), and breaking off a sparkplug (just the ceramic head), I finally got them in. There is just a piece of flex in place of the cats until I run it to the exhaust shop.
UNDER CONSTRUCTION click here 99 GMC RCLB ~19" Dana 60 & 14FF Detroit 5.38s GM HotCam Tom Woods Driveshafts PSC Steering Mazzi 20x12s Bilstein 7100s 36 MTZs(44" Pitbulls soon)
04 GMC Z71 ECSB
11-03-2009, 10:50 PM
#642
Supporting Member
Got the exhaust all done now. Its a bit deeper, but quieter now than what it was before. Instead of having long tubes with 3" pipes and stock cats(2 1/2"), it was shortys that run 2 1/2" from the collector to the 3" magnaflow high flow cats.
So I got home from work today and scabbed up some mudflaps. I haven't finalized my hitch yet, so the mudflap brackets aren't quit done either. I put some very decent tack welds on everything throughout, that I will cut off when I finish everything up. Just got done with that when the fedex guy showed up with these (Bilstein 7100s):
Threw them all on:
And now it rides a little smoother. I have about 700 lbs in the bed to help break in the rear springs, but the front will just have to do with the engine weight and driving it. I should be able to get some more/better pics tomorrow in the daylight.
04 GMC Z71 ECSB
11-04-2009, 07:11 PM
#643
Supporting Member
04 GMC Z71 ECSB
11-04-2009, 07:15 PM
#644
Supporting Member
 nice to see a build come to fruition after watching it for awhile
06 Trailblazer SS Cam 224/230 .610/.605 116LSA , PRC Gold Dual Valve Springs, TSP 7.4 Pushrods Ieatsrt8 V2 Intake, Magnaflow, Pcm4Less Trans Cooler, Circle D Converter, Built Transmission: Transgo HD2, Vette Servo, Z pack (upgraded clutches), Wider red band. Built and Tuned by RPM Motorsports
11-04-2009, 07:17 PM
#645
has been "had"
wow, that's one big SOB.
looks great though!
 - i'm new
 <-thanks again, xZoomerZx
96' burb - 6-inch RC, 4.56's, 35's, detroit, SYE, realift, flow 50's, w4m, 06' 17's, other stuff
98' silvy - z71, 285's, flow 50's, 1" block, some crank, blackbear
11-04-2009, 07:18 PM
#646
FSC BOT
Wow that thing is too low
Dubbed FSC BOT by: WildChevys
11-04-2009, 07:21 PM
#647
Supporting Member
Thanks guys. I am still going to build the "false" drop bumpers (or whatever you wanna call them), trac bars, and still have to get rear shocks. Then, get the 44" Pitbulls...
04 GMC Z71 ECSB
11-04-2009, 07:37 PM
#648
is the front able shaft centered in the wheel well right? It looks like it's pushed forward
1998 k1500/5.7/3.73/Mickey Thompson MTZ/Moto Metal 951/14b sf/Wheatley tune
1967 International 1500B/16,000 GVW/hydraulic bed/1 owner
#649
is the front axle shaft centered in the wheel well right? It looks like it's pushed forward
11-04-2009, 07:55 PM
#650
Pretty sweet. How does it drive and hows the power?
My new Truck
1994 K1500: K&N Drop In Filter, Dual Flow Master 40's. Rebuilt and Beefed up 4L60-e, New Alpine Deck, Alpine 6X9's Type S in the back. All pin stripping and Bumper Guards removed.
11-04-2009, 09:33 PM
#651
02GMCtruck
Location: Albion, Wa: from Pullman, Wa: from Edgewood, Wa
Wow you've made a ton of progress, lookin good. One of these days I'll have to track you down and see it in person.
Where are you planning on taking it with all the trees around here?
Last 3 Stepsides
79 Chevy C10, RCSS/5.0L/TH350/10, 86k. 4/6 drop.
88 GMC K1500, RCSS/5.7L/700R4/NP241/D44/14SF G80, 176k. 9" SAS w/ 35s
02 GMC K1500, RCSS/4.8L/4L60E/NP261/IFS/10, 20k. Sierra HT package: 1 of 234 Trucks.
11-04-2009, 09:52 PM
#652
RAMZ TRK
I can't wait to see some big rubber on that beast.
2004 GMC Seirra ECSB 4X4 5.3 AUTO
Originally Posted by someotherguy
It's always easier to ask forgiveness, than ask permission!
Richard
11-04-2009, 10:17 PM
#653
Got Hummer?
BIG! And only on 36s at that! The pic with the dog underneath cracks me up...what are you going to use to drain your engine oil into now? LOL
11-04-2009, 10:20 PM
#654
FSC BOT
a bar stool and a regular oil pan
11-04-2009, 10:47 PM
#655
Word!
My new Truck
11-04-2009, 10:48 PM
#656
Whore Whisperer
you should build sliders with snap-on canvas flaps and camp under the truck. that would be so badass.
2006 3/4 Suburban 8.1/4l80 with mods beyond mods...
11-04-2009, 11:10 PM
#657
Supporting Member
It's pushed forward about an inch. When the springs flex, the shackle swings rearward... can run a larger tire without eating the cab corner/ fender up
Its a little rough without rear shocks and all new springs, but pretty good. I passed a semi on the way to work... seat height is the same. With 5.38s and 36s, plenty of power.
Thanks. I've got a pass to 90,000 acres of privately owned forests used for logging. Lots to get into, along with great hunting. Got my first black tail 2 weeks ago, have seen many elk, saw 1 black bear but no shot, and getting ready to start slaying the bobcats.
It really nice to work under the truck, as compared to a stock truck. Under the hood sucks a bit. I'm 6'1" and I cannot reach the hood (when open and without jumping) from the front of the truck. There is definiatly no crawling under it needed.
04 GMC Z71 ECSB
11-04-2009, 11:24 PM
#658
That's an amazing lookin truck man.
♠ Dumped Magnaflow ♠ Rough Country 3" ♠ 33 x 12.50 Cooper STT's ♠ Blackbear ♠ K&N ♠ Keystone Hood ♠ Carriage Works Grille ♠ Painted Handles ♠ 6000K HID's ♠ 35% Tint ♠ 17x9 XD Hoss's ♠ Bedrug ♠ Smoked Tails ♠
11-05-2009, 08:09 AM
#659
Out of curiosity, what happens if you need to drop your transmission/transfercase? How exactly do you do that with a truck that big?  I'm being serious though, I'm really curious how people with huge trucks do that without killing themselves
Great looking truck man. I bet you are happy as hell to finally be able to drive it
--Bryan
1997 Chevy K1500 - 6" Trailmaster, 33's, 14b SF, 4" ORD Shackle Flip
11-05-2009, 08:33 AM
#660
Whore Whisperer
roll the work bench underneath it and go to town!
| Thread Tools |
| Display Modes |
Linear Mode
