Old 08-27-2009, 08:18 PM   #21
3.90+Locker up next
95tahoe95's Avatar
Re: '92 K2500 Suburban Refurb...
Where did you order the outer window seal from? I need all 4 and the one you got fits nice, Thanks!
Thanks xZoomerZx
95tahoe95 is offline
Old 08-27-2009, 09:09 PM   #22
markhuntsville's Avatar
Got them from LMC Truck;
http://www.lmctruck.com/
They are not quite as nice as the factory ones, but they doo look MUCH better and will work fine for us.
They do not use 'metal' clips - they have a plastic molded clip that catches a lip on the inner door area.
I'll get some pics this weekend when we replace the other 3 doors and post up.
'Mater
1992 Suburban K2500
5.7L L98 TBI - wheeze, but gettin better..
(L98 from IROC Z28)
4L80E
FF 14B
4.10 gears
Gov Locker
NBS HD Aluminum Wheels
Goodyear Duratracs
markhuntsville is offline
Old 08-27-2009, 09:46 PM   #23
3.90+Locker up next
95tahoe95's Avatar
Cool, thanks
Thanks xZoomerZx
Old 08-28-2009, 11:13 AM   #24
more goodies!
ROCK_KRAWLER is offline
Old 08-28-2009, 11:23 AM   #25
has been "had"
bhookxen's Avatar
Originally Posted by ROCK_KRAWLER View Post
its getting there... been alot of work but it will be worth it in the long run!
the jeep it will be towing...
sometimes i miss my old xj. they're fun to beat on!
- i'm new
<-thanks again, xZoomerZx
96' burb - 6-inch RC, 4.56's, 35's, detroit, SYE, realift, flow 50's, w4m, 06' 17's, other stuff
98' silvy - z71, 285's, flow 50's, 1" block, some crank, blackbear
bhookxen is offline
Old 08-28-2009, 11:25 AM   #26
3.90+Locker up next
95tahoe95's Avatar
more goodies!
3in/2.5 out? and Magnaflow FTW!
Thanks xZoomerZx
Old 08-28-2009, 03:15 PM   #27
Supporting Member
94383Z71's Avatar
Looks good man, props on saving an obs Burban
Parts, Dmax Rebuild
94383Z71 is offline
Old 08-29-2009, 07:33 PM   #28
Got around to installing other 3 outer window wiper seals -
Removing the rears was an experiment - I finally just bent them up and basically ripped them loose...not the easiest thing to do..
Here's a pic of the first one I removed - you can see the metal clips;
Here's the new one beside the old one - note the new one just has a molded plastic area that 'catches' to hold it to the door;
After;
Of course by the fourth one, I finally figured out how to remove them much easier - using a strong scraper from Lowe's, push it up under the outer lip and once it bottoms out, pop it once good and the wiper will easily snap out;
Getting the front to slide in behind the mirror was a PITA - but with care, and some spray lube, it finally went in place.
Here's a pic of the drivers door after romving all the glue and getting the new vent visor installed;
Front door put back together, hopefully for a long time;
Rear drivers side after the new outer wiper;
And lastely, but not least, I finally got a set of late model Chevy aluminum wheels, will get them put on next week;
Here's a closeup of the Goodyear Duratrac tread that I purchased;
We've just about got the interior put back together.
I noticed a couple of antifreeze puddles this morning, so I went ahead and bought a new radiator to install tomorrow. The PO had epoxyed the filler neck and I guess it worked for a while..
'Mater
1992 Suburban K2500
(L98 from IROC Z28)
4L80E
FF 14B
4.10 gears
Gov Locker
Goodyear Duratracs
Old 08-29-2009, 07:38 PM   #29
BHB
Motivational Speaker
BHB's Avatar
Psst...(you're supposed to remove the mirror)
looking good though.
Originally Posted by Big Angry
Hey ****face, (yes I am violating the rules and flaming you, whaah)
Originally Posted by CKTA View Post
No, I'm just dumb.
BHB is offline
Old 08-29-2009, 07:40 PM   #30
Yep - single 3" inlet, dual 2.5" outlets, it's the 22" long one - we're going to 'modify' the cat, so I wanted a free-flowing muffler, but not obnoxious.. we'll run dual 2.5"s out to the rear, where I ordered a couple of stainless angle-cut rolled lip 3.5" tips. Plan is to run them straight out the rear on each side of the hitch frame. Pics to follow...
Here's the link to the tips;
http://www.summitracing.com/parts/SU...3/?image=large
'Mater
1992 Suburban K2500
(L98 from IROC Z28)
4L80E
FF 14B
4.10 gears
Gov Locker
Goodyear Duratracs
Old 08-29-2009, 07:47 PM   #31
Yeah - I know, but I didn't want to remove the door panel on that door at this time... so I figured out how to get it in behind the mirror with a little finesse....so it 'can' be done.
Thanks for the compliment - it's come a LONG way since we drove it home...
'Mater
1992 Suburban K2500
(L98 from IROC Z28)
4L80E
FF 14B
4.10 gears
Gov Locker
Goodyear Duratracs
Old 08-29-2009, 08:15 PM   #32
Hope that magnaflow isnt to quiet lol. Cool build!
My new Truck
1994 K1500: K&N Drop In Filter, Dual Flow Master 40's. Rebuilt and Beefed up 4L60-e, New Alpine Deck, Alpine 6X9's Type S in the back. All pin stripping and Bumper Guards removed.
Gopedxr is offline
Old 08-30-2009, 12:48 AM   #33
3.90+Locker up next
95tahoe95's Avatar
NICE, hope you like noise cause thats my exact setup and its Really loud!
Thanks xZoomerZx
Old 08-30-2009, 08:56 AM   #34
Hmmm... thanks for the input - if it ends up being too loud, then I'll get a new cat and install it to help quieten it down some... we'll just have to see.
BTW - love the look of your Tahoe.
'Mater
1992 Suburban K2500
(L98 from IROC Z28)
4L80E
FF 14B
4.10 gears
Gov Locker
Goodyear Duratracs
Old 08-30-2009, 12:40 PM   #35
3.90+Locker up next
95tahoe95's Avatar
Thanks, BTW having the cat out is a noticable power difference, if anything you can put another muffler in place of the cat so you keep your flow but quiet it down mor
Thanks xZoomerZx
Old 08-31-2009, 01:40 PM   #36
Re: '92 K2500 Suburban Refurb... Wheel ISSUE!
Well *&*(&(*^@!!!
I took the late model Aluminum wheels and tire to my tire shop and they won't fit over the OBS hubs!
So now, I've got to get them machined! Anyone else run into this? Is the tire shop crazy??
The wheels are from a ~2004 2500HD and I'm trying to put them on our '92 K2500 Suburban... I'm REALLY suprised the hub diameter got smaller in later years...
Is there a website that details the hub diameters?
'Mater
1992 Suburban K2500
(L98 from IROC Z28)
4L80E
FF 14B
4.10 gears
Gov Locker
Goodyear Duratracs
Old 08-31-2009, 01:55 PM   #37
90Accord's Avatar
heres a cheap bumper http://www.stylintrucks.com/part.asp...&partid=480547
Hated by Most - Feared by None
90Accord is offline
Old 08-31-2009, 04:18 PM   #38
Originally Posted by 90Accord View Post
Thanks - I found several bumpers on ebay cheaper than these guys - but I really want an OEM bumper.
I used an after-market chrome smoothie bumper on our old '94 Z71 K1500 and I really wasn't happy with the quality... although, I may resort to this since good OEM bumpers seem to be rather rare... I did find an OEM on ebay for $129, but the phot quality was terrible, so I couldn't tell how the chrome plating was - AND the vendor couldn't get me any better pics
'Mater
1992 Suburban K2500
(L98 from IROC Z28)
4L80E
FF 14B
4.10 gears
Gov Locker
Goodyear Duratracs
Old 08-31-2009, 04:43 PM   #39
Supporting Member
94383Z71's Avatar
well, depends on if you want a smoothie or what. I have one with one or two dents, but it's sandblasted and primered, cause I was going to smooth it myself
so, if you wanted to get smoothies colormatched or something, and have a shop that could do the bodywork, pm me, I can finish all the weldin
Parts, Dmax Rebuild
94383Z71 is offline
Old 08-31-2009, 08:00 PM   #40
has been "had"
bhookxen's Avatar
Well *&*(&(*^@!!!
I use this one quite a bit. and it gives you matching vehicles.
http://www.roadkillcustoms.com/hot-r...RBAN+K2500+4WD
- i'm new
bhookxen is offline
