Old 04-24-2004, 12:20 AM   #1
bagged on 22's
ur2hi's Avatar
engine driven ?'s
do i need the york flange fittings or can i use regular fittings for the compressor? also, onboardair has air line that can handle 300 psi and 200 degrees. would this be ok to use from the compressor to the tank? thanks
ur2hi is offline
Old 04-24-2004, 11:08 AM   #2
Wuuuazuuup!!!
Kruznlow69's Avatar
need to know exactly which compressor you have, all depends on the head type...
also for your line, i'd still run a 36" 1/2"npt S.S. leader hose, that ebay one i found back in the old thread was only $30, plus you need a oil/water filter, blowoff valve, and pressure switch near the compressor.. lotta vibration and heat from that york...
let me know which model # york you got and i can look the head type up..
REBUILD THREAD Wreck Thread My StreetSource
"Lifes all bout making mistakes, It's how you learn from them that counts"
Kruznlow69 is offline
Old 04-25-2004, 12:27 PM   #3
bagged on 22's
ur2hi's Avatar
im getting the york 210. i know what parts i need, i've been researching engine drivens for about a year. finally have the $$$ to get one and i never looked into what fittings i needed for the compressor. maybe ill go buy the compressor today and see if my fittings will work. im not gonna run a blowoff valve just a check valve. thanks for the help
ur2hi is offline
Old 04-25-2004, 12:47 PM   #4
right now im not useing a blow off valve, and i've been useing it without it for 2-3months now
but im looking around for about a 250psi, because its a good idea to have one because the york will pump and pump into it blows itself up,
also just in case ur relay goes out on u and the pump could stay on
im looking around for a 250psi blow off valve because i run 200psi daily
u don't wanna blow the york up or one of ur tanks and then be screwed on the side of the road
2k gmc, sold!
08 t/c van, one audiomobile mass 12
84 austin mini, right hand drive,
one audiomobile mass 12, amp????
looking for a mtx 8100d or 1000d style amp
joakwin is offline
Old 04-26-2004, 12:47 AM   #5
bagged on 22's
ur2hi's Avatar
do you guys think this would work? the only thing i wonder about is the temp rating of 200.
http://www.grainger.com/Grainger/pro...697829&ccitem=
ur2hi is offline
Old 04-26-2004, 11:08 PM   #6
bagged on 22's
ur2hi's Avatar
would this be ok for an engine driven? someone please help me
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2547583815
ur2hi is offline
Old 04-27-2004, 07:08 AM   #7
Wuuuazuuup!!!
Kruznlow69's Avatar
yup yup, thats the one i found b4..... cheap for stainless!! only problem is no swivels so think ahead when screwing in the lines and connectors, water/air/oil filter, york fittings, BOV, and check valve
Old 04-27-2004, 09:42 AM   #8
I can get high pressure adjustable blow off valves. I even have one in stock.
Air Lift's braided stainless leader hose also doesn't have swivel ends, and it is a pain to get it in with everything being just right. I would highly recommend getting something that swivels. At least on one end.
Larry
www.innovativeairsuspension.com
Dealer for Air Ride Tech, KP Components, Slam Spec, Firestone, SMC, and Viair.
IRSd_mini is offline
Old 04-27-2004, 11:34 AM   #9
Know-It-All
BigChevMan's Avatar
I got mine from hoseandfittings.com it swivels on both ends...so I guess I'l just cool like that.
I ordered my blow off valve from mcmaster carr. It's adjustable between 150-200 psi. If I ever do my bags I'll be running it at 175...or so my pressure switch says.
Never argue with idiots, they drag you down to there level, then beat you with experience
BigChevMan is offline
Old 04-28-2004, 10:36 PM   #10
bagged on 22's
ur2hi's Avatar
would this be ok for an air/oil filter?
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
ur2hi is offline
