Old 02-06-2007, 04:50 PM   #181
sLOWrado01
ah nuts..I mean..ah nuts
sLOWrado01's Avatar
Member ID: 63087
Ive seen some mention of belltechs spindles in here and im goin to put in my 2 cents and ask for some help. heres the advice...DONT buy them! They are overpriced, very difficult to install (flip UCA's, balljoints, and we had to shave em alot to get em on OEM 17's) They do end up being about a 3" drop with flippin everything, great, but now i scrape more than i'd planned (i have them with 2" drop springs too). Also, when you turn the wheels to full lock either direction, they pinch or stretch the brake line too far (havent got it n the air to look yet but i think its wuts happening) so you lose braking power momentarily, then its like you have to bleed the brakes to get em goin again. Ive also heard from other places that the calipers hit the CA's but i couldnt imagine it. Also, my turning radius decreased alot more than i expected. They are just a hassle, and the thing is...belltech is aware of it all! I still have them on and im lookin for alternatives. Heres the question: Can i somehow fix this problem any way other than buying some Mcgaughys? Ill prolly get some longer steel braided brake lines to fix that part, but does anyone know anything about all of the other problems? had the same problems? let me know! Thanks.
Old 02-10-2007, 01:27 AM   #182
ChrisB
Just a n00b.
Member ID: 56659
Ok..I was looking at possibly just doing a 2/4 drop on my truck..Money is one reason, and it is my daily driver and I really don't want to get carried away, just want to close that wheel gap.
Whats the easiest way to do a 2/4?
Also, I bought the truck of my dad, and back when he first got it, he put air ride airbags in the rear, not drop bags, but for extra support when we had our camper on the truck.
Can I leave the bags be, or do I need to ditch them?
Chris B.
2006 Black Honda CBR600RR
89 Hugger Orange Camaro RS 355, lopey, sprayed, and unreliable
98 Red 1500 2WD Vortec 5.0 3" Catback/3.73s/2" shackles/18" Halos/Billet Grille
Old 03-01-2007, 11:12 AM   #183
thecodeman
the Waco kid
Member ID: 1522
Do spindles in the front and 4" leafs in the back. Don't mess with the hangers they are a complete PITA to get off.
You can probably leave the bags, but after you drop it just check the clearance and functionality of them. If something doesnt work right, you can either modify or toss them.
2003 Avalanche 2500
2002 Tahoe
1996 Silverado
Old 05-15-2007, 10:12 PM   #184
Acme Racer
Acme Racer's Avatar
Member ID: 68709
Question Re: My advice on lowering your truck static.
Hi Gang
I'm a newbie to the forums. I have a 94 C1500 2WD Suburban that I'd like to drop at least 3 in the front and level the rear to the front. I know I'll need spindles, but how can I level it in the back, maybe (hopefully) with just leafs? I dont really wanna cut the frame. I have found alot of info here in this thread, but not much pertaining to my 'burb. One main thin is keeping the cost "reasonable/sane". Any and all advice will be greatly appreciated. Thanks!
Best Regards from Daytona Beach
Larry
Old 05-19-2007, 11:10 PM   #185
fetuss10
Member ID: 68253
whats the trick to get the shackles to go on they seem narrower than my leafs
Old 05-19-2007, 11:19 PM   #186
fetuss10
Member ID: 68253
oh btw im doing a 5'7 drop on a 98 silverad ext cab... 2inch spindles 3inch springs flipkit all belltech.... if i dont put the shackles on will the flip kit just bring me down 4-5 in the back?
Old 05-20-2007, 02:33 AM   #187
drpdshrty
TurtlePusher
drpdshrty's Avatar
Member ID: 832
if you dont put the shackles on, it will be a 5/6. The shackles can add 1-2", depending on which hole you bolt them too.
Drew Huckins, Wichita, Kansas
1994 Chevy
5/8 Belltech
15x7, 15x10 Weld Split 6
Old 05-29-2007, 07:44 AM   #188
ccm
Member ID: 69100
Ok it is time to pass my 94 c1500 rclb on to my 16 year old son. I would like to put a drop on it before he gets it. Does the fact it is a long bed change any of the drops, also it is a 6cyl will that change any of the drops? The truck itself is in nice condition. One owner under 95k, I was thinking 4/6 is there a particular wheel size I should go with(17,18,or 20)? As I asked before does the 6 change the amount of the drop up front due to weight? If I do go with a bigger drop is there anything else that needs to be done up front? Thanks for any input.
Old 05-29-2007, 03:35 PM   #189
drpdshrty
TurtlePusher
drpdshrty's Avatar
Member ID: 832
i went with a 5/6 drop instead of a 4/6 because of the fact that i have a V6. Im really glad i did. It looks really nice that low in the front. Only thing you scrape on is the air dam, but thats easliy replaceable.
1994 Chevy
5/8 Belltech
Old 05-31-2007, 08:07 AM   #190
ccm
Member ID: 69100
So with the 5" drop up front did you need to change/modify anything else? Did use just use springs and spindles?
Old 05-31-2007, 05:05 PM   #191
drpdshrty
TurtlePusher
drpdshrty's Avatar
Member ID: 832
if you plan on running 15" wheels with drop spindles, you will have to cut about 4" off of the rain gutter on the lower control arms, or they will rub.
so just 2" spindles, 3" springs and a rear flipkit w/notch will give you a 5/6 drop.
1994 Chevy
5/8 Belltech
Old 06-04-2007, 07:52 AM   #192
ccm
Member ID: 69100
Ok, last question(I hope). When I lower it I need dropped shocks, I see the Belltech kits come with shocks. Question is what do shock extenders do? Are they so you can run stock shocks? Are they needed even with the dropped shocks?
Old 06-13-2007, 02:17 PM   #193
bradenn
bradenn's Avatar
Member ID: 69818
Hello, I've been reading this article along since page one and it got me enticed enough to post here what I plan on doing to my recently purchased 1989 Chevrolet Regular Cab Short Box with a 4.3L v6 and a 5speed manual.
I started off wanting to just do a simple drop, something like a 3/4... but then i realized that my truck sits pretty low at the front to begin with, so my brother suggested a 2/4 which I agreed with. I was about to order the parts today when I found this forum and saw pictures of member's actual trucks and the performed drop.
So I've held off from ordering the parts (which were chassis tech and recommended here that they were garbage) and have changed my mind and want a 4/6 drop.
Here's my truck, keep in mind I still have to put on my cab corners, new box, and front fenders, and all the rust will be gone.
http://www.fsckme.ca/wiki/index.php?...89_chevy_c1500
The package I've chosen is this one
http://www.stylinconcepts.com/part.a.../categoryid/30
Comments are welcome and criticism is encouraged.
thanks
braden
Old 06-30-2007, 06:28 AM   #194
doored90
formerly killer 10
doored90's Avatar
Member ID: 20730
lmao i have a 7.5inch drop in the front with spindles and cut springs and i have no problemsrides just fine to ill get sum pics up wen i have my rims on and repained its chiped to hell now and i jus put my roll pan on
Old 09-01-2007, 10:41 PM   #195
DroppedAsAChild
OBS Preservation Society
DroppedAsAChild's Avatar
Member ID: 51333
i currently have a 2/4 beltech drop on my 99 OBS gmc sierra i wanna bring it down to a 4/6 i already know what im gunna run with it i just need to get ahold of some stock shackles and hangers. My main questions i a running 255/45r20 yokos i was wondering will that fit up front with the 4 inch drop up front?? Oh and i am running 2 inch spindles and will be running 2 inch coils up front. and then the 6 inch flip in the rear. Also i am using nitro active drop shocks will i have to change those out for another set specifically for the 4/6?? Also do you guys reccomend cutting out all the inner fender lips?? Cause my fronts are rolled but they were done very Chitty. Also if i run 275/45r20's will they fit???
99 OBS Sierra Classic ECSB,4/6,20's,shaved,pan,and alot more *
UNDER CONSTRUCTION
http://www.cardomain.com/ride/2184611*
Old 09-04-2007, 04:08 PM   #196
DroppedAsAChild
Member ID: 51333
Bump
UNDER CONSTRUCTION
Old 09-09-2007, 11:39 AM   #197
bignick31985
Static Addict
bignick31985's Avatar
Member ID: 18371
With a 4" drop up front I ran 29" tall tires (255/70/15) for a long time, and had aboslutely ZERO issues with rubbing. Those 255/45/20's are literally the exact same height as my stockers were. Once I went to 5" I had some rubs, but not too bad honestly.
I'd believe they (255/45/20s) would work, as long as your offset/BS on your KMC's are good for tucking. The 275's I would think would work as well. They are 3/4" taller, but I know you should have that much clearance.
And I didnt cut my fenders out, just rolled them.
Old 09-10-2007, 11:54 AM   #198
Sup3rTun3r
Member ID: 74156
Good reading in here thanks!
Old 09-12-2007, 12:50 PM   #199
92 sierra slx
Hard times Kustoms
92 sierra slx's Avatar
Member ID: 69727
opinion on the 5/7 that avs offers is it fair priced and going to last???
http://avsontheweb.com/store/product...c3f4d4e586fbf9
ayden james woodbury
6-16-08 to 7-30-08
my son
Old 09-13-2007, 01:44 PM   #200
DroppedAsAChild
Member ID: 51333
Thanks alot Nick you got any updates on the truck ??
UNDER CONSTRUCTION
