Old 10-27-2007, 07:10 PM   #201
Hard times Kustoms
92 sierra slx's Avatar
[QUOTE=92 sierra slx]opinion on the 5/7 that avs offers is it fair priced and going to last???
http://avsontheweb.com/store/product...c3f4d4e586fbf9
bump???
ayden james woodbury
6-16-08 to 7-30-08
my son
92 sierra slx is offline
Old 12-03-2007, 10:49 PM   #202
lowballer's Avatar
good reading guys, thanks for all the help.
Rides:
2006 Yamaha R1 www.r1-forum.com
2004 Silverdao x-cab www.fullsizechevy.com
1999 19' Bayliner www.baylinerownersclub.org
1992 Honda prelude www.preludepower.com
www.preludezone.com
lowballer is offline
Old 12-04-2007, 12:58 AM   #203
the Waco kid
bump???
It's the same stuff everyone uses to drop their truck. Coils, spindles, and a flip kit. I'm sure you'll be fine seeing as its not from AIM.
2003 Avalanche 2500
2002 Tahoe
1996 Silverado
thecodeman is offline
Old 12-09-2007, 06:04 AM   #204
Just double checking.
On a 2 door 97 Yukon 2wd, isn't 5" the lowest you could drop a daily driver w/o notching the frame?
Thanx in advance.
stricninemonkey is offline
Old 12-13-2007, 12:25 PM   #205
hey how did you lower your front?
justin_brown is offline
Old 12-13-2007, 12:40 PM   #206
camp
badkelly's Avatar
haven't looked at this thread in a long time and figured i'd chime in.
i have 2" djm spindles and 2" hotchkis coils with another inch cut out for a total of 5. back is leaves, shackles, and hangers and yes, the factory rivets are a pain to remove if you don't have the proper tools. wickedspeed motorsports did mine about 5 years back and i have had zero problems. i still have the factory air dam, though it's in rough shape (see here: air dam thread)
overall, it's a rougher ride (because i'm also set up for performance), but it corners better than any car i've had. it creaks when i take a steep incline diagonally, but i usually try to watch out for them in general so it's not an issue.
Matt. 7:13 If it ain't broke, don't fix it. Oooops....Hey, I just broke it!
... the suburban build thread!
badkelly is offline
Old 12-13-2007, 10:32 PM   #207
I have not done anything yet, I was just wondering before I picked out parts.
Turns out I can't go that low w/o cutting out room for the driveshaft too. So I'm just going to go 2/4 so I don't have to cut up the truck.
Old 12-14-2007, 11:06 PM   #208
2bad$doesn't growon trees
96thebossgrnchv's Avatar
i'm running djm 2" drop spindles,
-2" djm drop coils,
-6" djm flipkit,
-2" belltech drop shackles,
-running a 265/35/22 tire on a 4/7 drop,
-trimmed my lca's to use my stock 15's,
-trimmed my front fenderlips,
-trimmed a section off of the center brace under the bed right on top of the differential,
-my wheels are 22x9.5 with 6" of backspacing,
-thats +40 offset and they tuck perfectly,
-raised my y-pipe also, great daily driver!
latruckscene.net
96 2dr 2wd tahoe
96thebossgrnchv is offline
Old 12-16-2007, 03:11 PM   #209
oh, you didn't know ?
blkshadow's Avatar
have you guys had any issues with pinion angle? i get vibrations and harmonics from my driveshaft angle at certain speeds. i have tried 4 different pinion angle wedges and can't get a happy medium, it either vibrates or i get the weird harmonics. driving me crazy. i am about to put the front back stock and 2" shackles out back and be done with it. hate to do that because i love the way it looks but enough is enough! jd
06 RCSB LT1 5.3l, 2wd
20" Malanni Bitchin wheels, 275/45/20 Falken tires, Gaylords bedcover
signature by: 91chevZ71
blkshadow is offline
Old 12-16-2007, 03:12 PM   #210
S B0MB
xx_ED_xx's Avatar
Have you checked the u joints? mine doesnt do that at all and i didnt do sheet to the pinion angle
xx_ED_xx is offline
Old 12-18-2007, 02:15 PM   #211
blkshadow's Avatar
yep! no play at all. jd
Old 12-19-2007, 05:51 AM   #212
House on the HILL!
CKTA's Avatar
Have your driveshaft checked.
2010 Carlisle All Truck Nats info..
http://www.fullsizechevy.com/forums/...aug-6-8th.html
CKTA is offline
Old 12-19-2007, 08:16 PM   #213
blkshadow's Avatar
thing is when i put the different wedges in it changes my symptoms. one wedge it will have no noise but will vibrate at certain speeds, put another one in and no vibration but harmonics when i let off the gas. if it were the u-joints or driveshaft it wouldn't change like that. jd
Old 12-23-2007, 02:28 PM   #214
86sunsetchevy's Avatar
i want to lower my truck but dont know how muck to lower it. its sitting on 22s
86sunsetchevy is offline
Old 12-23-2007, 04:11 PM   #215
lowballer's Avatar
Holy crap man, don't include to much information.
Rides:
www.preludezone.com
Old 12-23-2007, 04:17 PM   #216
get some 265/35/22 tires (if you don't already), assuming that they tuck,
front: 2" drop spindles, 2" drop coils (djm)
rear: 6" flipkit (djm)
call edelbrock and tell them you've lowered you truck 4/6 and they'll set you up with the right shocks
lmao
latruckscene.net
96 2dr 2wd tahoe
Old 12-23-2007, 05:24 PM   #217
blkshadow's Avatar
well i took off my hangers , spindles , coils and shocks and put the stock stuff back on and i have no vibrations and no harmonics. yes the truck doesn't look as good sitting basically stock except for 2" shackles and a set of 20" wheels and tires but until i wear out these tires i guess it will have to do. if i lower it after i wear out the tires i'll use leaf springs or a flip kit, no more hangers. pita to put on and take off. by taking off the hangers it raised the rear 3". i thought the hangers were 2" and the shackles 2" more. jd
Old 12-23-2007, 05:29 PM   #218
not sure about the hangers but yeah i would go with a flip kit when you lower it again
latruckscene.net
96 2dr 2wd tahoe
Old 01-01-2008, 11:04 PM   #219
omex18's Avatar
How Can I Lower The Front End Of My 94 Sierra???
omex18 is offline
Old 01-02-2008, 01:00 AM   #220
lowballer's Avatar
Read this and the other posts on lowering your truck then magically it will lower itself.
Rides:
www.preludezone.com
