Old 01-02-2008, 02:12 AM   #221
tpichevy's Avatar
hes a newbe, cut him some slack haha
use the search mode in the site it does wonders!
-TireFryr-v8TPI-212-218,110-1.52rollers-Fully Ported aftermarket TPI setup,52mm TB,Coated LTs,Built 700r4,2800Yenk stall,Hurst v-matic2,3.73posi "TractionLess"GoleET:13s Best 14.6-93mph 1.87-60' YenkoST is my Tunner!!
tpichevy is offline
Old 01-10-2008, 02:04 PM   #222
Hard times Kustoms
92 sierra slx's Avatar
a 5/8 i should only have to cut to bolt in the notch right and maybe trime stock arms
i plan on using djm componets
spindals,springs,shackles,and a flip kit
ayden james woodbury
6-16-08 to 7-30-08
my son
92 sierra slx is offline
Old 01-11-2008, 07:34 PM   #223
TurtlePusher
drpdshrty's Avatar
regular bolt in notch wont be deep enough. you will need super C notch. You also will need to trip your bed support over your differential.
Drew Huckins, Wichita, Kansas
1994 Chevy
5/8 Belltech
15x7, 15x10 Weld Split 6
drpdshrty is offline
Old 01-12-2008, 12:01 PM   #224
Hard times Kustoms
yeah i knew about trimming above diff but forgot to add it and i dont want to cut up my bed nor do i have the extra scrtach to get a super c maybe in the summer or next winter but ill make due with bolt in for a while
6-16-08 to 7-30-08
my son
Old 01-12-2008, 05:44 PM   #225
TurtlePusher
drpdshrty's Avatar
you could invest in a set of helper bags for the time being
1994 Chevy
5/8 Belltech
Old 01-13-2008, 10:16 AM   #226
Lots of info here. My question....I got a 89 gmc sierra sle swb and want to do a 3/4 drop, can I do it with springs & shocks, then what about alignemnt or frontend adjustments? Who makes a good kit? Depending on costs I would like to see what spindles and spring would cost also. I have a 70 chevy with 2/4 drop and no problems, the newer trucks I don't know much about yet. Thanks.
nevada89gmc is offline
Old 01-13-2008, 06:49 PM   #227
tpichevy's Avatar
im runnin 5/8 with 26" tall tires and i have never had any problems with the bolt in notch....you will be just fine!!
tpichevy is offline
Old 01-13-2008, 06:51 PM   #228
tpichevy's Avatar
yes they make a 3" drop spring for our trucks...hangers and shakles in the rear!
tpichevy is offline
Old 01-13-2008, 08:06 PM   #229
Hard times Kustoms
if i do the 5/8 will i rub or anything on a 275/65/15
6-16-08 to 7-30-08
my son
Old 01-14-2008, 08:51 AM   #230
i have a 2000 sierra long bed want to do a 4/6 and do 20x8.5 in front 20x10 in rear. Is it better to do spindles o lower control arms? Also daily driver
jphub is offline
Old 01-14-2008, 07:31 PM   #231
Hard times Kustoms
spindles are better and cheaper cause with arms you have to realign spindles you do not
6-16-08 to 7-30-08
my son
Old 01-15-2008, 08:47 AM   #232
Thank. Belltech or DJM?
jphub is offline
Old 01-15-2008, 08:50 AM   #233
House on the HILL!
CKTA's Avatar
110% wrong. You need an allignment ANY time you touch the front suspension...PERIOD.
2010 Carlisle All Truck Nats info..
http://www.fullsizechevy.com/forums/...aug-6-8th.html
CKTA is offline
Old 01-15-2008, 08:52 AM   #234
Yea i knew i would just trying to figure out best way. Most kits show arms instead of spindle for my truck.
jphub is offline
Old 01-15-2008, 08:54 PM   #235
Hard times Kustoms
im getting djm stuff but both are good beltech just a little more pricey
6-16-08 to 7-30-08
my son
Old 01-15-2008, 09:55 PM   #236
the Waco kid
Correct. And drop coils in conjunction with drop arms will really F up your front suspension
2003 Avalanche 2500
2002 Tahoe
1996 Silverado
thecodeman is offline
Old 01-22-2008, 09:50 PM   #237
So who makes a good 3/4 drop kit? Also should I go with the shocks that is packaged in the kit? Or is there different recommendations for type of ride, useage etc.? What is the travel difference between stock height shocks and ones for a 3/4 drop? Thanks again.
Old 01-23-2008, 01:59 AM   #238
tpichevy's Avatar
Who out there is runnin the QA1 shocks...how do they like them...what do you have them on? This would be about the best shock for tunnin in the ride and feel of how it rides. They cost alot but with the right parts your truck can handle like a slot car. Ive been thinkin about installin my shock-waves from ART with some ART 3/8" block valves and a tank out back under the bed, then run some QA1s out back to help fine tune ride performance and handling on the street and track.
The difference between stock shocks and drop shock are mostly travle and load/rebound specs.
tpichevy is offline
Old 01-24-2008, 09:43 AM   #239
RLC0503's Avatar
I've read this whole thread 3 times in the past month and I learn more and more everytime. Thank for all the knowledge and good info.
94 Yukon | Whipple Supercharger | Dual exhaust with x-over
*** ULTIMATE LIST OF ACRONYMS ***
RLC0503 is offline
Old 01-30-2008, 11:46 AM   #240
Hard times Kustoms
ok i just did a 3/6
djm springs
and flipkit
with bell tech nitro2 shocks upfront
rides great
it'll ride even better when i get the notch in back
i plan on going 5/8 in a few months with spindles and shackles
6-16-08 to 7-30-08
my son
