Old 09-23-2004, 09:31 AM   #41
20 Inches Strong
00'blackout's Avatar
Hey what's up guys...I'm new to the site but I have a 00' silverado shortbed, and I want to know if there are any places that sell the 2" hangers buy themselves b/c I already have the 2" shackles? And what should I do in the front? I want a low but very streetable stance.By the way the trucks look kick ass.
00'blackout is offline
Old 09-23-2004, 09:44 AM   #42
Administrator
454ss's Avatar
Check out http://www.stylinconcepts.com
click signature for pics
90 454ss
92 454ss
00 Silverado
08 Avalanche
I wish people were like slinkys, fun to play with but when I get bored I can push them down the stairs.
454ss is offline
Old 10-02-2004, 07:22 PM   #43
I have a 93 with a western chassis kit, flip in rear with homemade notch (super C style) front is 2" spindles, 2" eibach springs. I desire more drop especially in the front.
I am considering cutting the coil pocket out of the A arm and dropping it 1.5" by welding in a ring. Has anyone else tried this? Or should I go with a an arm kit. I really don't want to make the ride any worse than it already is by going with a shorter spring. does any one make a good kit to do this that gets the camber angles right? I would like to get close to 3" drop in the front and have a decent ride. I really dont wnt to do bags.
Anthony Consorte, Lithium Racing
1993 c 1500 cheyenne, 4/6 drop, 94lt1 and t56, 4.56 rear
old crappy pro street suzuki, lo 8 second streetbike.
NoBars is offline
Old 10-02-2004, 09:49 PM   #44
Beaner/Cracker
IMO you should just get a 3" coil. You could try and drop the coil pocket but you're more than likely gonna have alignment issues with the spindles and the drop pocket. Plus you may have issues with the pocket being lower than your lower rim edge which would violate scrub laws.
Izzy is offline
Old 11-15-2004, 11:32 PM   #45
technut
ok, im suspension challenged, so i am relying on some of you technuts.
ive got this 92 c1500 350 standard cab/short wheelbase and installed
PSJ 18x8 enkei with 255/55 tires. the front is lower than the front (the rake)
and already have the belltech shackles with factory rear springs.
now ive got this nose bleed stance with the truck. comming off the 295/50-15
the truck is too tall. before i installed the taller wheel/tires (29.5") i was looking
into a 2/4 drop. now possibly lower.
heres the needs:
daily driver
maintance free (dont wanna keep tweaking this forever)
hauls payload (1000lb max) occassionally
not looking for "laying frame stance"
pricing isnt major, but not looking for gold plated
not looking forward to bed surgery
air ride isnt out of the question
looking forward to suggestions, pictures are proudly accepted.
airdeano
2001 Silverado 4.8L 4-spd Automatic 3.42
? horsepower
? torque
will find out soon!
1965 C10 5.3L (SSR) TH4L60e
(It's Alive! 07/04 It Drives! 03/05 Daily Driver XX/08!)
airdeano is offline
Old 11-15-2004, 11:40 PM   #46
Xcentric Customs
Beyond Static©'s Avatar
if you want a semi-low stance, a 4/6 is your best bet. Some 2" spindles(djm or western chassis), 2" coil springs(belltech, djm, western chassis) and a flip kit for and c-notch for the back(djm, belltech, western chassis). Your tires seem to be pretty big. I'm not sure they would even tuck on a 4/6 if you hit a bump. Do you know the backspacing on the wheels? www.stylinconcepts.com has great service and pretty good prices. Start off looking there to piece a kit together.
Beyond Static© is offline
Old 11-15-2004, 11:55 PM   #47
technut
backspacing is 5"
you did mention companies for these items (thanks) isnt there a
way to grab it all up into a kit or is the kit form kindda lope-sided
with each component?
airdeano
? horsepower
? torque
will find out soon!
airdeano is offline
Old 11-16-2004, 03:49 AM   #48
the Waco kid
Airdeano,
A 4/6 is a nice "slammed" stance for most people and you can use some Air Lift helper bags like CKTA did on his 96 to keep the rear end level when you tow/haul stuff. Or, if youre looking to spend a little more money for lower, you can use 2" spindles, the Air Ride Technologies Cool Ride front bag kit , the KP parallel 4 link, an engine driven compressor like the Air Commander, 3/8" valves and line, and a couple 5 gallon tanks under the bed for storage. Since youre not concerned about laying you can get a notch from SuicideDoors.com and cut it down to fit under the bed, weld it in and then box the areas of the frame closest to the notch. You'll have a super strong, towable, reliable, easy to install bag setup that gets lower than most.
2003 Avalanche 2500
2002 Tahoe
1996 Silverado
thecodeman is offline
Old 11-16-2004, 06:49 AM   #49
House on the HILL!
CKTA's Avatar
Originally Posted by airdeano
backspacing is 5"
airdeano
Stylin' sells complete kits (with or with out shocks) from companies such as DJM, BEll Tech and Ground Force. It's actually best/cheaper to buy it in "kit" form.
2010 Carlisle All Truck Nats info..
http://www.fullsizechevy.com/forums/...aug-6-8th.html
CKTA is offline
Old 11-16-2004, 11:36 AM   #50
20 Inches Strong
stylin has this new thing called "Belltech 1-box kits" for some trucks, but for my 00 silverado i was looking at their other kits and the pricing for a 3/4 drop with shocks is 394.95, but the belltch 1-box kit, is priced at 489.00 for the same drop w/shocks....what's the diff? hass anyone else noticed, oh btw the ad is in the new Truckin' mag (dec. 2004) pg.26
Old 11-16-2004, 11:48 AM   #51
House on the HILL!
CKTA's Avatar
With-out seeing the ad......I'd say SHOCKS!
CKTA is offline
Old 11-16-2004, 11:51 AM   #52
Preferred Vendor
justin's Avatar
They both have shocks
EFI University's EFILive Course Instructor, Black Bear Performance
2003 Silverado SS. Radix. LS6 Cam || 2002 Trans Am WS6. Quasi-For Sale || 2008 Trailblazer SS
justin is offline
Old 11-16-2004, 11:53 AM   #53
House on the HILL!
CKTA's Avatar
Ohh......I misread that. Then they probably use different means of lowering then. One may use springs and one may use LCA's.
CKTA is offline
Old 11-16-2004, 11:55 AM   #54
20 Inches Strong
oh i see
Old 11-16-2004, 11:56 AM   #55
House on the HILL!
CKTA's Avatar
Have to see the ad to be sure tho.
CKTA is offline
Old 11-16-2004, 12:02 PM   #56
20 Inches Strong
i'll try and get a pic up, i just went to their website and they didn't even mention this mysterious "box"
Old 11-16-2004, 12:05 PM   #57
House on the HILL!
CKTA's Avatar
Are you sure the 394 was INLUDING shocks? And if so...was it for the same year model truck?
CKTA is offline
Old 11-16-2004, 12:05 PM   #58
the Waco kid
I think I know what youre talking about. Belltech offers the same drop but with different shocks. One uses the nitro drop shocks, the other uses the better "nitro active" shocks.
2003 Avalanche 2500
2002 Tahoe
1996 Silverado
Old 11-16-2004, 12:06 PM   #59
House on the HILL!
CKTA's Avatar
That makes sence.
CKTA is offline
Old 11-16-2004, 12:13 PM   #60
20 Inches Strong
yeah i see what yall are talking about hang on.....and i qoute "99 and up silverado/sierra...2/3 or 3/4 drop kits include coils,shackle kit/hanger kit, and nitro drop shocks...$394.95 kits also avail. with active shocks...Call!!!"
Next..."Simplify your drop with our Belltech 1-box kits
- No guess work
- No confusion
Complete 1-box kits include the matched parts you need to get the drop you desire-including shocks. 3/4 kit 99-03 chevy/gmc...........$489.00"
