#181 |
Chew On This
Member ID: 65587
Re: Advice on bagging a truck
Sounds like you have a pretty decent list going. One thing I may suggest on a fullsize, is going with at least 6 valves. That's 4 to fill, and 2 for purge. If you only run 4 valves total, you'll get side to side air transfer between the 'bags. Plus if you have more weight on one side of the truck (gas tank), your ride will have a crazy lean.
...Never falling victim to "The Norm"...
#182 | |
Member ID: 74349
Very good advice, Thanks. Any tips and trick concerning the install if I plan on doing it myself.
2002 silverado, caddilac front clip, just got it. looking to bag it next summer, meanwhile i'll try to get as much info as I can
#183 |
Chew On This
Member ID: 65587
No prob man. As far as any tips or tricks? Hmmm...Id probably run my valves directly off the tanks if I could? - To try and lessen the amount of wiring and airlines/fittings. The more breaks in the line, the higher the risk of an air-leak. Another tip is make sure to use all DOT lines and compression fittings. Aside from that stuff, just make sure the 'bags don't rub on anything, and just have fun with it.
#184 |
Hard times Kustoms
Member ID: 69727
opinions on setup im thinking of going with the
http://avsontheweb.com/store/product...416039df0e07ac ![]() http://avsontheweb.com/store/product...416039df0e07ac ![]() http://avsontheweb.com/store/product...416039df0e07ac ![]() http://avsontheweb.com/store/product...416039df0e07ac ![]() http://avsontheweb.com/store/product...416039df0e07ac ![]() ok did i forget any thing i should be able to lay frame with this set up right ??? as long as i notch for the tie rods??? ill be on stock 15's so it should lay frame with setup and are all these good parts and deals???
R.I.P son
ayden james woodbury 6-16-08-7-30-08 your time on earth was few and i'll be missing you RESIZE YOUR SIGNATURE BANNER TO 500x200 OR LESS |
#185 |
I DO BAD THINGS TO GOOD R
Member ID: 75450
Thank You Marcos For Those Pics
That Will Cut My Time Down By 1/8th |
#186 |
I Have 07 Silverado And I Want To Bagged It But Don't Know What I Have To Buy And I Want It To Lay Frame Or Close As It Can Be But Dont Want To Cut Up The Truck So If Someone Can Help Me And Give Me Info On What To Do And Want I Need To Buy Thanks
#187 | |
Member ID: 75843
I havent bagged a truck myself yet. but from the READING and SEARCHING i have done. i learnt that even a "bolt in" notch involves a bit of cutting of the frame. |
#188 |
dont mind cutting frame dont want to cut into the body of the truck and what system is good for my truck and how low will i sit to the ground if i get the under the bed notch
#189 |
Hi Im New To This Board And I Wanted To Know IF Yall Could School Me Out On What Type Of Airbag Setup I Need. I Have A 2007 Silverado Crew Cab On 26inch Rims With 2 12in Subs Under The Rear Seats. I Wanna Bag System Thatll Let Me Drop It To Tha Dirt At Will And Pick It Back Up With The Quickness! But What I Need To Know Is Is There A Setup I Can Get That'll Do That And Not Take Up My Entire Bed Because I Use My Bed Alot And I Know Those Tanks Usually Take Up Alot Of Space? Is There Maybe A Way I Can Have A Hidden Tank Or Something That'll Accomodate What Im Trying To Get Or No? Thanks Anyone Who Can Help Me In Advance!
#190 |
-box your tank under the bed the same with the compressers thhats what i did with no tubs youll still have the majority of all your bed space
#191 |
#192 |
Thanks For The 411 My Dude!!
#193 |
Blast from da past
Member ID: 78477
Okay, I think everyone should be well schooled on how to bag an 88'-98'chevy with 10 pages hahaha!!!So how about a 73'-87 chevy? Has anybody done one of these truck I just bought one and I need to get started, any help would be appreciated?
#194 |
Blast from da past
Member ID: 78477
Here are more pics fo my truck
#195 |
Chew On This
Member ID: 65587
For one, I am sickly jealous... Those trucks look absolutely sick layed out. I think I love it. Suicide doors dot com (SD)has a front cup kit specially for that truck that bolts right in. Mate those cups with some Slam RE-7 bags and a pair of 2" drop spindles, and your front will be in motion. As for the rear - It's a blank canvas. Anything's possible. It's just whether you want to go with an expensive bolt-on kit, or pick out your own link setup from SD (way cheaper and more original in my personal opinion). To get the rear suspension to lay out, you're probably gonna want a regular 8" or 10" step notch. For a link, I'd suggest a triangulated 4-link setup with some Slam RE-8 bags mounted on the lower bars... That's just an idea, you can do a ton of different things...I'm kinda lookin forward to seeing that square beast layin' some pinch-molding...lol.
#196 |
hey guys i have an 88 chevy 1500 with a 4 inch drop in the front and a 6 inch rear flip kit i am looking to bag but i don't know a whole alot about it i want them to fill and empty very quickly and i want to lay frame do u guys have any advice....thanks
josh |
#197 |
Chew On This
Member ID: 65587
As far as filling and emptying quickly, 1/2" air line, and either 1/2" or 3/8" valves should be pretty speedy. Of course, the more air you use, the faster your tank will drain, and the more your compressor will kick on. My advice - Get an engine driven compressor and a 12 gallon tank. That should make things fairly quick. As far as laying frame, you're gonna need at least an 8" step notch for the rear frame, and you'll need some sort of link-style suspension. Either bolt-on or weld-in. Look on suicide doors dot com, find stuff ya like, make a list maing.
#198 |
Baggin it Soon
Member ID: 83627
i was thinking of getting a whole kit from them avsontheweb.com, for around 2k, no sure if its a good kit or not though.
#199 | |
Member ID: 83595
#200 |
Member ID: 70253
Thanks for the info. Trying to decide on air bag suspension or a static 4/6 drop.
1990 Chevrolet RCSB (Future LS1 Project) 1996 Chevrolet Suburban. Nelson Tuned, CAI, Cat-Back Exhaust, 17" Impala SS Wheels 2004 Chevrolet Tahoe |
| Advertisements |
| Thread Tools | |
| Display Modes | |
