Old 10-25-2004, 07:26 AM   #41
Beaner/Cracker
Re: Advice on bagging a truck
Yes you can hit s2s on any 4 link.
I would check out the setups from suicidedoors.com and innovativeairsuspension.com
Copper lines are not the best to run because they can become brittle, they aren't made to be subjected to the elements. DOT line will be fine as long as it's not near anything too hot like your exhaust.
Izzy is offline
Old 10-25-2004, 12:21 PM   #42
So i need to cut new fenderwells for 22s in the back and completely cut out the front inners for 20s? Also is there a fittings kit that i can huy that has all the fittings i need for a whole bag job?
srosa707 is offline
Old 10-25-2004, 12:41 PM   #43
Mike's Avatar
Call Larry @ www.innovativeairsuspension.com and he can set you up with all the fittings you will need
Buy me
Mike is offline
Old 11-19-2004, 04:05 AM   #44
slammedchevy01's Avatar
So Suicidedoors and innovative are both reliable bag product dealers? I was checkin' em out, I knew Innovative was cool!
2k1 Silverado, ART/KP Air Commander
slammedchevy01 is offline
Old 12-03-2004, 09:47 AM   #45
Drive and Enjoy.
Low88's Avatar
yes, i just ordered about 1100 worth of stuff from jason at suicide doors, and he hooked me up for 975. he is a real nice guy and takes care of his customers. Only thing that jason doesnt sell is fittings.
Low88 is offline
Old 12-17-2004, 06:04 PM   #46
i ordered 1400.00 worth of bag parts, which included spindles triangulated 4 link all valves, slam bags, cups etc... all i have to do is weld it up and put it in and its ready to drag.
lowlyfecustoms is offline
Old 12-25-2004, 09:58 PM   #47
I'm new here but want to help out alittle. I've got a 92 Chev, I'm in the works of bagging. Here is all the hardwear, ART everything. 4link-airbar, with uca,lca, coolride kit and 2in drop spindels. And a RideproE 4way and a 5gal,tank, 450 compessor
From what I've seen on here, Make me think I'm going to need another 5gal tank and one more compessor. Because I don't want that compessor running all the time.
Any help on that would be cool.
I have not started on it yet, because I'm still painting it, "but soon". I would like to take pics of everything for everyone to see, Kind a step by step setup if ya know what I mean.
If anyone has some idea that I could show in a pics so people could get a good view of what where doing. Let me know. "Like grounding everything strait to the battery."
I heard the RideproE has some problems if it's not grounded right.
Hope to post pics soon of everything. Dropchop56
DropChop56 is offline
Old 12-25-2004, 10:39 PM   #48
Xcentric Customs
Beyond Static©'s Avatar
On the RideproE, for the ride height on start thing to work, your valves gotta be sooooo slow. It takes my dads truck 3 seconds to air up, and 4 seconds to air out. The system still acts funky. I'm running 8.5 gallons of air, on 175 psi. If you only run 145 psi, I recommend at least 10 gallons, and 2 or more compressors. I am running an engine driven, which fills the 8.5 gallons from 145-175 in under 30 seconds.
Beyond Static© is offline
Old 12-25-2004, 10:53 PM   #49
Thanks for the info. Hey on your step notche, how tall are they. The reason I'm asking is because I got a set of c-notches for ART and there not that tall. Is the reason your running bigger notches, to get lower. I want this truck to lay down all the way. Thanks DropChop56
Old 12-25-2004, 10:59 PM   #50
Xcentric Customs
If you're running the airbar, you wont lay frame unless you build new upper brackets, and a larger notch. My notch has 7.5" of travel, and lays the frame, and has about 3/4" to spare.
Old 12-25-2004, 11:23 PM   #51
with upper backets? The bar that run acossed the frame rails or the upper fourlink bars.
Old 12-25-2004, 11:59 PM   #52
Xcentric Customs
you will need to somehow raise the upper bar to lay the frame.
Old 12-26-2004, 12:05 AM   #53
Thanks! I will see what needs to be done. Peice of cake right. LOL
Old 12-26-2004, 12:12 AM   #54
Xcentric Customs
SIMPLE
Old 01-02-2005, 04:51 PM   #55
Originally Posted by Mike
I second the KP kit, very nice deal. I have firestones and they ride great.
I run shockwaves in the front and I love them. Ride great, and super easy to install. I can remove and replace them both in about 30 minutes. If you can remove your shock you can install these.
Are there any alignment issues with the shockwave setup?
motomack86 is offline
Old 01-24-2005, 09:11 PM   #56
Mike's Avatar
Not at all
Buy me
Mike is offline
Old 01-28-2005, 10:29 AM   #57
soon to be boosted
91blkstpsd's Avatar
I plan on baggin my 91 stepside and and work at a machine shop and was hoping to build most of my system. I was just wandering what would be the best ride and lowest without cutting into my bed, and if cups, 2" drop spindles, and 2500# bags would be good for the front. Any comments would help.
91blkstpsd is offline
Old 01-28-2005, 06:05 PM   #58
Xcentric Customs
You can build a super c-notch to fit under your bed, and come about 1.5" from layin frame on a 27" tall tire. Up front your setup sounds good, but run 2600lb bags. 2500's are for mini's.
Old 01-30-2005, 08:11 PM   #59
hey guys - Im about to bag my 00' tahoe (obs) 4 dr which I already have djm upper and lower control arms on - any body every put shockwaves with these control arm with any success?? Also - anybody every have any complaints about belltech nitro shocks being to harsh of a ride? I think my truck rides like crap - thus the reason im going to bag it. Also any thoughts on rear kits - I like the ART stuff - but like anybody else Im trying to keep from being put in the dog house with the wife when the parts arrive and she see's the bill?!?!
thanks for any comments - Jason
jb2000tahoe is offline
Old 01-31-2005, 12:07 PM   #60
wisesuperman's Avatar
I have a 2001 Sierra with 20's. I want to lay the frame, but I dont need it to be super fast. I am going to go with the KP 4 link with cantilever in the back, but my question is I have a Belltech 4/6 drop. Can I install bags with this, or will I need to remove it? My truck is about 2 inches from the ground now, so I dont think it will take much. The main reason I want to get bags is because I dont want to scrape everywhere with my new paint.
Thanks, Britt
Under Construction
2001 1500 Ext Cab
In the body shop getting 100% Shave and Kandy Paint
wisesuperman is offline
