#101 | |
Member ID: 39041
Re: Advice on bagging a truck
first of all DO NOT RUN A 2 LINK you will regret it they are garbage trust me i ran one for a week biggest mistake of my life i am now running a system i designed myself it's a tri 4 link and i'm running my bags on my lower bars and couldn't be happier i get no wheel hop the ride is great it's just harder to hop the back this way that's all here are some pics of my setup hope this helps and oh yeah for the love of god do not run a 2 link 2LINK = GARBAGE
The lower I go the more she likes it
i like my ride like my women clean shaven |
#102 |
Member ID: 35691
how much will a shop charge me to install a c-notch on my 74 c-10 short bed? im buying a kp 4 link for the rear and a coolride set up for the front but i dont feel comfortable taking out a chunk of my frame. i want to be layed out so cutting my bed up is ok
#103 |
WOW! a great thread! so much info to absorb here. I have searched, but cant find any pics of the front suspension set-up. do I need to cut anything out? I think so. can someone post a few pics of the front end done. thanks.
#104 |
lower than you.
Status:
Online
Member ID: 43083
Contitech 2600 air bags
24 Gallons GC 450 1/2" by 3/4" valve Oasis XD 2000 Custom 3 link 2 optima yellow tops |
#105 |
Member ID: 44245
I Am In The Process Of Bagging My 72 Chevy And Used Suicide Doors For Everything All My Buddies Used Them As Well They Used To Be Great But Now They Have Gotten So Big And Take A While To Get Parts Out Waited Around Three Weeks For My Stuff So If You Have Time They Are The Cheapest (price) Around Hope This Helps
#106 |
Member ID: 43125
just a couple of quick questions:
- Is the KP 6 link the same as the KP 4 link and cantilever setup? - I have a 4x4, what would be the best way (and cost effective) to get it low in the front without excessive camber, keeping in mind that you cant get spindles for a 4x4. i don't mind if it doesn't lay out in front... just want it close to laying. Would shockwaves be a good option in the front? i like them because of the easy install. |
#107 | |
well, just the obvious. 2 more bars |
#108 |
Member ID: 44341
Yes, a 6 link is the same thing as a four link and cantilever setup.
#109 | |
Member ID: 43125
#110 |
bag and drag
Member ID: 45299
NEWBIE here:
i bought from shAIM didnt know any better until i read this site i guess i didnt do my homework. Its up for sale on ebay-wish me luck I have an 88 gmc sierra I really want to bag it, and i really dont have to much funds to dump on the bags. I am looking at the 2 link system from godfather customs (extensive metalworks) they say i could have it for 725 shipped with the notch bags panhard bar ect. is that any good? I am not looking to make my truck hop i just want to go as low as possible and be able to raise it back up. So far this as far as i have gotten (just started today). I would like some help thanks the creeper |
#111 |
Member ID: 23617
thats a ripoff.
13.4 1/4
#112 |
bag and drag
Member ID: 45299
how about this setup? Does this look straight?
1358.92 shipped from suicidedoors.com SMC Water Trap 3/8" SMC 3/8" Dump Valve 110/145 PSI Non-Adj AVS ARC-9 Clear 9 Rocker Switch w/lock SMC 3/8" Fill Valve Firestone 255c 2500 (Front Bags) 3 Gallon 2 Port Black Tank No 2nd Compressor KP 200 PSI Dual Needle KP 200 PSI Single Needle Air Zenith 200 PSI Compressor 50ft of 3/8" DOT Reinforced Air Line 50ft of 1/4" DOT Reinforced Air Line Firestone 224c 2600 (Rear Bags) 945.00 88-98 Fullsize Chevy Single Port Cups 64.99 Basic Bridge Kit 159.99 ART 88-98 Full Size Chevy Front Shock Relocator |
#113 | |
Member ID: 16091
that doesnt have the rear link in it and i would run 25's all the way around and a 5 gallon tank
bada** rides are built not bought.
#114 |
Bad ass 92
Member ID: 8470
you mean 26's all they way around,
i am in the process of bagging my truck, and i am using suicide doors, but as everyone else on heres says don't cheap out, its not worth it.. |
#115 |
Hell Spawn
Need some help with this have a 92 ext cab stepside for the front I have 2" spindle and 3" drop shock for the rear 3" drop leaf 2" shackle and western chassis c-notch. Im going with the cool ride up front upper and lower control arms, but the rear drop is the problem. I have western chassis hangers that I can put on. The problem that I run into is the gibson 3" exaust. I dont need to lay it down in the back but I want to get a good tuck with the 18x10s I have any suggestions. Thanks
1992/2004 Silverados'
Ramstein AB, Germany ASE Suspension & Steering "STOCK is for GUYS who don't go DOWN!"
#116 |
Layin Body
Member ID: 39862
It all depends on how hard you want to lay in the rear. I bagged my 99 silverado abouth 3 mounths ago and had to turn my exhaust down before the axle. I have a thorebeck parallel 4 link and an 8" bridge and I tuck about 3 inches of a 22" rim in the rear.
Keep in touch, I'm about to bag a 95 silverado stepside I'll keep pics posted to help give you some ideas. It's gonna lay fram on 20s jus2fknlow |
#117 |
Stock sucks
Member ID: 38514
Alright some questions. How low can I go in the rear with my flip kit notch on 255/40/17in wheels VS a bigger notch without cutting through the bed? Will the bigger notch make a big difference or should I just keep my flip kit notch. I decided I dont need to lay out and want to keep it pretty simple but by no means cheap. I want lots of air and aengine driven compressor. Also can I bag just the rear for now or do you have to do it all at once? I need some suggestions on what all I should buy. Thanks
Another question I really like the airbar kit would I have to cut through my bed to get the maximum 10 inches of drop? ![]() |
#118 |
Member ID: 25890
all GREAT questions i would also like to know as im in the same boat!!
-TireFryr-v8TPI-212-218,110-1.52rollers-Fully Ported aftermarket TPI setup,52mm TB,Coated LTs,Built 700r4,2800Yenk stall,Hurst v-matic2,3.73posi "TractionLess" GoleET:13s Best 14.6-93mph 1.78-60' YenkoST is my Tunner!!
#119 |
305-35-24
Member ID: 5330
Simple, just do i right the first time, make sure your notch is big enough for your truck to lay out. Im having to do mine because in going from 22's to a 24.
1992 chebbie,bagged, 20/22, interior conversion, blah blah blah
1997 ford f-250 as seen in 8-lug mag. 2001 hoe, factory 20s and other bs |
#120 |
Ridin Derty
hey are airbagit.com's kits good?? ill have the money for a complete kit by june 14th
| Advertisements |
| Thread Tools | |
| Display Modes | |
