Old 05-07-2006, 09:51 AM   #121
305-35-24
Re: Advice on bagging a truck
Originally Posted by Nemesis8
hey are airbagit.com's kits good?? ill have the money for a complete kit by june 14th
you get what you pay for.
Say no to:
block valves
two links
small no name compressors
say yes to:
4links, custom made to your app.
SMC, "E" air valves, Parker
water traps
over kill compressors (oasis,york, thomas 4101)
locating all your stuff out of site.
1992 chebbie,bagged, 20/22, interior conversion, blah blah blah
1997 ford f-250 as seen in 8-lug mag.
2001 hoe, factory 20s and other bs
Zachs92 is offline
Old 05-08-2006, 05:00 PM   #122
icemike557's Avatar
I'm goin to bag my truck soon and wanted to know any suggestion on air, either to run nitro or use tanks and compressors, and if compressors which is good brand and size tanks to use on a 98 chevy 1500
icemike557 is offline
Old 05-11-2006, 10:47 AM   #123
305-35-24
Air and nitrogen are great, 8 gal tanks are good, more ports the better, that way you can run a line to each corner in stead of "T"ing off. Viair comps are great, ive burned a few up, the thomas 4101($399 for FBI) is what i have now and i run it way past 200psi and i work the **** out of it and it 100% rebuildable.
Zachs92 is offline
Old 05-13-2006, 10:06 AM   #124
icemike557's Avatar
thanx for the response and sorry if the questions sound stupid, im just startin to learn about this stuff, how are thomas compared to a york belt driven compressor, will they last about the same and are there any ups and downs of either one?
Old 05-14-2006, 08:01 PM   #125
305-35-24
the EDC spits alot of oil but hands down i would go with an EDC over my thomas 4101, i could have built EDC setip for how much the thomas was...
no question is a dumb question, you cant learn with out opening your mouth...
Zachs92 is offline
Old 05-18-2006, 11:06 PM   #126
Ridin Derty
Nemesis8's Avatar
i heard that kp's 4 links are weak, is that true?
also does the cantilever come with those shocks pictured with it?
also i have a friend that has his ranger bagged with a tri link and suggested i get a tri link for my 98 gmc ext cab. i always thought full sizes needed a parallel link and the mini's used the tri link. am i wrong?
oh yea are suicidedoors's THICK parallel links compatible with kp's cantilever?
Nemesis8 is offline
Old 05-21-2006, 12:55 AM   #127
305-35-24
I guess if you want a bolt on kit than there ok...
On a full size run a 4link, place all your bars in side the framerail, you will have to relocate the gas tank to the bed if you do this, but you have to do that anyways if your going to drag becasue those tanks hang down and throw good sparks.
If you locate all your link bars in side your framerail your wheel size is endless, you can narrow the rearend and run wide ass wheels and tires with the correct offset.
Zachs92 is offline
Old 05-22-2006, 07:32 PM   #128
Ridin Derty
Nemesis8's Avatar
i dont really want huge rims, that will look nice but right now im going for 20's
where can i find an affordable, dependable front kit? and which airmanagement kit should i buy from suicide doors? the 1/2 or 3/8? i want it to be fast
Nemesis8 is offline
Old 05-22-2006, 10:57 PM   #129
icemike557's Avatar
just wondering what people think about ekstensives 2 link setup, they are going to be doing my bags in 2 months and just wanted some input
Old 05-22-2006, 11:56 PM   #130
305-35-24
1/2 line if you want fast...
the 2link from them is ok, im just not a fan of 2links.
Zachs92 is offline
Old 06-17-2006, 10:24 PM   #131
How hard would it be to bag an 06 single cab on 22s? Currently stock suspension. Should I just get 20s instead? New to the bagging world.
nafunu32 is offline
Old 06-20-2006, 10:02 AM   #132
built to drag
to nafunu bag that **** on 22's, and 2 links SUCK A SS
Paulzy22 is offline
Old 06-20-2006, 10:27 AM   #133
Layin Body
jus2fknlow's Avatar
you can lay a nbs on 22's with ease
jus2fknlow is offline
Old 06-23-2006, 10:31 AM   #134
COLE ROCK's Avatar
Whats Up Guys...new To This Site. Some Quick Questions About Bagging.. I Have A 06 Silverado And Want To Bag It. I Know Itll Void Out My Warrenty And All The Other Greatness But Will Void Out My Warrenty On My Engine And Powertrain Or Just The Suspension Part End Of It. I Bought A Full Bag Set Up Last Night..let Me Know What You Think
COLE ROCK is offline
Old 08-21-2006, 03:47 PM   #135
Supporting Member
domestictuner's Avatar
I have read through much of this thread and thought i would ask a couple of questions that i didnt thik got answered or i didnt understand the answer.
i have a 99 nbs ecsb, I am planning on running 22" wheels all around and would like to lay frame. Can I use the kp components 6 link and lay frame with 22" wheels? How much of a notch would I need to acomplish this? Will the transmission crossmember and gastank crossmember need to be changed to lay frame?
Up front it seems there a million different ways to do the front suspension. With the goal being to lay frame and still be drivable, I am confused on the combination of control arms and spindles. If I use the cool ride kit what parts do I need to change to set the frame on the ground? Can this be accomplished with teh stock spindles and contorl arms? Also about the issue of the tierods hitting, is this problem solved when you change control arms? If this has been addressed before i apologize for having a thick skull
domestictuner is offline
Old 08-22-2006, 07:05 AM   #136
thorebeck brothers for the win!
And one other thing..100% duty cycle comps are crap.
GakiAkuma is offline
Old 08-24-2006, 12:52 PM   #137
Ridin Derty
Nemesis8's Avatar
how many relays doyou need tp bag your truck?
Nemesis8 is offline
Old 08-25-2006, 05:30 PM   #138
Ive had my truck done 3 times now. My biggest mistake was trying to save money the first time. Now that ive had it completly redone by a very reputable person i have no problems driving it on a regular basis. Im using a custom 4 link, with panhard, suicide doors monster notch in the rear, heavy duty air lift bags in the rear, all 1/2in line, slambags up front, belltech front spindles, dual compressors into a single 10 gallon air tank. Rides great, i still use it to tow, and it lays out.
1994 quad cab long bed dually, bagged and lays out. Custom painted, full audio, custom interior, chrome underhood. Must sell!
layedout1ton is offline
Old 08-26-2006, 12:24 PM   #139
Ridin Derty
Nemesis8's Avatar
heres another dumb question.
when you're truck is layn on the frame/doors/rockers or what ever and it rains. would the frame rust??
Nemesis8 is offline
Old 08-26-2006, 04:50 PM   #140
Stock sucks
CuZtOm90's Avatar
lol
CuZtOm90 is offline
