Old 03-19-2007, 01:05 AM   #161
Nemesis8
Ridin Derty
Nemesis8's Avatar
Member ID: 47071
Re: Advice on bagging a truck
installing my 6-link was my first install ever, and it took 2 days . i had a friend cut off all the suspension with a torch. he cut the u-bolts, shock mounts and all the other rivets, oh yea and he cut straight through the shock mounts on the axel.
i didnt use any straps to keep the driveshaft straight. it worried me at first but yea. i kept the tires on too.
have fun!
Old 03-19-2007, 07:55 AM   #162
gixer_kid
chopped user
Member ID: 62876
cool cuz thats usually how i learn everything is just by doing it...its really the only way with no experianced friends and no college education lol. Thats why i laugh everytime i hear a guy say he needs to go get his oil changed. Change it yourself!
tYs0n
Old 03-20-2007, 01:06 AM   #163
Nemesis8
Ridin Derty
Nemesis8's Avatar
Member ID: 47071
ha yea well good luck with those rivets if you dont have a torch! lol its gonna be a bish with out it!!!
Old 03-20-2007, 09:37 AM   #164
Marcos
Premium Member #69
AnotheR DimensioN
Marcos's Avatar
Member ID: 47427
Just cut the heads off, and air hammer them out, if you have access to that equipment, Otherwise it will be a bish. The instructions are dead on and its very simple, pretty much like changing a leafspring only lighter.
And no it doesn't come with notch's
Old 03-21-2007, 08:14 AM   #165
gixer_kid
chopped user
Member ID: 62876
Talking Re: Advice on bagging a truck
does the kit come with the crossmember? can anyone show me some pics of the rivest being bashed by an air hammer?
tYs0n
Old 03-21-2007, 08:15 AM   #166
gixer_kid
chopped user
Member ID: 62876
oh and marcos when are you gunna get new pics of your trcuk i wanna see them....do you lay frame? and how big are your wheels?
tYs0n
Old 03-21-2007, 09:50 AM   #167
Marcos
Premium Member #69
AnotheR DimensioN
Marcos's Avatar
Member ID: 47427
No the Kp kit doesn't come with a crossmember, I dont have any pics on how to take the heads off the rivets but its pretty simple...
And no all the pics I have are on my cardomain, I only work on it on the weekend's so every monday I update the pictures.
And no I dont lay frame, I chose to keep my bed intact because I still haul a lot of stuff around, and my wheels are 20"
Old 03-21-2007, 11:06 AM   #168
gixer_kid
chopped user
Member ID: 62876
so i take it you made the cross member yourself doesnt look like to much fab is involved? i like how you got 3 tanks UNDER the bed. i guess im gunna throw on some super c's so i can lay. So i take it the coolride setup from ART will allow you to lay out the front if notched/ tubbed for wheels? Do they come with the right cups? Do i still need drop spindles?
tYs0n
Old 03-21-2007, 11:33 AM   #169
Marcos
Premium Member #69
AnotheR DimensioN
Marcos's Avatar
Member ID: 47427
You don't need drop spindles but it helps with the camber on the tires and is easier on your balljoints.
And no, you have to trim the upper cups on the coolride kit... from what I found it, you should go to suicidedoors.com and just get some cups from them, and buys some slam bags, and a shock relocation kit... bam there is all you need besides the shock which can be picked up at a auto parts store.
Old 03-21-2007, 11:39 AM   #170
gixer_kid
chopped user
Member ID: 62876
you would have to weld on the relocater kit fron SD.com though....the welding doesnt bother me its where i put the shock that kinda worries me dont wanna f*ck up the front end. also the way you mentioned doing it, is that cheaper? would the best thing to do is buy the ART uca and lca coolride kit?
tYs0n
Old 03-21-2007, 11:41 AM   #171
gixer_kid
chopped user
Member ID: 62876
yah prolly gunna go the SD way because i am poor....whats the best size spindle 2" i suppose?
Dude does the shock keep the bag from over inflating or what? what if i had all this setup weve been talking about...how do you know when to stop hiitin switches...in other words im worried if i over inflate a bag. IS that possible???
tYs0n
Old 03-21-2007, 11:48 AM   #172
Marcos
Premium Member #69
AnotheR DimensioN
Marcos's Avatar
Member ID: 47427
Well you can actually buy the ART shock relocators from SD.com, but I hear that they break at the welds....
Well I would love to buy ART arms, but money doesn't allow me at the time, but they are nice to have... And yes sd is a whole lot cheaper.
As for the spindle, unless you have a 2500 or 3500, they only make a 2" drop spindles for 1500's
Old 06-19-2007, 02:59 AM   #173
Chevy_boy911
Member ID: 61901
ok! I got everything done on the rear and went to sit it down for the first time and the crossmember closest the cab was hitting the drive shaft. Is there any fix for this?
Old 06-23-2007, 12:21 AM   #174
extremetoy
Member ID: 67079
notch the crossmember or make a new crossmember
Old 06-25-2007, 03:38 AM   #175
firechkn
umm....hello
firechkn's Avatar
Member ID: 48064
I'm thinking of replacing my front 1" drop coils with Shockwaves on my ecsb nbs. What type of drop/lift can I expect? I also have 2" drop spindles installed already.
Old 07-14-2007, 10:57 PM   #176
kpex350
Member ID: 71175
Originally Posted by Socko
No matter what rims you use you will have to notch the frame somehow, either a bolt in under the bed notch. Or a step/monster notch in order to layout with any wheel. You should notch it when you do the bags getting the size of notch that will work with the 22s, for 22s you will also need to tub the wheel wells in the bed and for 20s in the front, on an OBS you have to remove the inner fender wells, I dont think you have to on the NBS (i could be wrong). Use 2" drop spindles, this way you can layout and it wont mess up a lot of the geometry. Some people run arms from Air Ride. it helps to correct the alignment/etc and is a cleaner setup.
The starting point of bags does not matter, many go from a 4/6 drop or whatever because thats what they had. You can bag it from bone stock the day you buy it. You will not layout on your stock rims because the tires are too tall, 30" stock tires are equal to a 22" rim/tires.
I 100% agree
Old 07-30-2007, 07:56 AM   #177
neverbackdownx
Member ID: 70059
i plan to get started on my 01' silverado soon im going full bag i work a a hose shop so im getting the hook up with stainless steal air line, but im going to keep stock control arms up front and just do cups and bags and out back i am going to do tri link
the number for the hose shop
THE HOSE CONNECTION
561-844-3699
Riviera Beach Fl.
Old 08-20-2007, 09:20 PM   #178
lowrider_dude
Member ID: 73126
i am 16 and building my truck to drive to school in a year i am going to order the air ride in the next couple weeks i was going to buy a kp6link with slam re-7 and then i just was going to but bag cups 2 and 3 inch with slam 7's also i will put spindles in the front will this stuff work help me out here
Old 08-24-2007, 10:13 AM   #179
hardluck
Chew On This
hardluck's Avatar
Member ID: 65587
You should be alright with that setup. I talked to a few guys this weekend at ITB who were running the kp 6-link. Even though it's a little pricey, they said they liked it alot, and it rode super nice. As far as up front, I'd just run SD cups and RE-7's. I've heard you can run 7's out back, but you may wanna consider running 8's. They're the same price. The 8's may give a softer ride out back with that 6-link, but that's just my opinion. What kinda truck you plan on doing this to man?
...Never falling victim to "The Norm"...
Old 09-12-2007, 11:54 AM   #180
kaos283
Member ID: 74349
Sup
Just got myself a nice 02 sylverado with a nice escalade front clip. Looking to put bags on it, it will be a daily and I need full space of the bed so this mean no big c notch for me (yet)
(and I just got out of a 2 year frame off/frame wrap so know I just want to relax)
Now, lets see if I'm missing something, from what I've seen on here my best bet yould be
ART shockwaves SKW2010-LUCA
ART airbar ABAR11007
Airlift air commander kit
4 smc valves (front back only is fine)
3 5 gallons tank (or anything that will fit under the bed)
It would be nice to have it controled on my remote (what should i get)
I'm probably missing some details so if you guys could fill in the blanks
Any help will be appreciated.
Thanks
2002 silverado, caddilac front clip, just got it. looking to bag it next summer, meanwhile i'll try to get as much info as I can
