Old 03-13-2005, 04:46 PM   #1
Project Neverending
Mavmavv's Avatar
York 210 Clutches
What would limit me from using the clutches on my existing AC compressor that I have in my truck right now? Im taking out the ac anyways for the onboard air, could I just use the clutches on there now, or are the clutches exclusive to the York? Just trying to save some money. Lemmie know what everyone thinks.
One Nine Seven Eight
Mavmavv is offline
Old 03-13-2005, 08:24 PM   #2
Re: York 210 Clutches
The yorks have a certain tapered shaft and key way. They probably will not use your current clutch. I like inexpensive, but hate cheap.
Good judgment comes from bad experience.
A lot of that comes from bad judgment.
Democracy is two wolves and a lamb deciding what to have for Lunch. Liberty is a WELL ARMED lamb contesting the decision!!
dapolice1 is offline
Old 03-13-2005, 08:45 PM   #3
Wuuuazuuup!!!
Kruznlow69's Avatar
yup yup.. definatly not interchangable, the york compressor's come large and small case, ie: 209sc 209c, the large cases have 4 bolts holes in a square pattern and the small cases have 3, two on top, and one low in the center.. the 210's are only large case and are the preferred engine driven for custom setups, most aftermarket kits utilize the 209sc's... also all three 206, 209, and 210 have different shafts, they are noted by the outer edge of the shaft, beveled edge(206), a deep groove (209) and a sharpe edge (210) 6, 9, and 10 being the cubic inch of the compressor.. depending on which york you have, any auto parts store sould have a "four seasons" a/c book to help you get the right clutch, i keep my own books to save steps..
REBUILD THREAD Wreck Thread My StreetSource
"Lifes all bout making mistakes, It's how you learn from them that counts"
Kruznlow69 is offline
Old 03-13-2005, 09:14 PM   #4
Project Neverending
Mavmavv's Avatar
well, it was worth asking I guess. Thanks for the info! How much do the clutches go for again? ~100 bucks?
Mavmavv is offline
Old 03-14-2005, 02:00 PM   #5
bagged on 22's
ur2hi's Avatar
onboardair has them for $110 i believe
ur2hi is offline
Old 03-14-2005, 03:30 PM   #6
Project Neverending
Mavmavv's Avatar
yeah, I was checking them out today. Any place like napa that would have it cheaper? Since im prolly gonna get the compressor fom there.
Mavmavv is offline
Old 03-14-2005, 03:35 PM   #7
Beaner/Cracker
http://www.fullsizechevy.com/forums/...d.php?t=148743
That thread has the vehicle info you need to get the comp/clutch from a parts house.
Izzy is offline
Old 03-14-2005, 07:45 PM   #8
Where did you get your Fourseasons catalog?
Old 03-14-2005, 08:46 PM   #9
you should be able to use your own compressor just have to tap it for air and either put an inline oiler or tap the case for oil. If you are trying to use your clutch on a york that won't work but if you are pulling your ac just use your ac compressor.
-ben
slammed 84 crewcab with a cummins
btanner is offline
Old 03-14-2005, 09:22 PM   #10
Project Neverending
Mavmavv's Avatar
Hrmmmmm... maybe ill look into that. Ill go find out the numbers it puts out and see if its worth it. That would Definitely save me some money and still look factory!
But I looked up that clutch at autozone for the f100 and its only 60 bucks. That definitely makes me a happy camper.
Update: Autozone has the whole assembly for 148.99 /w 10 dollar core charge. So if thats the right comp and clutch, thats a helluva deal.
Another update, I have a carb'd TBI motor in my truck and my alternator is on the passenger side. Is it stock like that?
Mavmavv is offline
Old 03-15-2005, 07:30 AM   #11
bagged on 22's
ur2hi's Avatar
that clutch is the v belt. i use a serpentine belt and the clutch is more expensive
ur2hi is offline
Old 03-15-2005, 10:16 AM   #12
RPM Graphics
GoNDown's Avatar
check ebay for the clutch i got mine & see them on there all the time for about $15
BUILT, NOT BOUGHT!!!!!!
YOU DROP YOURS......... & I'LL DROP MINE!!!!
http://www.myspace.com/rpm_inkz
GoNDown is offline
Old 03-15-2005, 03:05 PM   #13
Project Neverending
Mavmavv's Avatar
Well, I need the V Belt Clutch since thats what my pulley setup is. Im gonna call around today at the yards to see if anybody has some.
Mavmavv is offline
Old 04-16-2008, 10:46 PM   #14
Grass Shrimp
02chevygmc's Avatar
http://www.partsamerica.com/ProductD...pe=387&PTSet=A
Is this a good price for a york compressor?
[IMG][/IMG]
02chevygmc is offline
Old 04-17-2008, 11:05 AM   #15
Drive and Enjoy.
Low88's Avatar
actually believe it or not, alot of other clutches will fit a york. You can find them on ebay from time to time. I got my serp clutch for like $60 or something. the one off of your AC will most likely not work though.
Low88 is offline
Old 04-17-2008, 10:40 PM   #16
bagged on 22's
ur2hi's Avatar
Holy old posts Batman!
ur2hi is offline
Old 04-18-2008, 12:01 AM   #17
Rafaels6's Avatar
ryder fleet products i think its called has the cluth for under $100 think it was around 80 i got one from them they ship fast too i might have one for sale
AnotheR DimesioN
Rafaels6 is offline
