Old 07-13-2008, 09:00 PM   #141
MACON911
MACON
Member ID: 32103
Re: Post Your Setup
what size tires are on the back cause i i the same rims and size and im runnin 285-45-17 and 245-40-17 up front
Old 07-16-2008, 08:12 AM   #142
trainhorn22
Member ID: 81343
Re: Post Your Setup
i got a question i was wondering if i just took my facory coil springs on my silverado and cut about 2" off tham would it work for lowering my truck i was gonna lower it 2 in frunt and 5 rear so it sits good
Old 07-16-2008, 09:28 AM   #143
CDub01
CNC Laser Tech
CDub01's Avatar
Member ID: 69611
Re: Post Your Setup
Cutting 2" off a spring will result in a LOT more than 2" drop just so you know.
Also, cutting springs results in a fairly harsh ride in most cases.
Old 08-04-2008, 10:04 AM   #144
r1lorenzini
Member ID: 83488
Re: Post Your Setup
4-6 ece drop kit 1972 2wd k5/
Old 08-24-2008, 08:20 PM   #145
budhayes3
budhayes3's Avatar
Member ID: 14219
Re: Post Your Setup
1999
Chevrolet
Silverado Z71
4x4
285/50-20 Toyo Proxes on Joe Gibbs Performance wheels
Belltech Lowering Keys
Belltech 2" Lowering Shackles
4x4 Lift Blocks Removed
Spring Clamps
Bumpstops trimmed accordingly
Here's what it looked like before the drop, at factory height with 285/75-16's (32.9")
My CarDomain Page
99 Z71 RCSB 5.3 Comp 206/212, Volant, PCMforLess 02 PCM, StainlessWorks LT's & catted Y-Pipe, Gibson si/do cat-back minus tailpipes, Belltech 2" drop shackles, keys,- lift blocks, JGP 20's w/ Toyo Proxes 285/50's
Old 08-25-2008, 04:00 PM   #146
aztekas69
aztekas69's Avatar
Member ID: 89342
Re: Post Your Setup
Old 08-25-2008, 08:20 PM   #147
KADILLACKID
Keep on truckin
KADILLACKID's Avatar
Member ID: 28536
Re: Post Your Setup
Originally Posted by budhayes3
1999
Chevrolet
Silverado Z71
4x4
Spring Clamps
Nice truck,I REALLY REALLY LOVE those wheels
Old 08-26-2008, 09:23 AM   #148
budhayes3
budhayes3's Avatar
Member ID: 14219
Re: Post Your Setup
Thanks man!
My CarDomain Page
Old 09-05-2008, 08:03 AM   #149
bradenn
bradenn's Avatar
Member ID: 69818
Re: Post Your Setup
before
after
I've properly aligned the body and box with new bushings and fabricating some new cab mounts. Also the truck sits high at the front because I have the 4.3L engine. A relative has given me a '68-'69 327 with a forged crank and four bolt mains out of a corvette? nova?
I've had some rubbing/grinding issues with the LCA and it hitting the wheel balancing weights on the wheel. I will eventually put some bigger wheels on it and that should solve that problem. Then a quick coat of paint and I'm ready for a new truck.
89 RCSB C1500, 4.3L, 5sp, TB spacer, K&N, DJM 4/6 drop [2" coils, 2" spindle, 6" flip kit], Leer 100XL
To come: 20" Iroc replicas, Line-X inner fenders and box, engine swap, SilverStars
Looking for: Interior parts, please PM/email me if you have anything!
Old 09-05-2008, 09:18 AM   #150
gmctrucks
Member ID: 58218
Re: Post Your Setup
Bad picture but I bought like this back in 1993 fade job, wheels and so on.
Old 09-05-2008, 12:43 PM   #151
KADILLACKID
Keep on truckin
Member ID: 28536
Re: Post Your Setup
Originally Posted by bradenn
before
after
dude, is that your truck in your avatar? can you post more pics of it?
Also,where are you,I have lots of interior parts,what do you need?
Old 09-05-2008, 02:24 PM   #152
bradenn
bradenn's Avatar
Member ID: 69818
Re: Post Your Setup
Yea that's my truck in my avatar.
454ci big block 2 bolt mains, rectangular port heads, pete jackson gear drive, demon 750, ceramic coated headers, all ARP hardware, moroso pan, moroso electric pump, torker intake, hi-torq mini starter
I was working on fabbin' up my own rollpan but decided that it would be best if I sent it out to get it done.
I am located about two hours north of Toronto. I need bucket seats in GOOD shape, and pretty much any/all plastic dash pieces that are blue to match.
Old 09-06-2008, 08:50 PM   #153
gmctrucks
Member ID: 58218
Re: Post Your Setup
Keep us posted bradenn when your truck is done it's looking good.
Old 09-27-2008, 02:29 AM   #154
05silvy
Member ID: 89247
Re: Post Your Setup
2005 Silverado
5.3
3/4 drop, belltech ec springs, hangers and shackles
18" centerline archers
265/60/18
2005 rcsb 5.3 silverado,3.73's,3/4 belltech drop, magnaflow si/do, Airaid CAI, 18" Centerlines, debadged
Old 09-27-2008, 12:01 PM   #155
budhayes3
budhayes3's Avatar
Member ID: 14219
Re: Post Your Setup
Originally Posted by 05silvy
2005 Silverado
5.3
265/60/18
Those Archers are great...I've seen your truck on PT.net...95 bright teal right?
My CarDomain Page
Old 09-27-2008, 04:05 PM   #156
05silvy
Member ID: 89247
Re: Post Your Setup
Yep i was told i should come check this site out so here i am, i have actually had an account for 4 months just never posted
Old 10-02-2008, 07:49 PM   #157
Andy98chevy
Member ID: 81010
Re: Post Your Setup
1998
chevy
silverado 1500
2wd
235/75/15
15x7
4in. front with beltech 2in. spindles, and 2in. springs
6in. rear with flip kit and c-notch from beltech
-had to roll the lip on the fenders, and notch the drip rail on the control arms.
Old 10-02-2008, 08:45 PM   #158
STF
STF's Avatar
Member ID: 66156
Re: Post Your Setup
Originally Posted by Andy98chevy
1998
chevy
silverado 1500
2wd
235/75/15
15x7
Looks clean man. do you know what the backspacing on those wheels is?
Old 10-02-2008, 09:52 PM   #159
Andy98chevy
Member ID: 81010
Re: Post Your Setup
4in. i believe.. got them used off another obs chevy
Old 10-06-2008, 09:39 PM   #160
nevada89gmc
Member ID: 80613
Re: Post Your Setup
great thread, very helpful since i am looking at doing a 3/4 drop with 15x8, not sure about tire sizes yet, but open to input, thanks for the input.
