Old 10-02-2008, 04:19 PM   #21
billlilgreen's Avatar
Re: Alignment question
Les schwab. 40 bucks for an allignment.
billlilgreen is offline
Old 02-27-2009, 11:01 PM   #22
donit's Avatar
The shop I went to said the uca's must be unbolted to remove the piece. Said there is no way to cut, grind, or chisel it out without removing the uca's ???
SIGNATURE REMOVED FOR BEING OVER SIZE LIMIT.
donit is offline
Old 03-01-2009, 09:44 AM   #23
95 C-1500 Ext. Silverado
The alignment shop that I deal with told me it's no big deal at all to do and will cost me $140.00 at the most if they have to remove the knockouts.
1995 Silvy ECSB
Nothing fancy just old, reliable & paid for !!!!
Bigg G is offline
Old 05-09-2009, 01:17 PM   #24
UNDER CONSTRUCTION.......
addiction2bass's Avatar
im still not sure about these knockouts. im in mid progress of dropping my front....
so do i just bent these bent out pieces flat? or cut them off? or are mine already removed?
at least im thinking its these little bent out flaps....
do i just knock these flaps down flat with the rest of it?
ive searched online and cannot find any pictures of the knockouts before and after so not sure exactly.
97 C1500 Extended cab 3rd door.
addiction2bass is offline
Old 05-09-2009, 02:03 PM   #25
jolt11's Avatar
no worries,your knockouts are gone. the little tabs along with the bolt and washers are used to align your upper control arms for the correct camber
jolt11 is offline
Old 08-29-2009, 09:32 PM   #26
BigGixx's Avatar
excellent information, the plates with grease between them is what crew chief use on planes it helps alot
BigGixx is offline
