#1 |
Member ID: 95933
How low can you go
I have an 89 RCSB. I want to go as low as I can without air bags. I have lowered it 4/6 and would like to do 3 inch body drop. How low can I go and not have problems with front tires rubbing? What size tires? Wheels? Any pictures?
#2 |
Status:
Online
Member ID: 86983
Re: How low can you go
NO BAGS = No BODYDROP
I guess you could channel it like the old hotroders.. just bag it! |
#3 |
Premium Member #69
AnotheR DimesioN
Member ID: 47427
You could do a body drop with out bags, Some people have done it.
#4 |
Member ID: 84320
Why dont you want to bag it?
#5 | |
Is this better B**ch?
Member ID: 76635
Are you a bodyman by trade?
![]() ![]() Quote:
#6 |
the Waco kid
Member ID: 1522
There's a good sticky thread here with lots of discussion:
http://www.fullsizechevy.com/forums/...ck-static.html Also another sticky with pictures: http://www.fullsizechevy.com/forums/...ars-drops.html Also, you can go as low as 6/8 static if you want to without bags but its not generally recommended. I ran 5/8 daily for a while with no real issues. It also depends a lot on tire size wheel backspacing, etc. Welcome to FSC, spend some time in the street section, and Search is your friend :)
2003 Avalanche 2500
2002 Tahoe 1996 Silverado
#7 | |
Member ID: 11358
hmmm...can channel but not body drop?...they are different approaches to the same result which is a body sitting lower on the frame. |
#8 |
Member ID: 95933
Thanks for the replys to the post. I am not an auto body man, I am in the transmission buisness. I do love to fabricate. The 89 RCSB truck is a low budget beater NO billet NO shiney paint and no air bags. That would cost more than I have in the whole project now. It drives great with suspension mods right now (spindels, springs, Home fabbed axle flip and C-notch). Any more suspension modifications I may sacrifice the ride. If I do a body drop where I would lower the cab mounts, brace and trim off the top of the frame and raise the bed floor 3 inches I don't know if the tires will rub in the front when I steer. Final wheel and tire size has not been decided, it will probably be 15 inch wheels.
#9 |
Status:
Online
Member ID: 86983
Thank god your into transmissions.. your name: "TRANSMAN" led me to think you may have had some other sort of fabrication doen to yourself...
Whoooo... dodged that bullet |
#10 | |
Member ID: 84320
LOL, He's not a tranny. |
#11 | |
the Waco kid
Member ID: 1522
2003 Avalanche 2500
#12 |
Member ID: 93004
i am a 5/7 every day, and i enjoy it. Looks good, rides on rails.
#13 |
Member ID: 95933
I guess my question should be, Is there anyone out there with 7/9 drop and no bags? And still use it for a regular driver?
#14 |
Member ID: 71769
I don't think you want to go lower then 6" without bags. Even 6" is pushing it IMO If anything go with 5" in the front to be safe. Maybe Fab a coilover for the front and then you can adjust to what you will be happy with.
Lowkey
eriK Getting on the map |
#15 |
teh ownji
Member ID: 18305
i can see where he's coming from. i always thought a static bodydrop would be sweet.
the problem with actually driving anything lower than 5/7 is ground clearance and this doesn't change with the body drop. frame/cross member will still be the lowest part of the truck (airdamn will be gone i guess). so the only real problem is tire clearance in the front. i was at 4/6 with some meaty tires and room to spare, so i'd imagine that it would be possible with some small 15s. easiest way to figure it out is to take some measurements with bagged trucks |
#16 | |
Member ID: 79730
#17 |
Member ID: 97033
Depends on how nice you want it to ride
| Advertisements |
| Thread Tools | |
| Display Modes | |
