02-27-2007, 06:46 AM
#41
Wuuuazuuup!!!
Re: The York Thread.
Originally Posted by chaps7931
some people dont know but its recomended that the york be painted black rather then some original silver, it desipates heat faster and beter
ummmm ????? not really
please back this statement up...
Originally Posted by ARVCUBE
so is there anyone selling one of their custom brackets for the vortec v8's?
i could start making some if it there were a few more people.. they are kinda tricky and my setup depended on my alt, relocating a lot of stuff and so on.. for my application it werks great..
03-22-2007, 04:29 AM
#42
He may not be able to, but I partially will. Color of the paint makes no difference (so long as its not silver), but a painted surface will radiate heat better than an unpainted surface. Do a google search for paint heat radiation and see what you come up with.
03-22-2007, 06:44 PM
#43
Bagged & Bodydropped
What size inline fuse should I use for the clutch?
03-22-2007, 07:08 PM
#44
5 Amps.
03-22-2007, 07:27 PM
#45
Thank you very much... I couldn't find it anywhere on here... And I dont have a PDF file reader at work.
04-03-2007, 09:58 PM
#46
Okay is this the stuff thats supposed to be coming out of my york?
30w non detergent oil, Its a used York 209
04-03-2007, 10:21 PM
#47
OVER8TD
Mmmmmmm, that's the stuff! I kinda miss draining it on the ground and everyone asking wtf it is.
1994 K1500
9" lift
37" Pro Comps
04-03-2007, 11:30 PM
#48
I thought it was supposed to come out more clear?
04-04-2007, 08:11 AM
#49
Wuuuazuuup!!!
nope thats the pooooo.. you know you're overheating your york when the filter (inside) gets chunky darker stuff. thats really smells like a treat! gotta keep it clean inside too.
but yeah thats normal. i kept a small gatorade bottle in my "york service bucket" to blast it into from the filter. along with some wrenches, a cpt qts of 30wt oil, rags, and extra white teflon rings and o-rings if i had to remove the fittings for some reason?
04-04-2007, 09:51 AM
#50
Cool, I was a little worried...
also, where did you get the fitting for the case vent mod?
04-05-2007, 06:29 AM
#51
Wuuuazuuup!!!
i got my parts from a local racecar shop.
05-11-2007, 07:49 AM
#52
sparks flyith deathcomith
Looks the same as mine, I was let my go in parking lots lol. Looks like some cow pee! lol
Project Dirty OldSchool Rebuilt 350 .30 over. Fullly bagged with Kp 6link, custom watts link. "If your not first your last"
2002 dodge cummins turbo diesel 6spd 5 inch exhaust! FASS 95/150
http://www.myspace.com/hammeredchevy
05-13-2007, 08:18 AM
#53
Wuuuazuuup!!!
i kept a thin gatorade bottle with a nice locking top to spray it into. i'd jsut pour it into my waste oil buckets and recycle or jsut toss the bottle, please dont jsut let it fly, i'd hate to step in that stinkpile of oil!
08-07-2007, 10:12 AM
#54
enlarged member
whats this oil dropping for? just routine changing as if it were a car motor? how often do you have to change it out? thanks
another ?? whats the difference between car motor oir, and this non-detergent oil for the yorks?? im a lil confused about all of this.. thanks guys
Breakin Necks!
08-11-2007, 01:05 AM
#55
Does anyone run the kilby combo pulley on their alternator for the york or is it best to find the right clutch for the serp.? I found a york with the v groove clutch already on it and thought I'd just get this pulley instead of a whole new clutch. Thanks..
http://www.kilbyenterprises.com/pulleys.htm
08-11-2007, 07:19 AM
#56
Drive and Enjoy.
I am running the combo pulley, but it ended up being the wrong size groove for the clutch on my york. Good thing there was enough to turn it to the right size on the lathe.
08-11-2007, 07:20 AM
#57
Drive and Enjoy.
What are all of you using to fill your yorks? I used to have this funnel that worked decent, but I discovered the caps on differential fluid containers are amazing to fill a york with.
08-11-2007, 07:18 PM
#58
08-30-2007, 12:18 PM
#59
I thought I should put this info here for what car comes with a York 209.
Audi
1980 - 1983 4000
1985 4000S QUATTRO
1986 - 1987 4000CS QUATTRO
1985 QUATTRO
1984 - 1987 4000S
Thats all I found for the 209 compressor, I hope it helps.
09-04-2007, 10:32 AM
#60
I found one of those bottles that comes in those hair color kits at my girls house, it has a very small tip and works pretty well.
98 1500 ext 350 vortec, Volant air filter, Edelbrock ceramic coated headers, Magnaflow high flow cats, duel bullets and turndowns, Comp Cam 210/220, Wheatley Tune, 2 link by ekstensive, york 210 engine driven compressor, layin frame on 22's
| Thread Tools |
| Display Modes |
Linear Mode
