04-26-2008, 09:00 PM
#101
DRAGGIN CREW CAB
Re: The York Thread.
Who here is running their EDC's with an unloader valve. Thanks
If you do what you have always done, expect to get what you have always gotten!
04-27-2008, 05:31 AM
#102
Ohh yeahh Megasquirt !
My unloader's a line lock valve nice 1/8 NPT fittings. I run it to the center wire from the EDC Relay, Pump on unloader off , pump off unloader on. Ya know the wire that never gets used on a relay, I think it's 87a
04-29-2008, 08:15 AM
#103
DO all yorks need to be vented on the side like the two pictured in post #84?
04-29-2008, 09:11 AM
#104
Bagged & Bodydropped
No, it just helps with oil consumption.
05-01-2008, 07:14 PM
#105
i just put in a new york and it throws alot of oil out of my vent... is it just because it is new?
98 1500 ext 350 vortec, Volant air filter, Edelbrock ceramic coated headers, Magnaflow high flow cats, duel bullets and turndowns, Comp Cam 210/220, Wheatley Tune, 2 link by ekstensive, york 210 engine driven compressor, layin frame on 22's
05-01-2008, 07:20 PM
#106
SKR8PN
...yeah bro... according to what i've read in this & other posts it'll do that until it gets broken in.
coigna
... barely scrapin' by ...
05-01-2008, 09:09 PM
#107
anyone have any spare york Head gaskets ? . I believe I've breached the discharge port below the top most plate. Re-tourqe'd the bolts and No change.
spits oil on the wheel well. I'd like to remedy this before I remove the wells. all the kit's I see on egay are 69$ and I don't need all those parts. would napa get me by ?
05-19-2008, 09:29 AM
#108
when i go to my salvage yard tonight.. the guy told me he has several to choise from.. what should i look for so i dont get riped off?
05-19-2008, 11:02 AM
#109
Feeling a little low...
A 209 or 210. Square top or round top will work. Get the clutch too and make sure the compressor's not siezed...
...Never falling victim to "The Norm"...
05-21-2008, 11:14 AM
#110
he's asking $125.00 for a used one.. i think i can get a new one for close to that.
05-22-2008, 09:24 AM
#111
That seems pretty steep from the bone yard. I got my remanufactured 210 off ebay for like $75. They were all over there when I got mine. Sometimes they'll be listed under Four Seasons...Just make sure what you're getting is right-hand suction.
05-23-2008, 08:34 AM
#112
why would it matter to get the right hand suction?
05-23-2008, 09:35 AM
#113
I always thought it was direction of the pulley rotation? My engine goes clockwise, and when I rotate my compressor clutch clockwise, it sucks through the suction side, and purges through the discharge side. You turn it the other way, and it's backwards. So I'm guessing a left hand suction compressor would be bakwards?
05-30-2008, 12:05 AM
#114
Hard times Kustoms
my york
the bad part
i opened er up bam snapped connecting rod laying in there
look in front of finger
ayden james woodbury
6-16-08 to 7-30-08
my son
06-02-2008, 02:07 PM
#115
ouch dude... so now what?
06-02-2008, 04:06 PM
#116
Hard times Kustoms
old school chevy from gmfs had one that was a little grooved so he's sending it to me and i migt macine it to smooth it back out
6-16-08 to 7-30-08
my son
06-03-2008, 08:17 PM
#117
'88 Chevy
I second wanting to see some pictures of people who mounted them relatively near the stock AC spot if at all possible. I never use the AC in mine, so I was gonna take out the stock pump anyways.
06-10-2008, 02:01 PM
#118
has anyone modified the Easystreet Air 209(mini) bracket to fit a 210?
if so, could someone post pics, i'm runnin into this problem and the bracket is the only thing from gettin my EDC running
06-23-2008, 03:52 PM
#119
Supporting Member
i got my edc kit from suicidedoors when I got my bags, how do I drain the oil out of it on the truck? can i just pull a bolt out of the bottom of it?
07-18-2008, 10:52 PM
#120
The Man The Legend
Damn this thread has helped me out alot. I got a 02 NBS with a 4.3 and plan on doing an edc on it. Just got to find a bracket for a 4.3. DOes anyone know of the same year 4.3 s10 is the same motor. from pics and seeing some in person they look the same. Just want to make sure before I go out and buy all the parts to find out it won't work.
| Thread Tools |
| Display Modes |
Linear Mode
