10-16-2008, 09:25 AM
#141
is laying rocker
Re: The York Thread.
got a motorcraft version of the york. looks the exact same. i'm psyched to get it goin.
Bag. Drag. Get Layed.
10-20-2008, 10:10 PM
#142
when i bought my new serp clutch was i supposed to grease the bearing? because after about an hour of running the clutch squeaks whether its on or not.... once i find an impact ill grease it..
11-03-2008, 06:59 PM
#144
If anyone is puttin a york on buy the kit off suicidedoors.com.its killer
DRAG THAT ****!
11-03-2008, 07:12 PM
#145
Feeling a little low...
Made my own bracket for the york 210 on my '95. Still keepin the a/c too...
...Never falling victim to "The Norm"...
11-13-2008, 04:33 PM
#146
Anyone have to make spacers so there belt aligned better on the pulley for the compressor? I had to replace my compressor bracket since from the vibration it snapped! I have the Airlift kit and recently unhooked it well like a year ago actually. After I replaced the brackets it started snapping belts, never snapped a belt before that in 2-3 years! Think I need to place some spacers on it...??
12-10-2008, 11:19 PM
#147
can I use the electric clutch from my a/c on my 350
and how do I operate one edc with a tank for the front, a tank for the rear? do I have to tie the tanks together?
NO CHANDALEARS I HAVE GUNS HANGING FROM MY CEILING
 rebuild begins
12-11-2008, 09:42 AM
#148
Tie the tanks together and it should work just fine. As far as the clutch goes, you have to use the clutch that mates to the compressor. I used one from a Kenworth, since they run York 210's.
12-12-2008, 07:08 AM
#149
ok cool,I cant just go to advanced auto and tell them what I need, because I did one time and the guy looked at me like a dumbass and was like " go online and you can get a whole air ride kit for like 1800" so whatever I know you guys will be more helpfull. Thanks
 rebuild begins
12-21-2008, 06:41 PM
#150
Brass air fittings
Now that is a lot of brass air fittings http://www.liangdianup.com/subpages/airfitting_1.htm there is just about every type
of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
used some of the parts to make my babington wvo burner.
01-10-2009, 02:53 AM
#151
CBCS
Cool, I Just Got Me A Motorcaft Version Out Of My Grandpas 69 F-100 And Im Going To Start Working On My Set Up As Soon As I Make A Lil More Money....
01-15-2009, 12:55 PM
#152
i thought ford used yorks for their ac?
Hated by Most - Feared by None
02-11-2009, 07:53 AM
#153
Oregon's Finest
does anyone make a york bracket for the vortec small block? I have a york 210
03-31-2009, 02:43 PM
#154
Do yorks need to spin in a specific direction? will they work regardless of if the crank pulley spins clockwise or counter clockwise?
04-14-2009, 11:00 PM
#155
hi all i plan on buying a york off waylard when they are back in stock and am just wondering if you can buy all the other gear needed to set it up in a kit? this is to suit a 90 model with a 350. Just hard to buy induvidual parts as i am in australia
04-16-2009, 07:26 AM
#156
i cant believe this hasn't been posted in here yet....
04-18-2009, 06:11 AM
#157
very helpfull thread
04-23-2009, 11:23 PM
#158
Anybody tell me if motorcraft or Eton made a version that will work? I think I found one at a yard but one says Motorcraft and the other says ETON.
Thanks
04-23-2009, 11:44 PM
#159
Bump sorry now I see Motorcraft everywhere above me, How bout the Eton?
Thanks
08-30-2009, 09:35 AM
#160
Supporting Member
a couple things not covered about Yorks.
First I was an A/C tech from 1980 thru 1999 and did alot of Yorks back in the day. I also did Yorks on big trucks, like Freightliner, Peterbilt etc.
one thing is that if you run the York as your primary source of air for your bags understand that the cylinders in the York need a small amount of oil or they will scorch, heat up the cylinder and then it starts to leak. It also scorches the reed plates in the head and they lose there tensile strength.
If you do the oil mod your cylinders no longer get any oil and you need to an an air tool oiler to the inlet side of the system. get a good adjustable one and turn it all the way down. then get a seperator on the outlet side. It will catch the very small amount of oil coming out plus it catches anything else that leaks by the pistons.
next is the clutch, most aftermerket or new clutches come with small washers. these go between the bearing and the clutch to space it properly. theres about 5 washers in the clutch kit. some are thin and some are thicker. look at the instructions to get the proper spacing for the clutch. too much space and it slips under heavy load and eventually burns up the clutch and sometimes the heat melts the wiring in the magnet.
also using a quality synthetic non detergent motor oil will make the York last longer.
| Thread Tools |
| Display Modes |
Linear Mode
