#1 |
Pimpin' aint easy
Member ID: 34197
How much pressure have you ran with your EDC?
Figured id throw this up. Took out my blow off valve thing so i could run some more pressure. Forgot the switch was on for a while haha...didnt blow it up so thats a good thing..how much PSI do you think this is?
![]() ![]() Show- Bagged w/6 link, 15 gal under bed, EDC, 22's, Satin black, GMC grille, HIDs, custom interior, 18" BTL in a blow through w/ Kicker kx 2500.1
Go- 350 w/headers, true duals, TB spacer 2000 NBS Tahoe LT www.subsonickustomz.com |
#2 |
Supporting Member
Member ID: 34172
Re: How much pressure have you ran with your EDC?
ha ha done that more than a few times
#3 |
Premium Member #69
AnotheR DimesioN
Member ID: 47427
#4 |
So whats the no frills way to setup the EDC?
York with switch, brackets, braided leader hose with check valve, water trap, and airline to tank? I'd like to have the option of running up to 200psi. I have the york right now, just need to setup the brackets and get the lines and crap.
#5 |
Supporting Member
Member ID: 34172
yup pretty much leader hose to air line air line to water trap(s) water trap to air line to check valve to air line to tank
#6 |
Supporting Member
Member ID: 34172
for the switch i used the cargo light switch nice and clean would never know its there
#7 |
NICE! I'm all about reduced costs.
#8 |
Member ID: 76427
id say thtas close to 300 psi
dont be a faggit......drag it
#9 |
sitting sideways
Member ID: 56746
we need video of you airing up with that much psi
![]() 99/5.3/built 4l60e/k&n FIPK/udp/hypertech/dual flows/efans/custom blowthru box/ 20's/ static as of now R.I.P. Boyd |
#10 |
Stepsider
Member ID: 44912
We tried to hop it but she only hopped the back a bit.
#11 |
Premium Member #69
AnotheR DimesioN
Member ID: 47427
Must have too much weight since I can get mine to hop with 230
#12 |
Pimpin' aint easy
Member ID: 34197
ill put the video up in a sec..couldnt get the front end off the grond but the back cam up an inch of so..
#13 |
Pimpin' aint easy
Member ID: 34197
Go- 350 w/headers, true duals, TB spacer 2000 NBS Tahoe LT www.subsonickustomz.com Last edited by Nickleahy23 : 05-30-2008 at 04:53 PM. |
#14 |
void
Member ID: 4335
Be careful with a york. They will produce a tramendous amount of pressure. I had a check valve lock up and my york exploded. As you can see from the pic, it blew the side off my york.
95 GMC Sierra ext. stepside. bagged with kp 6 link. Denali front clip. Underconstruction!
95 Chevy Silverado ext. fleetside. Stock daily driver. |
#15 |
Wuuuazuuup!!!
Member ID: 326
nick on kp gauges thats just over 250-275 id guess. i cranked my nitrogen up once to 250, which was just under popping my 250psi BOV and it was at about the 6 0'clock position. definatly carefull with that. yorks can overheat running longer to build up that pressure. will burn em up or make em spit out gunk that will clog filters fast and then burn em up.. (don't know why??? lol)
not to mention, if you didnt build your truck to hop be carefull, a lot of hoppers blow balljoints, those hi-travel moogs in your uppers arent as solid as a totally encased balljoint.
REBUILD THREAD
Wreck Thread My StreetSource ![]() "Lifes all bout making mistakes, It's how you learn from them that counts" |
#16 |
Member ID: 84929
i had a sanden on my s10 and they pump a little slower but like to pump high pressures. i ran mine at 225 daily and a buddy ran his cause he likes to hop, at 300 psi daily. we took care of them and there still running strong.
#17 |
Member ID: 81442
i also had a sanden on an s10...forgot it was on a few times had to run like 400psi it hopped a couple feet. i ran about 200 daily and id run it up to 350ish to show off.
1996 xcab 4.3 5spd - bagged front flipped rear. dammit i started another project
1988 Mazda b2200 - stock floored, unibodied, etc 1993 BMW 325iS - fake m3 dd 1967 Lincoln Continental - for sale |
#18 |
Drive and Enjoy.
Member ID: 19385
I did that one time, cranked it right around till the needle stopper. atleast 300psi. I was scared to fill the bags.
#19 |
Hard times Kustoms
Member ID: 69727
nick what brand is your tonneau ???
R.I.P my son€:ayden james woodbury
6-16-08-7-30-08 your time on earth was few and i'll be missing you *SIGNATURE REMOVED FOR BEING OVER SIZE LIMIT* |
#20 |
Pimpin' aint easy
Member ID: 34197
its a guidon? just some tonneau I got for 100 bucks..nothin special lol
| Advertisements |
| Thread Tools | |
| Display Modes | |
