08-09-2008, 07:45 PM
#61
Z71 Owner
Re: Fix Those Wipers (Wiper Board Repair)
Just want to say THANK YOU! My wipers have been going on and off for about 6 months now, and I never would have thought it was that easy to fix. I also admit to reaching out the window to move the wipers by hand, AND using Rain-X as a temporary fix. Hopefully now I no longer have to worry about heavy down pours and pulling off the side of the road.
Thanks Again!
08-12-2008, 03:38 PM
#62
Thanks a bunch. My 95 has been parking high. Just took all of 10 minutes to fix a burned trace. that was finding the solder gun and tools. Thanks a bunch.
09-11-2008, 06:31 PM
#63
been having intermittent problems for last 12 months with my '98 model silverado. would engage delay and hear buzzing behind the dash. a jiggle or two would get things working until next rainstorm, then repeat.
i removed circuit board and cleaned contacts, both coated with gear lube. no broken solder joints seen. replaced and all tested good. we will see this weekend. ike is coming. thanks to the forum.
12-02-2008, 03:33 PM
#64
i have the old body style suburban(1990) with the motor on the right side of the booster and i can't find the board.
12-08-2008, 05:17 PM
#65
ITS CAVALRY NOT CALVARY!!
different animal bud. This would help you if you had a 92 or newer.
1987 V3500 "WT", 93 GMrolet K1500, 67 Bronco Sport, 66 Bronco Roadster
02-25-2009, 03:28 PM
#66
98bluek1500
i have a 98 gmc , does my truck fall into the recall category?
 (thanks to lukej6009 for sig)
04-17-2009, 11:10 AM
#67
Hungry...
I have an '04 Tahoe.... my wipers won't stop once I start them! Well, not until I shut the damn truck off anyway.
Is this part of the same problem?
Thanks...
08-23-2009, 08:24 PM
#68
Life Is Good
hey guys, i pulled my circuit board this afternoon and checked all the joints. they all looked fine. i got a couple of que tips and cleaned all the joints that had dirt on them but didn't know what else to do. my wipers are still not working properly. any other ideas?
1998 z71, 5.7L 350, 4wd- 6k HIDs
09-13-2009, 04:58 PM
#69
Member
Ever since i bought my 96 GMC, the wipers worked off and on... i always had high speed mode, but when it acted up, i had no low speed, no squirters, just high speed. Thanks to this board, and this thread, i decided to go pick up a new board for 30 bucks. My soldering iron was at work, and its raining here, so i didnt want to wait. Anyway, all seems to be working good now! Crossing my fingers it stays that way! Thanks guys!
Current vehicles:
08 Lexus IS250 - FSport.
10 Toyota Sienna Limited - Wife's.
96 GMC Sierra Z71 - Lift, Nav, Etc.
Sold Vehicles:
93 GMC Sierra Z71 - Lift, Etc.
87 Chevy V10 - Lift, Stereo, Etc.
99 Camaro SS - 600+rwhp, low 10's.
95 BMW M3 - Lots of mods.
98 Lexus GS400 - Lots of mods.
09-30-2009, 12:59 PM
#70
Thanks...
My 99 Suburban does this. no washer either. I didn't find any loose joints... I will look again. I will also try the ground wire.
10-12-2009, 04:54 PM
#71
You just saved me $30! Thank you!!!
10-12-2009, 04:56 PM
#72
I didn't see any loose joints at all on mine, but I cleaned out as much of the old solder as possible with some solder wick from radio shack, and resoldered everything back in. I did all of the big pins, and a few small pins. Again, nothing looked loose or cracked, but that is what I did, and now they work perfect! Maybe it's worth a try!
10-12-2009, 06:22 PM
#73
Yup! re did the big solder joints and all is working now, Even the washers.
Thanks!
10-19-2009, 04:25 PM
#74
ECSB build up in progress
thanks guys fixed mine this morning!
need a sig
| Thread Tools |
| Display Modes |
Linear Mode
