05-09-2006, 10:52 PM
#61
Crazy Motha Trucka
Re: Installing factory fog lights, '04 silverado
i know i would get the grey one but i want it to look stock, do you have to run a wire from the switch or no?
05-09-2006, 11:05 PM
#62
Specify you want the '06 airdam when you order, it will fit your truck and is black like you want. The wiring for the switch is already there. You'll have to run the harness in the kit from the airdam to the fuse box under the hood.
05-09-2006, 11:08 PM
#63
Crazy Motha Trucka
ok who would i order it from that would be cheap?
05-10-2006, 05:05 PM
#64
I'd try Mark.
http://www.fullsizechevy.com/forums/...d.php?t=205586
09-19-2006, 09:27 PM
#65
ok i have a question it might be a crazy one. but i have an 04 Chevy silverdo and im wanting to put on fog lights. factory preferred what im having problems with is just getting the wiring harness. i have the lights and the switch itself. but im getting told from a whole bunch of people. that i would have to buy a brand new engine wiring harness so i could buy the kit to make the fog lights connect. or i would have to buy a whole brand new front end lighting harness that would include for the headlights and fog lights.
but im wondering how do you hook up the factory fog lights isnt it just runned to the fuse box itself. and then runned to the switch not having to hook up with the headlight system. i really would appreciate some advice for i do anything. dont want to make the wrong move and get screwed
09-19-2006, 09:32 PM
#66
Originally Posted by Colby 04
what if the truck already has fog harness' hanging? My neighbor has a 2004 that didn't come equipped with factory fogs, but I'm trying to get him set up. His truck already has the harness hanging for the lights, but no switch - not sure if he has the fog relay, can we just install the lights and switch and have the BCM reprogrammed(if needed)? The harness that comes in that kit, I assume it is running down to the fogs for power?
hey colby, you saying you have the kit for the fog lights but you already have the wiring harness. installed in your truck. when you bought the truck. what all came with the kit that you got? just out of curiousity.
09-19-2006, 09:33 PM
#67
I think i have a brand new harness in my garage, when i did mine all the wires were already there.
You may have the wires already there too...have you checked?
'02 GMC Sierra 2500HD 4x4 Crue Cab 6.0 4.10s 3" PA BL
Trenz billet '05 tails M/T Classic II's X-terrain 35's
Flowmaster duals K&N Wester's 93 tune...
09-19-2006, 10:09 PM
#68
yea ive checked and there not there. didnt come with the truck when i bought it.
09-20-2006, 08:27 AM
#69
The kit comes with lights, valance, switch, harness, relay and hardware pack.
Once it's all installed you may or may not need to have your BCM programmed at the dealer.
09-21-2006, 03:46 PM
#70
Supporting Member
I had to use the harness that came with the kit. There were no wires for the lights. The fuse was there, but not the relay. Relay came with the kit.
YMMV.
09-21-2006, 08:11 PM
#71
Originally Posted by Mark
12499673: List price on it is 225.00. I can sell it for 191.25. Thanks for the write up!
hey mark, do you know the part number for the limited tahoe fog lights? i need a set.
thanks
10-16-2006, 01:33 PM
#72
Tha Gangsta Crizzab!
Has anybody installed this kit on an 05-06 GMC? It looks like you have to cut holes in the airdam. An airdam doesn't come in the kit and the stock one is color matched. I'm just wondering if anybody has done it and can shed some light on the subject. Heck, even a copy of the installation instructions would be fine.
-Charles
2003 F-350 CCSB 6.0 Powerstroke
1991 C1500 RCSB 5.7
1984 Mustang LX
10-16-2006, 05:31 PM
#73
The GMC and Chevrolet front bumpers are not the same
EDIT: The actual fog light housing is different too.
'07 Sierra Denali - 6.2l L92, 6L80E, AWD w/3.42s, HPTuners, Innovate LM-1, Volant CAI, 160* t-stat, N-Fabs, 2.5" leveling kit and 285/65/18 Nitto TGs
10-18-2006, 08:09 AM
#74
I was referring to the GMC kit listed on page 1, PN 12498351. Sorry for the confusion.
-Charles
1991 C1500 RCSB 5.7
1984 Mustang LX
10-18-2006, 12:49 PM
#75
Charles,
I bought a kit off of Ebay for my 03 GMC Sierra WT. I did not buy the other lower bumper panel but just cut the openings in the stock panel. I used a razor knife and a cutoff wheel and it worked pretty good. I do have a mid-rise lift so I wan't exactly rolling around on the ground when i did it.
10-18-2006, 01:19 PM
#76
Wade, is the rough edge that is left from cutting out the openings visible when the foglights are installed?
-Charles
1991 C1500 RCSB 5.7
1984 Mustang LX
10-18-2006, 01:57 PM
#77
You say yours is color matched? It still has the endented area where the lights go, right?
Thinking back, I cleaned the edge up pretty good I guess. I may have used the heat gun to warm the plastic a bit to make it easier to cut with the razor knife. You wouldn't know it wasn't factory from more than 3 feet away. Mine is 2wd, so it's not right up in someone's line of sight.
10-18-2006, 03:12 PM
#78
Mine is indeed red like the body. Did the instructions specify that you were supposed to cut the foglight holes open, or did they suggest buying the correct airdam?
-Charles
1991 C1500 RCSB 5.7
1984 Mustang LX
10-19-2006, 09:22 AM
#79
The instructions that I got were for the mechanic to remove the bumper and cut the holes out.
10-19-2006, 03:38 PM
#80
I see. Well thanks for all the help Wade, it's much appreciated.
-Charles
1991 C1500 RCSB 5.7
1984 Mustang LX
| Thread Tools |
| Display Modes |
Linear Mode
