07-22-2006, 09:29 PM
#21
duramax
Re: Disable Your Daytime Running lights AND Auto Headlights OBS!!!
It works on all the OLD BODY STYLE STUFF... IE... PRE 2000
If some one wants to give me there 2001 NBS i can figure it out for you :)
07-23-2006, 02:46 AM
#22
poopsocked
I know on the S-10's and Sonoma's there is a button labeled "dome overide" on the dash. If you press it four times your DSL's will turn off. I figured with that the bigger trucks would have some sort of overide via a pattern of buttons pressed in the righr order.... if not the same thing
Originally Posted by Boarsheadburban
I'll bet you don't use condoms either, your'e a gambling man. right?
07-23-2006, 08:35 AM
#23
Learning
I have the dome override button on my '97 Tahoe and it doesn't seem to work that way. In my friend's 2001 blazer, yes it worked. But it doesn't seem to do it in my OBS Tahoe.
07-23-2006, 11:56 AM
#24
poopsocked
Ya, Iam sorry dude, i learned this from my mini trucker buddy(2002 s10) but I try to stay away from fuel injected stuff.
09-07-2006, 10:40 PM
#25
If you press the dome override four times in my 01 Silverado, the lights will go out, but you must do it every time you start the engine.
Willy
11-12-2006, 04:53 PM
#26
Since I installed my new HID's I wanted to be able to complete this task, Thanx for posting this great write-up
1998 GMC Sierra ECSB 1/2 ton
5.7 350 V-8 230hp
11-18-2006, 07:12 PM
#27
BITE ME
You could just do what I did and run your truck into a big ass rock
Had to replace the bumper but other than that no other damage.
The DTRL have not worked since though.
1996 ECSB Z71, DC Stage II, 4.56 Motive Gears, 315/75/R16 Mickey Thompson MTZs on 16x8 AR Chambers, Flowmaster 40 Series, K&N Intake, Hypertech Programmer, and enough time to put'em all togather
12-30-2006, 08:44 PM
#28
Under Construction
I was wondering if it was possible to disable the amber parking lights untill i need them for the blinker? If anyone could tell me know how to do this it would be greatly appreciated
09-06-2007, 02:02 AM
#29
Hey 99skalaid,thanks for the wright up and pictures,just did the 4-high upgrade and removed the DRL unit from under the dash all worked out just fine with the new grill and lights.. thanks again
see my gallery for how it turned out..
09-06-2007, 06:29 AM
#30
Gotta Love Chevy Power
Originally Posted by 1badgmc
But then instead of having the green DRL indicator on the dash you have the red e-brake indicator, beside the fact that you'd have to make a conscious effort to do it. I pulled the fuse and then pulled the indicator bulb and all it's all good.
Although, I still need to pull the indicator bulb, that thing is annoying.
DEAD***Red '97 K1500 - ECSB - 165k miles and counting - Rebuilt 5.7L V8 - True Duals - Bullets - 285/75R16 - Pretty much stock.
Sig By: AllBlkdOut07
Originally Posted by thekl0wn
"Quit pointin' that thing at me, and put some pants on!"
09-21-2007, 03:05 PM
#31
You might what to check if that is illegal or not, but all you have to do is cut one each of the bulb wires itself. I cant quite remember witch one it is off hand, but that will shut it off. You could also throw a switch in the loop and disable it that way, then the cops wont freak out when u drive it on the street.
1999 Tahoe.
NOW: 3" body lift, Edelbrock headers, true-dual 2.5" exhaust.
SOON: 33" F-C-II, New cam
09-21-2007, 11:11 PM
#32
Pulled fuse 15 on the dealer lot when I bought my 98 1500. Hate DRLs, so it was an easy decision for me. No automatic lights, so everything functions as it should.
10 years on the original headlights and happy with that fact and money savings :). The ironic thing is that green DRL light is still burning, I keep waiting for it to burn out (my radio lights have mostly) after driving nearly 200K miles, LOL.
Thanks for posting the info :).
Larry
09-25-2007, 03:40 PM
#33
Originally Posted by nova7163
I know in my 01 silverado all you have to if press the dome override button multiple times till you hear a few beaps and the lights go out
Do you do this with the vehicle in accessory? I followed the instructions from the manual on my '00 Hoe (New Body) and nothing works... ready to pull out my hair... everytime I hit a bump, one or both of my HID lights go out and I can't reset the lights by using the switch because of the auto light feature... any help is appreciated!!!!
10-12-2007, 07:36 AM
#34
wayne
i pulled the fuse on my 07 but they still came on .
what next ?
10-14-2007, 01:51 PM
#35
obsessive compulsive
Larry
No doubt. Can't see buttons at night. Some passengers ask me what that green light is, I tell them it's the law enforcement proximity indicator, as long as it's green I can exceed the speed limit.
10-14-2007, 02:01 PM
#36
In my 2001 the ignition has to be on. I press override 3 times to have manual control of headlights. Sometimes I like to run just the fog lights and parking lights only. Turning ignition off puts it back to factory (automatic) setting. Of course the key passes through OFF on the way to ACC.
Just curious...so you're driving along, hit a bump and light(s) go off. Have you tried override right then and turning headlight switch on? Do you have switch on to begin with or let auto sensor turn on lights when dark?
BTW my 2001's DRLs are not the headlights, some other light underneath, haven't cared enough to figure out if they're also the turn signals or parking lamps.
07-11-2008, 09:39 PM
#37
Originally Posted by 99SKALAID
TTT anyone else do this
About ten seconds after I found this thread
Sig pic done by 454ss
99 GMC Yukon 350 on hydrogen 4L60E NP 241 4x4 3.73 gears, superchips power programmer, Devino wheels on 32's, 21 mpg's no joke.
07-12-2008, 01:00 PM
#38
duramax
awesome. :)
just did it in my 2dr 2wd tahoe i picked up too :)
08-16-2008, 01:00 AM
#39
What year tahoe do you have? My 97 has a relay under the dash in the fuse panel. I was going to jumper across and then pull the fuse. When the relay is unenergized it puts power from the DRL module to the headlights. When its energized the headlight switch powers the headlights. All this could have been replaced by running the headlights off the ignition switch.
Just waiting for my ADHD to lead me to actually do it.
97 Tahoe 1500 4x4
35x12.5R15
RCD 6" kit
09-11-2008, 04:06 PM
#40
lol sorry im a newb but where is fuse 15???? I cant find it! All i see is like 10 20 30 40 and 50? I am ready to get an answer that is gonna make me look really stupid!
| Thread Tools |
| Display Modes |
Linear Mode
