01-22-2007, 05:46 AM
#241
House on the HILL!
Re: disc brake swap
Originally Posted by 99gixxer
I finally got around to doing this last week. Im glad someone found out how to do this because I had been wanting to, but not for $500-$700 like most kits ive seen.
This mod was worth every penny! The only complaint I have is the rotor needs to be slightly bigger to get full contact on the s10 pads. I still might look into a proportioning valve. The rear doesnt lock up but id like for the front to do about 60% of the braking, I think right now the front & rear are each doing 50%.
Looks good!  Keep us updated on how it works out after some miles on it.
01-22-2007, 12:03 PM
#242
Re: disc brake swap
man i almost forgot about this thread, keep up the good work, and yes this thread does need a certified parts list. e-brake, and no e-brake. i know what to get but the other nuckle heads are havin problems. thanks man
01-22-2007, 08:15 PM
#243
AfterHours Kustoms
Re: disc brake swap
Thanks for the compliments. Its been about 10 days since ive done the mod & I drive the truck daily. Still works great! Ive been keeping an eye on them & everything seems fine.
I dont even think there is a need for a proportioning valve anymore since it all started to loosen up. For the first day or so the pads would slightly drag the rotors after you let off the brake. I guess since everything has had a chance to wear together, everything is good. The calipers float very smoothly on the slider bolts now without feeling sticky.
Parts list:
Speedway brackets & slider bolts - $40
94-96 Impala SS rear rotors - $67 (pair)
s10 brake pads - $30
used 98 s10 calipers, lines & banjo bolts - free
I didnt need to pull out the axle shafts, I just cut the plate off the axle that held all the old drum pads & springs. The only thing you really need to modify are the brackets need to be beveled a little, like the diagrams in earlier posts. Then you either weld on the bracket or drill 2 holes in each to bolt it on. Also dont forget to drill the holes to 9/16 in the rotors.
What took the longest was grinding the bracket, test fitting, grinding, testing, etc. Then fitting everything together 3 or 4 times until i was satisfied all was good. Very easy!
01-23-2007, 04:18 PM
#244
Re: disc brake swap
whats the best bolt on bracket to use do you guys think? i dont want to weld it on and i would like to use more then 2 bolts.
 -TireFryr-v8TPI-212-218,110-1.52rollers-Fully Ported aftermarket TPI setup,52mm TB,Coated LTs,Built 700r4,2800Yenk stall,Hurst v-matic2,3.73posi "TractionLess"  GoleET:13s Best 14.6-93mph 1.87-60' YenkoST is my Tunner!!
01-23-2007, 08:36 PM
#245
SWBLS12B
Re: disc brake swap
I think the kore3 brackets are the only ones that use all four.
They are the only ones that I have seen anyways.
88 Ext. cab longbed TPI 350
99 Suburban LS Vortec 350
90 SWB Silverado 5.3l and 4l60e 4 sale will part out
01-23-2007, 11:54 PM
#246
Re: disc brake swap
looks like most guys here have 1990+yr trucks with this conversion. will the kore3 brackets work for an '86 c10? 5 lug, 10 bolt. kore3 site lists them for 88-00. anything for older fits that are listed seem to be for cars or s10.
almost forgot...i need brackets that can bolt on without machining or grinding.
01-24-2007, 01:59 AM
#247
Designated Smart Ass
Re: disc brake swap
NO. The axle flange on the 73-87 is different than what is found on the 88+. You might be able to make them fit but you would have to drill new holes in the Kore Brackets.
01-24-2007, 03:09 AM
#248
Re: disc brake swap
thanks.
is there a bracket that will work? i'm planning to start working on my truck this week and the rear brakes pretty much need complete rebuild...wheel cylinders, drums, shoes, springs/hardware..i figure if i'm gonna spend $300 i might as well switch to disc
i just found this site. don't recall seeing it in this thread.
http://www.tsmmfg.com/2540.htm
01-24-2007, 10:49 AM
#249
Re: disc brake swap
you could go the speedway bracket route and drill them to fit your axle flange or have them welded on or you could buy just the brackets from a company like streetrod manufacturing company for your truck. or you can go here and make your own brackets like this guy did:
http://www.73-87.com/7387garage/chas...n/reardisc.htm
hope this helps. the main thing to do when doing the rear disc brakes is do your hw first. have all the parts, dont try to cut corners, and do it right the first time.
01-24-2007, 06:59 PM
#250
Re: disc brake swap
I happen to have a set of ImpalaSS backing plates and caliper brackets. I bought them years ago thinking of doing a disc swap on another car.
Do you guys thing I could bolt everything using these instead of the Speedway brackets?
Then of course I would use ImpSS rotors/calipers/pads as well.
CD Smalley
Wichita, KS
1991 W41 #142
1995 Astro
1986 Caprice
1997 C1500
1977-90 GM B-Body email list Owner @ yahoogroups.com
"No sacrifice or service of mine requires any other reward than that which conscience gives to every man who does his duty" - Joshua Lawrence Chamberlain
01-28-2007, 08:39 PM
#251
Re: disc brake swap
thanks for the info. from the looks of that guy's set-up i may just order the kit from classic parts to avoid the fabrication process since it might be too expensive, no tools or 'hook-up'. i'll keep looking. hopefully i'll find something reasonable soon.
02-04-2007, 11:19 AM
#252
Re: disc brake swap
Hey guys, my name is Mike.I just registered on the site, and wanted to introduce myself. Looks like a great site, with tons of invaluable info on our trucks.I can't wait to do this brake swap on mine.I still have to get a little more info on the rear, before I order anything.I'm planning to use the Moser 12 bolt, just need to get ahold of them and make sure everything will be the same.What rear end ratios are you guys running?I think I'm going with a 3.42:1.Anyway thanks for posting this stuff, it's been a big help. Oh, and has anyone figured out what to do about a backing plate yet?
02-05-2007, 11:44 AM
#253
Ding Fries Are Done!
Re: disc brake swap
Thought I'd let you guys know that I found a bracket with 4 holes which is what most of the high end kits that I've seen have used. They're $95 shipped. Here's the link:
4-Hole Bracket
I knew this one guy who bought a used car once. 10 years later...... BAM! Herpes. True story.
02-05-2007, 02:33 PM
#254
Re: disc brake swap
And what about this part number will these calipers work?
18060134
Click here to see them
02-05-2007, 08:13 PM
#255
Re: disc brake swap
i was talking with a friend yesterday. he said swapping the rear-end out with one from a camaro with discs should work on my 86. Is that true/possible? i didn't see that option mentioned in this thread.
02-05-2007, 09:08 PM
#256
Re: disc brake swap
I just wonder about the comments about the Cadillac rear calipers needing to have the parking brake set every time. Was this required on these cars from the factory? If so then I don't think it would have been very popular to consumers in my opinion!
1981 Blazer K5 2WD w/Full Convertible Top- Just complete LS-1/4L60E Swap
02-05-2007, 11:36 PM
#257
Re: disc brake swap
4-Hole Bracket
just an fyi for the pre-88 owners out there...
kingtek response to request for 86 bracket:
"A bracket kit is in the works, but it will
most likely be 2-3 months before I have anything for
sale."
edit:
sorry to keep dragging this on but i'm not really in the mood to wait for the pre-88 brackets. what if i hit up the salvage yard for a 88 rear and swap it out on my 86? possible? things to consider?
02-06-2007, 12:09 AM
#258
Re: disc brake swap
ok so im gettin ready to finally order the parts for my rear setup but have few final qs...im goin to run the caddy calipers not the s10 ones, what will i need to do so my stock brake likes work and fit with the caddy calipers? this is the parts list im goin to get....am i missin anything?
http://www.performancecenter.com/pro...et/1995/Impala
http://www.kore3.com/proddetail.php?prod=10097
http://tsmmfg.com/cable_housing_spacer.htm
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=013
also does anyone know anythin more about usin the e-brake calipers with the 3/4" rotors vs the 1" rotors....anyone have any problems....how does the e-brake work? if theres any problems i will just use some s-10 calipers
02-06-2007, 05:06 AM
#259
House on the HILL!
Re: disc brake swap
Your friend is VERY wrong......
1. the rear is completely different, mounts, spring perches and width.
2. The bolt pattern is 5 on 4.75, not 5 on 5 like your truck has.
02-06-2007, 07:31 AM
#260
Re: disc brake swap
You need a rubber or stainless flex hose and either get a new brake line or cut the old one and use a double flaring tool to flare the ends.
| Thread Tools |
| Display Modes |
Linear Mode
