09-02-2008, 03:55 PM
#401
Ohh yeahh Megasquirt !
Re: disc brake swap
Placed an order for a pair of Kore3 brackets today , rotors arrived this morning and since then I had em' both opened up to 9/16 . As soon as I score my brackets I'll post some pics !
1988 Chevy
Scottsdale
09-02-2008, 07:07 PM
#402
Officially "Un-stroked"
Re: disc brake swap
Has anyone done the swap on a Dually that they use for heavy towing?
There's no doubt disc brakes are better than drums, but the drums on this truck are pretty massive and I'd rather not spend the money for discs if I'm going the wrong way, you know?
I was thinking about it, and fuel trucks and other semi's still use drum brakes, so there has to be a reason, right?
'91 C1500 with a 350 Vortec engine, Compcams 08-501-8 roller camshaft, Thorley headers, Holley 770 carb, Edelbrock Air Gap manifold, K&N X-Stream, and quickly balding rear tires
'99 K2500 crew cab, Whipple Charger, Westers Tune, 9" lift, 35's with Weld wheels, and DVD system
09-03-2008, 01:31 AM
#403
Re: disc brake swap
Since I ran into the problem of installation due to my truck having 11-inch drum brake and large axle flange (GM Pro-Code Z56), I have to sale the brackets.
See the llink:
http://www.fullsizechevy.com/forums/...-pictures.html
09-10-2008, 01:46 PM
#404
Re: disc brake swap
Okay, Got the brackets this morning and I'm in the middle of deciding how to place the brackets , it looks like it'll be easier to bleed if I mount the caliper on the bottom of the rotor towards the rear bumper . is this how everyone else is mounting them ? does it matter where on the rotor the caliper clamps the pads at ? or as long as it's bolted to the axle it don't matter where you mount it at .
I'm using the 85 caddi calipers & kore3 brackets
1988 Chevy
Scottsdale
09-10-2008, 08:36 PM
#405
Designated Smart Ass
Re: disc brake swap
Pre-stroker...bigger trucks still use drums b/c they have more surface area to slow the vehicle down and dissipate heat much better than a disc brake would when used with consistent heavy towing.
09-10-2008, 08:53 PM
#406
Re: disc brake swap
finished the swap but I now have a Lower than normal pedal (who dosen't have alow pedal in their Chevy) stops nice n straight with no hint of fade , but it's lower than before I started .
I'm using 2500 series front calipers (larger piston Vs the 1500's) and 85 caddi rear calipers , I did some searching and came up with Gm PN# 18038499 for a 1-1/8 MC . Will this help with my low pedal issue ?
1988 Chevy
Scottsdale
09-13-2008, 02:10 PM
#407
USMC
Re: disc brake swap
anybody know where i can get the ebrake brackets for the caddi calipers? i ordered brand new loaded rears and they didnt come w/ the bracket for the cable and i cant find it anywhere. autozone, advanced, even the junkyard didnt have them. ive tried ebay and google and i cant find them. i cant do my swap until i get these brackets and its driving me insane.
91 z71 stepside
3" ory/si/so magnaflow
s&b intake
285/75/16
09-13-2008, 08:55 PM
#408
Re: disc brake swap
Check Doorman. If you need help, contact NavyLifer, Bill Harper, he is a absolute guru in this arena. Shoot him a email (might take a few times, I don't have his current email, but look for him on ImpalaSSforum.com)
94 Cadillac Fleetwood Brougham w/RPO V4P
00 Buick Park Avenue Ultra SC 3800
99 K2500 Suburban 454, Tuned by Me!
09-13-2008, 08:56 PM
#409
Re: disc brake swap
I got my kit for my 14b SF. Are the rotors supposed to slip over the lugs from the outside or are you supposed to pound out the studs and install the rotors from the inside?
09-13-2008, 08:57 PM
#410
Re: disc brake swap
Not sure if I follow, I have only seen rotors go on over the lugs. Can you post a pic of what you mean?
09-13-2008, 09:16 PM
#411
Re: disc brake swap
Well, I had to put it back together so I don't have pics. The rotor does not fit over the lugs in my application. I thought that maybe I have the wrong rotors, but everyone says the rotors from an '85 chevy should work. On these rotors, there are tabs that connect the mounting surface to the friction surface. These tabs hit the round part of the axles that the lugs go through. They don't just hit it a little either. Of course, after I put it back together, I realize that maybe the rotors were supposed to attach on the back of the axle, and the head of the studs would hold the rotor on. Am I making any sense?
09-13-2008, 10:34 PM
#412
Re: disc brake swap
it worked great on my '90 c1500. speedway brackets, '96 impala ss rotors drilled to 9/16" and '91 s10 calipers....
09-14-2008, 01:26 AM
#413
USMC
Re: disc brake swap
dorman didnt have anything. hopefully tomorrow i can call a few other junkyards and see if they can help me out.
91 z71 stepside
s&b intake
285/75/16
09-14-2008, 11:15 AM
#414
Re: disc brake swap
I pulled it apart again this morning to move the rotors to the inside of the axle flange. Still a no go, but for a different reason. To do this, you have to press out the studs from the axle. When I went to reassemble, the knurled part of the stud no longer reaches the axle, and the hole in the rotor is too large to hold them. This would make it impossible to bolt the wheels on because the studs fall through.
09-14-2008, 04:22 PM
#415
Re: disc brake swap
the rotor should slip over the axles like the wheels do .
if you used 94-96 impalla rotors you'll have to clearance the I/D of the rotors to account for a small Lip on the axle flange .
1988 Chevy
Scottsdale
09-14-2008, 09:11 PM
#416
Re: disc brake swap
I think we're working with different rearends. I don't think they ever put a 14bolt SF in an Impala. That's my problem, it doesn't look like anyone here has done this swap to a 14b SF; just smaller rearends and 14b full-floating.
09-16-2008, 03:52 PM
#417
Re: disc brake swap
Yeah .... Your on yer own Dude. Good luck tho..
1988 Chevy
Scottsdale
09-16-2008, 10:39 PM
#418
Re: disc brake swap
I think I got it figured out but the true test will be this weekend when I can tackle it again. Rotor on the inside of the axle and I bought longer studs. The studs are a full inch longer than stock, which is fine because I don't like that the stock ones in the rear don't have as many threads as the front studs. Unfortunately I'll have to use some spacers though because the studs aren't threaded down quite enough and my lug nuts bottom out.
I sure hope this swap is worth it! What a headache!
09-21-2008, 06:20 PM
#419
Re: disc brake swap
I got the swap done and I am not impressed. The brakes don't stop any better than they did before with the drums on it. I don't know what the deal is, so maybe I have a problem elsewhere. The entire reason I did this swap was because the truck does not want to stop. I've already upgraded to stainless lines, new calipers (one was sticking), performance brake pads, new rotors, and now the new rear disc conversion. The truck is a 4x4 with 35's, but it should still be able to stop better than it does now.
09-21-2008, 11:13 PM
#420
Re: disc brake swap
You might need some brake bias tweaking. But the big reason I am not the rush to do discs in back is the fronts do most of the work on a hard stop, so with the puny 11" in front on the 1500's, smaller on some, add some larger front discs and it will have a phenomenal braking improvement combined with those rears.
My plans are to always upgrade fronts first, rears second. But not always able to on a lot of rides either.
| Thread Tools |
| Display Modes |
Linear Mode
