Go Back   FSC Forum > General Discussion > Tech Articles Two
Old 10-01-2008, 02:44 PM   #421
Re: disc brake swap
Hey I Got An 06 1500 I Bent My Rear End And Have The Option Of Getting My Friends Rear End Its Off An 04 But It Has Discs I Was Wondering What I Need To Do To My Brake System To Do This Thanx
chevell27 is offline
Old 10-01-2008, 02:58 PM   #422
Re: disc brake swap
Yup, might need to remove the residual pressure valves in your master cyl if they put those in these days.
94 Cadillac Fleetwood Brougham w/RPO V4P
00 Buick Park Avenue Ultra SC 3800
99 K2500 Suburban 454, Tuned by Me!
N0DIH is offline
Old 10-21-2008, 04:31 PM   #423
Ohh yeahh Megasquirt !
Re: disc brake swap
anyone got a link or to where you can buy 86 caddi caliper parts ? like the e-brake ratchet mechanism ?
1988 Chevy
Scottsdale
16vconversion is offline
Old 10-21-2008, 05:12 PM   #424
Re: disc brake swap
FWD or RWD? RWD, there are none, they weren't doing discs anymore in RWD then. FWD was.
I have the 76-78 E-Body (Eldo, big car) backing plates and calipers (probably need rebuilt), which are a bolt on for the car 10 bolt axles (and likely for trucks too with some minor mods around the wheel bearing). These are similar, just a little more HD than the 79-81 F-Body backing plates.
Make me an offer, I don't plan on using them.
N0DIH is offline
Old 10-22-2008, 12:28 PM   #425
USMC
91k4x4's Avatar
Re: disc brake swap
i had to find mine on ebay, and even then it took me like a month to get that lucky. if you find a reliable source im sure it would be a nice find.
91 z71 stepside
3" ory/si/so magnaflow
s&b intake
285/75/16
91k4x4 is offline
Old 10-22-2008, 01:23 PM   #426
Re: disc brake swap
What did you find? 86 no RWD cads had discs. They all had 11" x 2" drums.
N0DIH is offline
Old 10-22-2008, 05:25 PM   #427
USMC
91k4x4's Avatar
Re: disc brake swap
my bad i miss read. i thought u said 85.
91 z71 stepside
s&b intake
285/75/16
91k4x4 is offline
Old 10-22-2008, 10:04 PM   #428
Re: disc brake swap
Still not sure what you are looking for calipers for, GM stopped the rear disc setup on the Cadillacs (RWD) in the 1979 model year. If you are finding calipers, you are getting them from a FWD car like an Eldo/Rivi/Toro, which by the way, ARE the same ones used on the 79-81 Firebirds with the disc brake option.
In comparisson, the 76-79 B/D body rear discs are 5x5 drilled rotors with a larger caliper (more like a front caliper size wise) and beefier backing plates. I wouldn't use the 79-85 stuff, but it is for sure easier to find.
N0DIH is offline
Old 10-26-2008, 08:41 AM   #429
Re: disc brake swap
I'm biting the bullet today and getting a re-man'd L/R caliper. I'm tired of pumping the brakes so the l/r caliper piston extends all the way. doing the e-brake ratchet thing don't work on the one I have.
1988 Chevy
Scottsdale
Old 10-28-2008, 11:16 AM   #430
STLowburban's Avatar
Re: disc brake swap
I just got the new Speedway catalog and they have new 78 and up GM metric calipers w e-brake for $99 bucks each. Anybody used these? Thats cheaper than th caddy's new I think. Just FYI.
I'm not superstitious, but why take the chance.
STLowburban is offline
Old 10-28-2008, 12:01 PM   #431
Re: disc brake swap
Here's a good link I found. This guy makes kits pretty cheap for all years.
http://www.blackbirdscustomtrucks.com/
Old 11-01-2008, 03:31 AM   #432
Re: disc brake swap
so if I read this right, I can get the Kore3 brackets, then i just ned to find calipers and 6-lug rotors? anybody done this on a 4wd with 6-lug wheels yet? I'd like to convert my drums to discs using off the shelf parts. I'm thinking I just need rotors from say, a 2002-04 chevy truck, and calipers from the same truck? or do I need Caddy calipers? shed some light on this for me please.
Helomedic1171 is offline
Old 12-19-2008, 09:22 PM   #433
Re: disc brake swap
This is the best place I've found. If they are posted already sorry, didn't read back through the whole post. They have all the brackets, calipers, drive shaft e-brakes, and great info.
http://www.tsmmfg.com/
Old 03-14-2009, 05:01 PM   #434
www.dfwminis.com
Re: disc brake swap
Has anyone dealt with the King Tek Performance kit on Ebay? Comes with all the parts to do a 88-98 1500 disc swap for $480. $600 with matching front rotors drilled and slotted.
Featured in STREETTRUCKS June 07
dimebagged is offline
Old 04-01-2009, 08:15 AM   #435
Re: disc brake swap
I bought the King Tek brackets off ebay & pieced the other parts. The brackets bolted right on. The cadi calipers are just a shade off, they aren't mounted quite deep enough. I have everything fitted. But I haven't bolted on the rear-end yet. BTW I have a 92 2wd and swapping in a 92 4wd rear (6-lug). I used the 87-89? (don't remember the year) 4wd front rotors. Read back thru the thread for the correct year if you have a 6-lug rear. 5-lug I think you will use an impala ss rotor. Good Luck!
92 chevy 1/2 ton extended cab, 350 swapped-in edlebrock fuel injection
92chevyblue is offline
Old 04-21-2009, 03:10 PM   #436
Supporting Member
94383Z71's Avatar
Re: disc brake swap
yes, I believe he says within the first 5 pages that if you're in need of a 6 lug disc setup, use the front setup off your model. I think. Because thats what I came in looking for haha
Parts, Dmax Rebuild
94383Z71 is offline
Old 07-02-2009, 05:53 PM   #437
Re: disc brake swap
So i have been tryin to read all of this but i have not seen anything that answers all of my questions. I have a 6 lug 14bolt that i am installing in my 1990 1/2 ton. also have a set of extra front calipers, pads and rotors from my 90. can i use the backing plate off of the rear of an 02 or 03 model 10 bolt to mount the calipers? or is the kore3 large enough to mount my calipers. i read that it mounts gm small calipers, not sure if this is considered small or not.
hoggy is offline
Old 07-02-2009, 07:41 PM   #438
Heslekrants's Avatar
Re: disc brake swap
Your 90 front calipers will not work with the backing plates from an 02-03 10 bolt rear disc. The calipers are way different.
The factory 10 bolt rear disc setup comes in 2 flavors.
1) Single piston caliper & 12.8" rotor.
2) Dual piston caliper & 13" rotor.
1999 K1500-Int balanced 383, 10:1 pistons,534 lift cam,6"rods,alum heads,1.6RR,welded alum vc,LT4 knock module,MPFI conv,HD built tranny,custom ECM,headers,Flowmaster SUV50,highflow cats,drilled/slotted rotors,HID headlight,LED running lights,305-50-20 tires.14Bolt SF 4.10 gears & 13"rear disc
Heslekrants is offline
Old 07-03-2009, 12:51 PM   #439
Ride-Race-Live
Re: disc brake swap
thanks. and the backing plate from the 10 bolt will be a direct bolt onto the 14 bolt i have?
BRAPP is offline
Old 07-03-2009, 12:52 PM   #440
Ride-Race-Live
Re: disc brake swap
is there any backing plate from another model that i can use to mount the calipers from my 90?
BRAPP is offline
