10-28-2006, 07:59 PM
Drive and Enjoy.
disc brake swap
truly, I dont know why more people dont do this. I did it in about an hour and a half, all bolt on with parts available over any parts counter. Total cost = $300 including calipers, rotors, brakes, ebrake lines, and brake lines. And the caddy calipers allowed me to keep my e-brake. Everything needs a good cleaning, but here are the mock-up pics.
10-28-2006, 09:09 PM
#2
Project Neverending
Re: disc brake swap
How bout you post up a parts list then man!?
One Nine Seven Eight
10-28-2006, 10:18 PM
#3
Drive and Enjoy.
Re: disc brake swap
caddy calipers, rotors with a 5x5 pattern, speedway motors brackets.
10-28-2006, 10:40 PM
#4
Blah, Blah, Blah!!
Re: disc brake swap
Would the same work for my 6 lug? I've been wanting to do this for a while now.
"Turbo lag is my way of giving v8's a chance"
99 K2500 Silverado 454 QCSB ~ Daily Grunt
91 Nissan TTZ ~ Weekend Boost
10-28-2006, 10:47 PM
#5
- Luke
Re: disc brake swap
 I gotta get the stuff to set up the disc brakes on my 14ff, gotta get the expensive ass front brakes too.
2001 rcsb Z71 06 clip, lowered, 6.0 LQ9, p&p 241s, cam, PI3600, LPP long tubes, etc. Tuned by TJ of Baker Engineering Inc - SOLD
1989 rcsb 4x4 5.7 Turtle Body Injection - Runs 10s on desktop dyno
10-28-2006, 10:57 PM
#6
Drive and Enjoy.
Re: disc brake swap
yeah.. you could.. it would actually be easier. I really got lucky with my setup. As far as i know, im the first one to do it on a 2wd with the speedway brackets and caddy calipers, but everything fit like it was made to be there.
10-28-2006, 11:02 PM
#7
OVER8TD
Re: disc brake swap
Which brackets did you buy?? looked through the site, couldn't see anything for our trucks.
1994 K1500
9" lift
37" Pro Comps
10-28-2006, 11:10 PM
#8
Drive and Enjoy.
Re: disc brake swap
what brackets you buy depends on the calipers you want. the are both there... I bought the weld on ones.. but i made them bolt on :)
10-29-2006, 01:41 AM
#9
Guest
Re: disc brake swap
looks slick, nice mod
on a side note
I got a sh*tty blueprint of the bracket to put disk brakes on a dana 60....I think its a dana 60 i need to check but maby i could help someone out if they want it?
10-29-2006, 02:10 AM
#10
vato
Re: disc brake swap
nice ..got lot of questions ... any caddy will fit ? or theres a special model to look for ? .. the rotors you are using are the ones of the caddy?. they fit 15" wheels ? do you think is necessary to add a proportioning valve to make them work better ? how much for just the brackets ?
Cheyenne '81 sidestep, yellow, 5.7L
Silverado '88 sidestep, gold, 5.7L
Cheyenne '90 sidestep, brown, 4.3L
10-29-2006, 06:52 AM
#11
Drive and Enjoy.
Re: disc brake swap
I think the calipers are from a 79-85 caddy seville. I got them because of the mechanical E-brake, I wanted an E-brake back this time around. you can use S-10 or other GM calipers if you dont care about the e-brake.
I am using modified impala SS rotors, I dont know if they fit 15" wheels, but I can tell ya in about an hour.
Not so sure on the proportioning valve quite yet, as my truck is in shambles, but im going to do what i have to, to make them work.
and the brackets were $10 each, and fit perfect... which is suprising for a speedway motors product.
hardest part of the swap was tearing in to the rear end to get the axleshafts out. it was super easy in hindsight, but it was my first time tearing into a rear end. Just remember that the pinion shaft holds two spider gears in, and the axlehsafts hold the others, and you will be alright.
10-29-2006, 07:13 AM
#12
under the knife since 95
Re: disc brake swap
Are these the brackets you used? http://www.speedwaymotors.com/xq/asp...qx/Product.htm I need to change my rear axle seals anyways so I might as well do this mod while I have everything broke down.
10-29-2006, 07:27 AM
#13
Re: disc brake swap
Hey Man,
Got a parts list for the 14 bolt? Mine is a SF, so im sure stuff is a little different between our two setups.
Originally Posted by LOWGREEN1
LowGreen,
It most definately isnt the bracket that is shown there, they look quite different.
Someone else was selling them on ebay a year back or so, gold anodized finish too. :thumbsup:
10-29-2006, 07:30 AM
#14
Re: disc brake swap
Originally Posted by 1BadZ71Tahoe
LowGreen,
That's what I thought but I couldn't find them on Speedways site. I am looking on Ebay as I type this trying to find this conversion kit/brackets.
10-29-2006, 08:51 AM
#15
Drive and Enjoy.
Re: disc brake swap
Lowgreen, this is the bracket i used http://www.speedwaymotors.com/xq/asp...qx/Product.htm... you drill two holes and bolt it to the flange. with impala SS rotors it works perfect. You do however, have to machine out the holes for the lugs on the impala rotors. the lug pattern is correct, but the holes need to be enlargened to the same size as the studs.
and btw everyone, 15's fit!... im pretty pumped, because now i can carry one of my 15" spares with me and be fine.
excuse the rust... caliper needs cleaning and its my 15" steelie... just to show clearance.
if there is enough interest, I can write a how-to, and take pics when i disassemble it again.
10-29-2006, 09:07 AM
#16
Re: disc brake swap
Thanks. I believe there would be enough intreset in a write up. I would include all the info you have. What rotors, what calipers, brake line, what you had to do to get them to work...ect..
10-29-2006, 09:32 AM
#17
Guest
Re: disc brake swap
oh that would be bad ass, make it all detailed with every part number for everything and pictures of everything! Yea do a write up i think it would help out alot of people and be worth your time!
10-29-2006, 09:58 AM
#18
Xcentric Customs
Re: disc brake swap
DO IT. Soon as you do it, i'll convert. I've been wanting to do this for a couple years
10-29-2006, 10:09 AM
#19
Blah, Blah, Blah!!
Re: disc brake swap
Since I'm six lug can't I just get the whole ste up of a NBS or would I be better just getting the whole axle too?
10-29-2006, 10:19 AM
#20
not low enough
Re: disc brake swap
hey maybe u can help me. if i get a complete 10bolt with disks off a caprice or something, and get the ebrake bracket,will i just have to modify my brakelines to hook up to the calipers?
project SS
| Thread Tools |
| Display Modes |
Linear Mode
