Go Back   FSC Forum > General Discussion > Tech Articles Two
Old 04-27-2008, 12:42 PM   #81
knows nothing, needs help
xAustin's Avatar
Re: Cheap way to shave a NBS antenna!
did this today myself, didnt use a bracket or zip ties. easiest/cheapest mod i've ever done that makes a big difference..Thanks!
02 5.3 silverado
xAustin is offline
Old 06-14-2008, 06:13 PM   #82
Harley
Crazed179's Avatar
thanks for the writeup and part number. I hated that antenna. simple and adds that subtle touch.
"Too much of anything can make you an addict" - Xzibit
BUILD THREAD --- http://www.fullsizechevy.com/forums/...1-ext-cab.html
MYSPACE --- www.myspace.com/blkoutslvrdo
Crazed179 is offline
Old 08-06-2008, 02:13 PM   #83
Munchin 24-7
Silv3rado Own3r's Avatar
you think the part number would be the same for 08?
Silv3rado Own3r is offline
Old 08-06-2008, 05:46 PM   #84
Honorary Mythbuster
neonhomer's Avatar
I would imagine there is a different part # for an 08. Go look at an 08 esky and see if it has the same panel, and then order for that vehicle... or see if they have a panel for a "radio delete" truck.
NeonHomer
2004 Chevy Silverado 1500 2WD Ext. Cab 5.3L/4spd
1994 Dodge Caravan 3.0L/4spd
2004 Harley-Davidson Road King Police FLHP/I
neonhomer is offline
Old 08-07-2008, 06:09 AM   #85
GMAN12's Avatar
I did mine a couple of weeks ago, just used 3 zip ties, and used black dum dum in cover hole. I lost some am recept, but don't use am very much. FM is pretty much the same, I guess it just depends on where you live. I you lived up in Alaska you probably wouldn't get any recept. I live in the city, so now problem.
"02" Silverado Reg. Cab 6' Box 4.8 2WD
GMAN12 is offline
Old 08-08-2008, 11:30 AM   #86
Fever for the Flava
hunt_ak's Avatar
I'm in AK, and when I had my 05 CC silvy, I did this mod and lost some reception, but not bad...
hunt_ak is offline
Old 08-09-2008, 12:13 PM   #87
formerly tribaltatts70
1SIK02's Avatar
I live in Louisiana, i did the mod, took about 5 minutes if that, i really dont listen to radio, but still get good reception, if not better, and everyone notices it, easy and simple. i did like a lot of you and bought mine from partszoneonline
***SIGNATURE REMOVED 500x200 or LESS***
02 ECSB, 456's w/locker,GMC 20's, 3/6 drop, esky handles, e-fans, engine and trans work, 04+ tails, shaved tailgate, rollpan, 20% tint, 14" magnaflow
1SIK02 is offline
Old 08-12-2008, 11:42 AM   #88
j0shimself's Avatar
this is an awesome write up when it stopps raining im gunna do it
2006 Silverado 1500
j0shimself
j0shimself is offline
Old 08-17-2008, 08:04 PM   #89
Kenny C's Avatar
No, they are not the same. I ordered an '07 esky cowl corner. Here they are side by side. Mine on the left...esky on the right.
The esky part has the outline of the hole that is in our part. I used my dremel and cut that piece out and used it as a plug on my cowl corner. Also, on the GMT-900s, the antenna cable is shorter and the hood hinge is in the way. So, I mounted the antenna under the wiper cowl with some zip ties. Reception was crap, so I used a piece of wire with some connectors to ground the antenna base. Reception is pretty good and I think my "plug" that I made doesn't look bad. Even the texture matches.
I don't remember the part number off hand, but you can use the site that I posted in the first post and then drill down through their part menu, or just call them up. I think the part for the GMT-900s was only about $8...cheap enough for me to justify hacking it up.
'07 Sierra Denali - 6.2l L92, 6L80E, AWD w/3.42s, HPTuners, Innovate LM-1, Volant CAI, 160* t-stat, N-Fabs, 2.5" leveling kit and 285/65/18 Nitto TGs
Kenny C is offline
Old 09-09-2008, 07:14 PM   #90
worked great, got an escalade already so i stole the cover off that at my own house, i swear the radio sound way better, i think it turned my whole engine bay into an antenna or somethin thanks!
Galster12MX is offline
Old 11-08-2008, 12:47 PM   #91
Chevy in my blood
CustomChevyGuy's Avatar
I just tried this, and didnt have any reception at all, so I undid the whole l-bracket and put it back up in the stock position.
any word if the inline amp has helped? i would think that if you amplify no signal you would get extra nothing ---at least thats how it works in the home a/v field.
Originally Posted by bhookxen
sometimes bad-assery takes time
71 Chevelle 454
03 Silverado 22's,Esky handles,black bowtie,Alpine HU, tint, clear corners, 02 candy tails, FM50. 2" rear drop shackles, debadged, demolded, BlackBear Tuned!
CustomChevyGuy is offline
Old 02-24-2009, 06:51 PM   #92
Chevy Owner
blackknight's Avatar
Hmmi think i got an L bracket sitting around, im gonna try this.
2002 Silverado|4x4|5.3|RCX 6" II|Cognito Steering|3/4 ton CV's|33"BFG|Moto Metal 951B|Borla|K&N|4300k HID|Vette Servo|Blackbear
2007 Suburban|4x4|5.3|LTZ|Cooper Zeon's|Magnaflow|K&N|Blackbear
TSX Projector Retrofit
blackknight is offline
Old 02-25-2009, 02:15 PM   #93
Chevy Owner
Well my L bracket didnt work, but i went to a 24 hour walmart and did this mod at midnight in the parking lot. Pretty easy!
Old 04-30-2009, 06:16 PM   #94
whiteFiveThree's Avatar
Thumbs up Re: Cheap way to shave a NBS antenna!
Ditto.
Looks clean too
Did this today after my buddy down the road had his broken off.
After helping him tear his truck apart trying to find where the antenna wire went behind the dash i did this to prevent myself from having to do the same.
Besides i listen to Sirius and never use FM anyway.
'02 Regular Cab Short Bed 5.3L Silverado
295/45's on 20" Silverado SS wheels
Custom Classic Roll Pan and 3500HD Hood
whiteFiveThree is offline
Old 05-01-2009, 01:53 PM   #95
Supporting Member
94383Z71's Avatar
Did this a week ago on the 03 after finding this thread. the truck looks so much cleaner, and didnt lose much reception. If only the 94 was this easy!
Parts, Dmax Rebuild
94383Z71 is offline
Old 05-17-2009, 12:58 PM   #96
Just did this today. Thanks for the good idea.
For anyone needing an L bracket. I just found a scrap piece of aluminum, cut into a 1x2" piece and bent it and it worked perfect. No need to actual buy a bracket unless you can't find anything around the house that will work.
I did not notice any loss in reception with this either. Thanks!
mrbray101 is offline
Old 05-27-2009, 01:01 PM   #97
Supporting Member
vb02's Avatar
Just ordered this part going to give this a try
2002 Chevy Avalanche Indigo Blue Z66 package 20 Goodyear's, Magnaflow Exhaust, K&N 77 Series intake, Power Aid Throttle Body Spacer, Hypertech Programmer III,and many more Mods
2004 Crew Cab Silverado Silver Burch Z71 offroad
vb02 is offline
Old 06-14-2009, 01:21 AM   #98
eo2159's Avatar
Why not just unbolt the antenna mount flip it upside down then bolt it back in and screw the antenna back in from underneath. Works like a charm and no need for L brackets or zip ties. Its a tight fit but there should be enough slack to do this. I have done this on two 05 gmc rc and had no problem with either. I will say try to use the stock antenna it gets the best reception when mounted upside down.
05 CC Duramax 12" Full Throttle lift,38/1550r20 Toyos, 20X12 weld Cheyenes, Chrome Fox res shocks, Sidewinder 8" steps, Kenwood 8017 DVD player,Focal componets mids & highs front and back,Zapco r750,r360, 12" Treo behind the rear seat,Cobalts in Trippin mt, Egr unplugged, Mbrp exhaust, Predator 65HP
eo2159 is offline
Old 06-15-2009, 09:38 AM   #99
Merez
lunchbox22's Avatar
This is a pretty slick mod, thanks!
lunchbox22 is offline
Old 07-26-2009, 10:57 AM   #100
Supporting Member
GWolfe67's Avatar
Sweet, gonna do it today. If only it was this east to get rid of the Onstar and XM antennas.
2004 Crew Cab Silverado Z-71
Black Bear Tune
GWolfe67 is offline
