05-15-2007, 07:26 PM
Cheap way to shave a NBS antenna!
Whataburger from TexasTruckScene.com clued me in to this cheap and easy mod and I thought I should share
The antenna on the NBS trucks goes through the wiper cowl corner, not the fender like the OBS trucks. Escalades have the antenna in their back glass I think, so their cowl corner doesn't have the hole in it.
Parts needed:
Escalade cowl corner - GM part number 15287179 (got mine for about $10 shipped from partszoneonline.com)
1 zip tie
1 bolt/nut (not sure of the size, mine was 3/8" bolt head and about 1/4" in diameter at the threads)
Remove the antenna and then pop off the cowl corner. It has 3 clips that hold it in place. Then you unbolt the base of the antenna (3 screws) and lay it down, running it parallel with the fender. Now attach the antenna base to the "L" bracket. I used an old bolt that I had in my tool box to attach the antenna to the "L" bracket. Now attach the "L" bracket to the antenna mount using one of the original antenna screws. Reattach the antenna to the antenna base. Now secure the antenna to the fender using the zip tie towards the end of the antenna. There is an opening in the fender well that you can thread the zip tie through. Install the escalade cowl corner and you're done.
I noticed a little reception loss, but not enough to be concerned with. Enjoy
"L" Bracket attached to antenna mount.
Antenna base mounted to the "L" bracket.
Antenna tie wrapped to the fender well.
Old cowl corner next to the esky cowl corner.
Before mod
After mod
My truck was filthy at the time, but you get the idea
'07 Sierra Denali - 6.2l L92, 6L80E, AWD w/3.42s, HPTuners, Innovate LM-1, Volant CAI, 160* t-stat, N-Fabs, 2.5" leveling kit and 285/65/18 Nitto TGs
05-15-2007, 07:42 PM
#2
Re: Cheap way to shave a NBS antenna!
Damn! That got stickied fast
05-15-2007, 08:07 PM
#3
FSC Spam Sniper
I was in the area and it was a good write up
Bob
#4
i wonder if that will work on my Avalanche. I took my antenna off over a year ago but still have the hole there.
2002 Avalanche, bagged, 22's, EXT upper cladding, painted lower cladding, full tint w/a few upgrades inside.
05-15-2007, 08:12 PM
#5
It should. The esky ext is damn near the same thing as an avalanche. I would call a dealership if I was you and verify the part number on the ext. Post up if it will fit.
EDIT: I just checked cadillac.com and I don't see an antenna on the ext. I think it would fit
05-15-2007, 08:13 PM
#6
Thanks
My last write up took about a month before it got the good approval seal of STICKY
05-15-2007, 08:21 PM
#7
one step ahead of you. already emailed my inside connection at the Chevy dealer. he's gonna check to see if he can get it.
Hell, for $10 shipped, it'll be worth it to find out.
thanks for the info.
05-16-2007, 06:57 AM
#8
nice writeup
2004 Silverado-RCSB-5.3-RADIX
2003 Silverado-RCSB-4.8-DD
05-16-2007, 08:11 AM
#9
formerly kustomkoncepts
good one, thanks!!
05-16-2007, 11:42 AM
#10
Originally Posted by kustomkoncepts
good one, thanks!!
No problem
05-16-2007, 05:07 PM
#11
got mine on the way from the dealer. Ended up being a freebie because the guy I know there didn't want the hastle of dealing with a $9 paypal transaction.
hope it fits an Av.
05-17-2007, 06:01 AM
#12
hope it fits an Av.
Keep us posted
05-17-2007, 08:53 AM
#13
SLACKIN' CARLISLE BISH
How is your reception? Did it get any worse with the antenna like that?
If its loud, fast and runs on flammable liquid......count me in.
LQ9, 11:1 compression, Edelbrock/Lingenfelter heads, 224/224 5xx/5xx 1xx+ cam, 44lb injectors edelbrock headers, 3000 yank stall, flt 4l65e lvl5 trans, truetrac, WHEATLEY tuned
05-17-2007, 11:02 AM
#14
Not much. I live on the border of Indiana and Kentucky and I am always crossing back and forth. I live in IN and work in KY. Anyway, I still get all of the stations the same as I did before, but sometimes when I use "seek" it will not stop even though I know there are stations there...if that makes sense.
05-18-2007, 05:22 PM
#15
i just got done doin this.. it was really easy and i didnt loose any of my reception. i can still scan through stations and everything. thanks for the idea man!
05-19-2007, 09:49 PM
#16
Works on an Avalanche also. Took about 2 minutes to swap the cover. I didn't do the whole antenna thing because I don't listen to FM at all.
05-20-2007, 09:46 AM
#17
Cars & Guitars
on my to do list! thanks for the idea & part numbers!
05-20-2007, 01:35 PM
#18
1999 Z71 w/ system
It work on 99 silverado? same parts correct? I am hoping to do this because I hate the antenna. It's always in the way
05-20-2007, 01:38 PM
#19
its the same for the 99
05-21-2007, 06:30 AM
#20
Yeah it should work on the 99-07 classics.
| Thread Tools |
| Display Modes |
Linear Mode
