06-01-2009, 10:48 AM
#21
3 FSC's and Counting
Re: OBS Dual Battery Big 3 Upgrade.
Let me find my pics.............
94' GMC k1500 6.5l TD for parts
96' K2500HD 6.5l TD, Heath PMD, Turbo Master, Mand. Bent X-Over Pipe, 4" Flo Pro Exhaust, Vac Pump Removed Belt # 4061000 = 100", 04' Dmax wheels w/ 265's
07' NNBS 2wd w/4.3l
Originally Posted by daved931
You're on crack. Every man should have more cars than he can drive in a week.
09-19-2009, 11:24 PM
#22
whats gonna break next?
pics?
1997 K1500 Built vortec 355
Originally Posted by StreetFreak
A good number of parts on my truck are ziptied on, simply because bolts are too heavy
imo
09-20-2009, 12:28 AM
#23
I got a similar set up. I will go take some pics.
09-20-2009, 07:26 AM
#24
Kanye Herman
CST Performance Lift
4" Lift Spindles
3" Lift Coils
2" daystar Spacers
CST Tube UCA
Firestone F9000 Bags
Helo 442 18"x9"
Hankook 35x12.50x18"
09-21-2009, 04:05 AM
#25
Overall look of the truck motor
Yellow top on the the drivers side (IE battery number 2)
Red Top on the passenger side (IE primary battery)
Battery Isolator
Left Terminal - Charge wire to number 1 battery, voltage sense wire, and excitation wire.
Top Terminal - Excitation wire
Bottom Terminal - Alternator (only thing I didn't upgrade)
Right terminal - Secondary Battery
09-21-2009, 06:02 AM
#26
whats the blue thing and what does it do?
imo
09-21-2009, 06:04 AM
#27
Motivational Speaker
Battery isolator. I speparates the batteries from each other electrically, and charges them.
Originally Posted by Big Angry
Hey ****face, (yes I am violating the rules and flaming you, whaah)
Originally Posted by CKTA
No, I'm just dumb.
09-21-2009, 06:07 AM
#28
so if one goes dead, it wont drain the 2nd one?
imo
09-21-2009, 06:08 AM
#29
Basically, yes.
No, I'm just dumb.
09-21-2009, 10:07 AM
#30
how did you mount the battery on the driver side... on mine theres a vacuum canister that i would think would be in the way
95 2dr tahoe tbi 5.7 w/t front
My Cardomain
11-01-2009, 08:59 PM
#31
BNSF railfan
good question since i need to have a dual btry setup on my 1992 c1500 burban
11-01-2009, 10:43 PM
#32
You'll need to look under the hood of a Vortec truck as they use a different charcoal canister and have a battery tray where the TBI can sits.
Originally Posted by mudbuddy
only reason to get rid of EFI is because your afraid of what you don't know.
'98 K1500 ECSB 5.7/4L60E, LT's w/3" Magnaflow, EFI Live.
11-01-2009, 10:49 PM
#33
naked women and beer
there is a bracket for the 2nd one and the fuel evap can has to be moved elsewhere but since i built my new motor i did away with it completely just capped the tube going back to the tank
 CONSTRUCTION ALMOST FINAL
94' 1500 silverado 4.56 gears, Rancho 6" Realift torsion bar risers, 3" body, 10"procomp leafs, 37 MTZs on 18 diesels, 383 stroker and motorvation injection 11to1 comp, 4L80e
08' HD Rocker
11-10-2009, 12:38 PM
#34
BNSF railfan
does anybody have the part number for the aux battery tray for the 1992 C1500 truck?
11-19-2009, 06:16 AM
#35
I have a dual battery tray for a 92. I'll pull it out this weekend and get the part# for you guys. I'm still trying to figure out what to do with my canister too.
1992 Chevy Silverado Mark III EXT
| Thread Tools |
| Display Modes |
Linear Mode
