Go Back   FSC Forum > General Discussion > Tech Articles Two
Old 03-26-2008, 11:40 PM   #1
Stripped Sway Bar Frame Bolt Hole Thread Fix
To those who have stripped thread on the frame for front sway bar bushing bolt, this repairing could help you solving the problem.
On my 1999 Tahoe 2WD, 4Dr, the front driver-side sway bar bushing is directly bolted on the frame with 2 self-taping bolts. Some time bolt cold strip the thread on the frame if over-torque happens.
The solution is either using over-size bolt or adding a nut to the bolt. But the over-size bolt may have larger hex-head, the fixed distance between 2 holes and bushing bracket does not have enough space for larger head bolt. So, add a nut to the bolt is more realistic. The front frame is box type, no accessing hole. So, you need drill a 1-1/4 diameter hole on the side of the front frame near bushing bracket bolt. See the picture.
Fig.1: Accessing holes:
If the stripped thread happens on passenger-side, drill ONE hole on side of the frame between 2 holes.
Some Chevy B-body forum members weld a insert nut to the hole, but you need some weld equipment which costs you more.
Here is list of tool and parts you need:
1) Electric drill
2) 1/8 drill bit
3) 1-1/4 (maximum) step drill bit
4) Grind stone
5) 3/8 ratchet
6) 8MM or 5/16 Allen wrench (3/8 drive)
7) 14MM or 9/16 box wrench
8) Needle nose pliers
9) 3/8-16X1.5 socket head bolt, 3/8-16 nut
Fig.2 Tools:
The Chinese-made $12 step drill bit was purchased from Amazon.com, but its quality is good enough to get job done.
Fig.3 Step Drill bit:
Procedure:
Remove the front wheel.
Attach a pieces of masking tape between power steering gear attaching bolts, mark a drilling spot.
Fig.4 Marking Spot:
Use a 1/8 drill drilling a pilot hole first, then use step drill bit continuing the job. The step drill bit needs some cooling while doing the job, so spray some WD-40 every minute.
After the accessing hole diameter is large enough for a 14MM box wrench accessing, then use a grind stone attaching to electric drill to chamfer sharp edge one the accessing hole.
Fig.5 Hole diameter:
To engage the nut on the bolt is a challenge job, be patient! Since the accessing hole is NOT larger enough for 2 fingers, so you need a needle nose pliers as a helper. What I did was using masking tap wrapping the nut on A finger tip, then punch a hole on masking tap to expose thread, then using ONE finger to put the nut on the top of bolt while the bolt was turning with an Allen wrench.
Fig.6 Finger & nut:
Finally, tighten the bolt and nut with box wrench and Allen wrench.
Fig.7 Final:
JZ57_CN is offline
Old 03-27-2008, 11:08 AM   #2
GMC RULZZ
NEUMANNZZ's Avatar
Re: Stripped Sway Bar Frame Bolt Hole Thread Fix
I have had that happen before, using a bigger self tapping bolt worked for a while then finally used a nut and bolt to do it. good writeup!!!
Matching Ninja 500r
NEUMANNZZ is offline
Old 04-03-2008, 11:15 AM   #3
RAGMC
ragmc's Avatar
Graet write up!!!!!!
ragmc is offline
Old 04-10-2008, 09:50 AM   #4
Chevy's For Life
tonxcab's Avatar
Good write up does this happen alot.
Sig by: 454ss
1979 Chevy SCLB C20
1982 Chevy Suburban K20 "MUD KING"
2001 GMC Sierra 1500HD, 6.0L-4L80, Crewcab 4x4
tonxcab is offline
Old 04-11-2008, 05:46 PM   #5
Rev it up and GO GO
intimidator4x4's Avatar
Happened on mine 4 years ago, that is how I did it, worked good
91 RCSB fleetside Z71 6"Superlift/3"bl/35X12.50 SSR's/15X10 Eagles/4.10's
96 ECSB stepside/DD/265's/slight crank
99 ZR2 Blazer/32's stock
intimidator4x4 is offline
