07-15-2005, 11:30 AM
#21
typical custom user title
Re: LS1/Electric Fan Install Tech Article
I posted this in another thread, but thought this info would be helpful in this tech article, as well, for those using a harness for their pcm...atleast you know what it will likely look like before ordering it.
Here are pics of the harness and manual that Bryan Herter with PCMFORLESS provided me. The only thing that I lack to install these are the pigtails to the ls1 fans. I did find from a thread on ls1tech a few guys that bought the pigtails from waytekwire.com p/n 46047...3 piece minimum, but I think Tom at AMP performance is gonna hook me up with a couple.
The manula that Bryan provided has many color pics and easy instructions to follow to hook up his harness. I'll let you know how easy it was once I get it installed.
07-18-2005, 05:55 PM
#22
Hey watch this
Originally Posted by OKLAGMCRUISER
...The only thing that I lack to install these are the pigtails to the ls1 fans. I did find from a thread on ls1tech a few guys that bought the pigtails from waytekwire.com p/n 46047...3 piece minimum...
that looks like it may work
Price is only ~$2.20 a piece, total of ~$7 to meet the minimum order, not bad.
02-09-2006, 11:06 PM
#23
Im bidding on some ls1 fans on ebay, but what exactly do i need to buy from truckprefornace to get it to work without going in my pcm? I think this http://www.truckperformance.com/prod...mber_FLX31165/ But there are like 3 other things they sell from felxalite
Chevy 2001 z71 1500 5.3, 4.56, Flowmaster, K&N Generation II Air Intake Kit and a Tune by JESSEBUBB
6inch Procomp /3inch PA bodylift / Micky Tompson 16x10 / 37x13x16 Boggers
05-07-2006, 09:51 AM
#24
Okalgmcruiser? Pryor to your install did you have a factory PCM? Or an aftermarket? I am looking to install some e-fans from an 05 truck and looking for the cleanest looking install for the wiring end of the deal! I have an 03 Denali, any help would be appreciated. Thnak you, 03 Denali
05-07-2006, 09:53 AM
#25
Was looking to install some e-fans from an 05 truck into my 03 Denali and the wiring you spoke of does it connect the factory PCM or Aftermarket? Thank you , 03 Denali
08-04-2006, 02:30 AM
#26
2005 wiring harness part number #15216042 stock fan harness for 2005 34" radiator fans , will work with any fuse box that looks like the 05 fuse boxes . Snaps in under the fuse box cover to the right of the fuse pod already there .:)o
08-08-2006, 09:31 PM
#27
ive got an imperial 16 inch electric unit on my 90' silverado with a 160 thermo, i run 160 on the street and 175 in stop and go, i dont have a thermostat switch. i hooked up a toggle instead, power at my finger tips, muah. i know 160 may seem a bit cool, but hell, cooler engine=longer life for your bearings and other vital parts, however short life for gasoline. but hell who cares in the times of $2.91 a gallon, i know i dont, muahhaha
-Reaper
10-03-2006, 08:56 AM
#28
Thats Right!!
The link does not work for me any more!!!!!!!!
really need it!!!!!!!!!!!!!!
HEEEEEEEEEEEELLLLLLLLLLLLLLLLLLP
2008 Limited Edition Navigator
1999 ECSB GMC Sierra
2007 Crew Cab 1 ton single rear wheel Dodge Cummins
10-07-2006, 12:17 PM
#29
I think the server is down. Shoot me an email if you have questions.
Andrew
-Andrew
2001 Silverado 6.0 RCLB - Home Page
Nelson Tune, Comp Cam XR265HR, Pacesetters, 3.42 Eaton Posi, RPM Trans, LS1 Fans, Hotchkis Sways, Eagle 219s
10-11-2006, 09:06 AM
#30
Can you put it up on a different server?......or email it out? I need it too. Any help would be greatly appreciated. Thanks
12-19-2006, 10:32 PM
#31
Cars & Guitars
ls1 fans are on my "to do" list, I'll probably tackle this project mid January (I get some free time than) thanks for all the great info, hopefully getting rid of the mechanical fan along with the underdrive pulley will open up some otherwise misguided ponies.
one question however, what is holding the pulley on to the waterpump hub without those four bolts or the threaded nut on the fan clutch?
12-20-2006, 07:08 PM
#32
what kind of performance should i expect out of efans over the manual clutch?
2004 Silverado-RCSB-5.3-RADIX
2003 Silverado-RCSB-4.8-DD
12-21-2006, 12:15 AM
#33
Thats Right!!
What i like the most about it is the reduction in noise!!!!
You wont pushed back into your seatif you do this but your truck will run cooler and more efficient you will probably notice a small gain in fuel mileage. I did it to mine becaause I like the way it cleans up the engine bay. Less cluter.
12-21-2006, 11:39 PM
#34
I have a White Eyebrow
I really want to do this to my truck. Doing this tho, will it help warm it up in the winter a little faster without the fan running all the time? I plan on hooking it up to a togle switch on my dash so I can turn it on when I please.
Brian Threet 3-17-87 - 1-05-08
Jenna Foellmi 9-15-87 - 12-14-07
I feel you everywhere I go, I see your smile, I see your face, I hear you laughing in the rain, I Still can't believe you're gone.
12-22-2006, 03:51 PM
#35
12-22-2006, 06:08 PM
#36
Cars & Guitars
I found this about converting over to electric fans. He is directing the site to RX7 guys but he still had some valid points. I dont agree with everything he said, but I do agree with some of it. I'm still doing the ls1 fans on my truck though
http://www.aaroncake.net/rx-7/efanmyth.htm
12-30-2006, 06:40 PM
#37
Thats Right!!
Damn we have an engineer in our hands(who ever wrote that article)!
What it comes down to, is most of us run 1/4 or 1/8 mile at the strip. If you turn off your fans for that period of it will help not having to turn that clutch and fan. Also with our trucks the fan pulls air threw the AC condensor as well, if you have been stuck in traffic in 100 deg weather like we have here in Houston, the AC does not work to good. After the e fan install my AC works alot better in stop and go traffic! Alot more air moves threw condensor and radiator.
Thats my 2 cents
01-04-2007, 11:12 PM
#38
Cars & Guitars
I just added my E-fans today. I ordered the flex-a-lite kit part # flx-292 from summitracing.com I dont have it wired up yet, I'll do that first thing in the morning. The kit was complete! it came with the fans in a shroud. The brackets to bolt into the factory shroud locations. The controller, a huge maxi-fuse holder and plenty of wireing & connectors. It looks professional and I love how it cleaned up the engine compartment.
01-05-2007, 10:24 AM
#39
Thats Right!!
That must of cost you a pretty penny!
I ordered the flexalite controler for my LS1 fans. I have them on a switch right now, which im not to crazy about. I rather let technology work for me.
01-05-2007, 02:53 PM
#40
Cars & Guitars
yea, the kit was costly. But you get what you pay for. I finsihed the wiring and the fans work great! it's amazing, most of the time the fans aren't even running. They only click on when I've been idling at a light for a while.
there is so much room in front of the engine I can stand in the compartment... a little easier to change a cap & rotor now.
| Thread Tools |
| Display Modes |
Linear Mode
