Go Back   FSC Forum > General Discussion > Tech Articles Two
Old 12-01-2003, 07:01 PM   #1
LS1/Electric Fan Install
Hey guys, I threw together a little LS1 Fan tech article for those hesitant to do it based on what all goes into installing it. I think this covers just about everything, hope it is helpful.
http://bertok.us/agreif/fans/fanstech.htm
Andrew
-Andrew
2001 Silverado 6.0 RCLB - Home Page
Nelson Tune, Comp Cam XR265HR, Pacesetters, 3.42 Eaton Posi, RPM Trans, LS1 Fans, Hotchkis Sways, Eagle 219s
agreif is offline
Old 12-15-2003, 11:10 PM   #2
4x2 Silverado Guru
Atreyu's Avatar
whats the benefit of doing a LS1 fan install ? less drag on the motor ?
Atreyu
Atreyu is offline
Old 12-16-2003, 12:56 PM   #3
Yep, you got it. instead of the machanical fan taking away power that could be used to turn the driveshaft, you now have an electrically driven fan that isn't always spinning.
-Andrew
agreif is offline
Old 12-16-2003, 06:47 PM   #4
Red rado's Avatar
Where did you get the fans? What is approx. cost? Can you tell any difference in the performance? Is the cooling capabilities better or the same with the electric fans? Sorry for all the questions, but this looks interesting.
03 Silverado ECSB 2WD 5.3L 3.42 G80, Nelson Tune, Magnaflow catback, UPD Intake, body color door handles and mirror caps, Access tonneau, Bedrug, 17" chrome Escalade wheels w/ Michelin Pilot LTX tires
Red rado is offline
Old 12-16-2003, 06:50 PM   #5
4x2 Silverado Guru
Atreyu's Avatar
do you have the fan part # from flex-a-lite? i workd for CSk and i can order the fans at 40% discount if anyone wants one. i am going to do this myself. i hope the results are substantial, or at least my motor runs cooler. i am in arizona and you can never have too much cooling.
Atreyu
Atreyu is offline
Old 12-31-2003, 01:23 AM   #6
1) I got em from an ebay seller
2) you can usually get them for around 90-150 depending on the person you get them from and then another 30-60 depending on what controller you get.
3) The biggest difference you will see is around town in warm weather, that would be when your fan would normally be engaged, I know people have gotten dynos before and after and seen anywhere from 10-24 HP increase.
4) A lot of people run them on their trucks and I haven't heard of any problems with cool yet, but you may want to investigate further for peace of mind.
No I don't, I only ordered the flex-a-lite controller and I got that from truckperformance.com
Andrew
-Andrew
agreif is offline
Old 01-09-2004, 08:01 AM   #7
Can this be done on an older truck, say a 92 K?
1992 Z71/9in. lift/39.50" TSLs
2000 Camaro SS
1993 Mirage 30 mpg!
92Z71 is offline
Old 01-13-2004, 02:08 PM   #8
Low trap speeds are COOL!
SloNlo350's Avatar
I have heard that it could, but I cant find where i saw that. I wanna do the same thing om my 95.
SloNlo350 is offline
Old 01-15-2004, 11:30 AM   #9
I know you can do it on a 95, it's been done before.
-Andrew
agreif is offline
Old 01-17-2004, 01:21 PM   #10
LS6TT's Avatar
if its done on a 95 doesnt that mean it can be done on a 92 as well? im curious cause i want to do this same thing
-Alex
Cadillac CTS - the daily
95 k1500 Suburban - the toy
LS6TT is offline
Old 01-18-2004, 06:00 PM   #11
really nice install. I purchased the Flexalite kit for 400 bucks. what i like the most is the increased HP gained. at least 10-15 easliy.
c5truck is offline
Old 02-22-2004, 07:19 PM   #12
I put dual 16" fans on my 95...
Ran an adjustable thermostat and another relay to kick the fans on with the AC. never any overheating problems and I believe that you can actually feel the difference.
LK
Alwhite95 is offline
Old 03-23-2004, 09:16 PM   #13
The 12 gauge AUTO-LOADER
Germanator's Avatar
if you buy the dual flexalite kit do you still need a bigger alternator? Im debating of adding some e-fans by flexalite if my truck wont sell by summer, then I just keep it and might add the fans. I been dabating that ever since...
FOR SALE
Germanator is offline
Old 04-04-2004, 08:44 PM   #14
rat
put doul e-fans on my 86 picked up a few mpg and a little more power to push snow , didnt have to get a bigger alt. when i plow i run heater full blast,headlights,light on roof,radio,and both fans and the volt guage doesnt drop below 12.5 volts,much quieter on the road to now i hear everything
rat is offline
Old 04-07-2005, 07:26 PM   #15
tpichevy's Avatar
Re: LS1/Electric Fan Install Tech Article
i put in some ls1 fans from a 2002 ss camaro on my 92 truck when i swaped the 4.3 for a built 5.7 tpi from a 91 z28, the fans work perfect, i kept the stock fan shroud and all, i run to cold right now, i need to chenge stat.
tpichevy is offline
Old 04-13-2005, 04:49 PM   #16
farmerdave93's Avatar
I'm thinking of doing this mod because my gas mileage is sucky on my brand new 05 X-cab 4.3L V6. Plus it's a little underpowered... I know, I know, why didn't I get the V8? Maybe I'm overreacting, since I've only filled up twice, but I'm averageing 15mpg, mostly highway. Pretty sorry for a new vehicle if you ask me. I have yet to play with tire pressures though.
Thanks for the info!
Anyway, what thermostat should I run if I do this mod?
farmerdave93 is offline
Old 04-17-2005, 08:49 PM   #17
HAH! I was under the hood of my truck... and I didn't notice till today that I've already got dual electric fans! Guess I'll be looking for another fuel saving mod.
Old 06-17-2005, 03:51 PM   #18
formerly jonmcc0417
nice mod i had the flex-a-lite fans on my old 89 ( now theyre for sale on ebay) and it helped out a lot since i had a body lift
red02chevy is offline
Old 06-17-2005, 05:20 PM   #19
SloNlo350's Avatar
Yeah, i have long since done the fans. This is an old freakin' thread too. I got some LT1 fans and it keeps my ZZ4 below 180 no matter what (95 degree weather in traffic no problem). I dont have a thermostat on the fan though, it is just always on.
Old 07-12-2005, 11:59 AM   #20
typical custom user title
OKLAGMCRUISER's Avatar
Great write up. It has given me peace of mind before doing mine.
FYI...Call Tom Thompson with AMP Performance for used LS1 fan assemblies @ 1-800-454-8387. He currently has around 20 assemblies at aprox 75 each plus around 20 for shipping.
Pat
OKLAGMCRUISER is offline
