Old 01-21-2008, 12:34 PM   #361
racermech
Member ID: 58077
Re: disc brake swap
To all that have replied to this thread and kept it going, excellent work. This whole site rocks! One question to add, are there any e-brake calipers that I can use that I don't have to step the e-brake in everytime like with the caddy calipers?
Old 01-21-2008, 08:03 PM   #362
Low88
Drive and Enjoy.
Low88's Avatar
Member ID: 19385
Re: disc brake swap
I wouldn't say every time with the caddys. If you set it once every few weeks, you should be fine. I am going to be working on a driveline E-brake sooner or later, once my truck is on the road.
Old 01-21-2008, 09:04 PM   #363
achidotcom
98burbk1500
achidotcom's Avatar
Member ID: 71578
Re: disc brake swap
found this might help a few people
http://tsmmfg.com/2620.htm
98 GMC Suburban K1500 , 3/4 drop, comp 08-503-8 cam, 1.52 roller rockers, e-tec 170 heads, blackbear tune, headers, flowmaster, k&n, MSD 8.5, MSD, billet dist. wideband o2, transgo hd2, vette servo, yank ss2800, LT4 knock module, aluminum radiator, e-fans
Old 01-21-2008, 09:15 PM   #364
Rob Brown
Rob Brown's Avatar
Member ID: 15539
Re: disc brake swap
Look under some of the offroad specialty places like highangle driveline, or JB conversions, etc for your driveline ebrakes. I am going to go to one on my daily SAS eventually.
...as for the caddy ebrake calipers..I don't especially like mine cause with large tires they just don't hold period. On level ground in gear at idle, the truck will carry on still. Though I am running a 37" tire with 5.13's......but still not impressed for what they are worth.
Old 01-21-2008, 09:38 PM   #365
achidotcom
98burbk1500
achidotcom's Avatar
Member ID: 71578
Re: disc brake swap
electronic brake lock, i use this on my service truck chevy 3500
http://gmcmotorhomeinfo.com/BRKLOCK.html
Old 01-21-2008, 10:37 PM   #366
Rob Brown
Rob Brown's Avatar
Member ID: 15539
Re: disc brake swap
Only problem is, that does you no good what so ever in a case where and if you lose hydrolic usage (brake line/hose breaks etc.) That is why the emergency brake is mechanical still. Here is is illegal to use a switch like that or a line lock for an emergency brake. Will fail a safety inspection.
Old 01-24-2008, 01:08 AM   #367
55chevyman
Like a rock
Member ID: 76873
Re: disc brake swap
I read this and didnt see a 8 lug setup..maybe i missed it?
I got a 75 c-20 3/4 ton could i use the front rotor for the back and use the caddy caliper?
1975 3/4 c-20 -- sadly sold
1997 1500 silverado-
jet stage 2 performance chip, jet air sensor thingy, edlebrock headers, catback exhaust.
His name is rumblebutt
Loud pipes save lives
Old 01-24-2008, 06:30 AM   #368
Rob Brown
Rob Brown's Avatar
Member ID: 15539
Re: disc brake swap
If you have a 3/4 ton, I would assume that you have a 14 bolt full floater in the rear. You can use the 3/4 ton discs in the rear, buy your caliper conversion bracketry, and install the calipers off of the same version in the rear. If you need/want ebrake, then yes...caddy calipers.
Old 01-24-2008, 07:47 AM   #369
N0DIH
Member ID: 27004
Re: disc brake swap
What years did the 10.5 FF get discs? 00-up?
94 Cadillac Fleetwood Brougham w/RPO V4P
00 Buick Park Avenue Ultra SC 3800
99 K2500 Suburban 454, Tuned by Me!
Old 01-24-2008, 07:31 PM   #370
achidotcom
98burbk1500
achidotcom's Avatar
Member ID: 71578
Re: disc brake swap
http://tsmmfg.com/General_Motors_truck_rear_axles.htm
8-lug, 5-lug, 6-lug, kits for all
Old 01-25-2008, 08:21 AM   #371
N0DIH
Member ID: 27004
Re: disc brake swap
That finally the first I hasve seen with a REASONABLE price, most places like SSB are stupid high price, which is the reason I look at the OEM solutions....
Old 01-25-2008, 07:44 PM   #372
82Blaze
Member ID: 43483
Re: disc brake swap
You guys might try this guy. I bought brackets from him for use with the 94-96 Impala SS calipers/rotors. He is now redying a kit for use with the Camaro calipers which have an ebrake.
http://www.blackhollowllc.net/Automo..._Products.html
Old 01-25-2008, 09:09 PM   #373
mred
mred's Avatar
Member ID: 62799
Re: disc brake swap
so this swap, does this make the braking work that much better?
my 97, the brakes are just down right ****y!!!!
i have the Jb5 brakes and wow
Old 01-27-2008, 01:21 PM   #374
82Blaze
Member ID: 43483
Re: disc brake swap
Doing the drum to disc swap on my old 2wd Blazer made a world of difference! It got even better after I got the adjustable proportioning valve in the system.
Old 01-27-2008, 01:42 PM   #375
N0DIH
Member ID: 27004
Re: disc brake swap
I would LOVE to do a disc swap on my 99 K2500 Burb....Are all NBS 2500/3500 SRW discs with the 10.5 FF?
It has decent brakes now, the massive rear drums are on there now. But anything to improve it is worth it, these trucks need all the braking we can get....
The 1500's especially, the bigger brakes on the 2500 is one of the reasons we opted to go 3/4 ton in the first place, depsite the lousy fuel economy. It isn't worth it if you can't stop....
Old 03-20-2008, 01:19 PM   #376
silverboy02
Member ID: 82054
Re: disc brake swap
Hey guys, I just found a company that makes kits for the 2wd and 4wd trucks. They have stock kits and Hi-Performance kits. Check them out on ebay. Here is one item number: 350038362980
Here is a link to there store:
http://stores.ebay.com/KingTek-Performance
02 Camaro SS 35th LE M6
For Sale: $13,000 55,000 miles
96 Chevy Silverado Reg. Cab Stepside
Project in the works:
Denali front, 02 GMC front bumper, SS style hood, 4/6 drop, shaved tailgate, Caddy tails, shaved stakes, bed seams, rear steps,20x8.5 Boss 335, ProCoat bedliner
Old 03-20-2008, 11:14 PM   #377
tpichevy
tpichevy's Avatar
Member ID: 25890
Re: disc brake swap
good find!! might have to do this sooner then i planed on ha
-TireFryr-v8TPI-212-218,110-1.52rollers-Fully Ported aftermarket TPI setup,52mm TB,Coated LTs,Built 700r4,2800Yenk stall,Hurst v-matic2,3.73posi "TractionLess"GoleET:13s Best 14.6-93mph 1.78-60' YenkoST is my Tunner!!
Old 03-21-2008, 01:49 AM   #378
cancritter
cancritter's Avatar
Member ID: 48067
Re: disc brake swap
2am...19 pages...whys the info lm after always on the last page ...my eyes are sore....excelent info...nappy time..zzzzZZZZZ
[Stole/FOUND 13/03/08 :O)
91GM 4x4 excb 5.7 @ 40 over, Westers,Eld 3704.Lunati Trickflow 195 @1.6 RR,Hooker Walpro 190/overbuilt 700r4 /TCS TC,4.10/tru trac,14 bolt,Hooker LT,areofilter,Extreme TBI.msd and still adding
97/rclb/5.7/westers tune/stock
Old 04-14-2008, 09:44 AM   #379
rainman318
Premium Member #118
Needs More Cowbell
rainman318's Avatar
Member ID: 63861
Re: disc brake swap
Has anyone tried using the whole setup from an impala? Is there a difference in axle flange or something that would prevent you from using the e-brake?
Old 04-14-2008, 11:35 AM   #380
N0DIH
Member ID: 27004
Re: disc brake swap
Get a hold of Bill Harper, aka, navylifer and talk to him, he would know.
Let him know I sent you, he and I have talked on it before, it might jog his memory....
