#1 |
::runs into wall::
Member ID: 9996
CB Radio/PA install!!!
sorry this is kind of sloppy and my camera was dying so i only had a little bit of time to take pictures
i purchased the PA speaker from Radio Shack for $15 (make sure it's an outdoor speaker) and i bought everything else from FRYS electronics... all of this costed just under $100...OK.. heres the picture of the antenna mounted on the front left portion of my bed... it feeds down a hole in he bed right below the antenna: after feeding the wire down the hole i ran it along the emergency break cables (don't directly attach the wire to the emergency break cables... run it along something comfortably far from the emergency break cables, like me) and pardon my ugly zip-tying skills: Here is the wire coming up right behind the front left fenderwell (ugly zip-tie again: and here is the picture of it coming up from the fender well (the black wire, this is also under the hood): then i fed the wire through the firewall (you can also see the PA wire in this picture): And finially i hooked the wire up to the main unit which has a CB radio plug-in and also a PA output: Now for the PA install I ran the PA wire from the output on the main unit back out through the firewall (the same way i brought the CB radio wire in): i then ran the wire down the side of the left wheel well: then i mounted the actual PA speaker on the frame where there was a lot of clearance (right behind the bumper on the left side, notice the tow hooks) and then soldered the wires together): sorry if this thread is confusing... if you don't understand something feel free to PM or instant message me... have fun guys, don't get in trouble... later... ![]() Stock Trucks Own You. |
#2 |
breaker breaker one nine.
what model Uniden is that and how much $$?
#3 |
::runs into wall::
Member ID: 9996
haha, its ****ing funn to hear truckers talk.. they hit on my girlfriend all the time... its the PRO520XL... around $50-$60
#4 |
02GMCtruck
Status:
Online
Member ID: 13211
Nice install on the PA. I also have a CB and PA in my truck but the CB quit working.
![]() ![]() 88 GMC K1500, RCSS/5.7L/700R4/NP241/D44/14SF G80, 168k. 9" SAS, D44 on 35's 02 GMC K1500, RCSS/4.8L/4L60E/NP261/IFS/10, 16k. Sierra HT package: 1 of 234 Trucks. |
#5 |
3rd generation Chevy guy
Member ID: 53352
Re: CB Radio/PA install!!!
Ahhhh! Where'd the pics go?!? I would LOVE to see how this was done as I'm doing the exact same thing (on a 95 Z71 though, don't know what your truck is).
![]() "This... is my BOOMSTICK!" 1995 Z71 ECSB 5.7L (crate)~4L60E~3:73~GVW 6200~HD towing package~NBS stock wheels~285 BFGs~TB crank 1"~3" dual exhaust~BCT7 scanner~Cobra 29LTD~almost debadged |
#6 |
Member ID: 53352
Thank you for updating the pictures! It's nice to finally have a visual reference.
What year truck did you do this with? I gues you were able to run the antenna and PA wires through existing holes in your firewall? ![]() "This... is my BOOMSTICK!" 1995 Z71 ECSB 5.7L (crate)~4L60E~3:73~GVW 6200~HD towing package~NBS stock wheels~285 BFGs~TB crank 1"~3" dual exhaust~BCT7 scanner~Cobra 29LTD~almost debadged |
#7 |
stock wheelin' is fun
Member ID: 29541
nice work...how did you hook up that radioshack pa to the pin connector on the back of your radio...i have the same cb...could you take a pic of the back of yours?
![]() 2001 Chevy 1500 4x4 3" body lift ford keys 3" blocks 315/75/16 Dunlop Mud Rovers Flowmaster FORD ![]() WRECKED! GO STATE |
#8 | |
Premium Member #26
Supporting Member
Member ID: 13228
#9 |
Member ID: 53352
Eh, yeah I guess the NBS would have a "Big Grommet".
Looks like I'll have to drill my own in my '95. I just keep thinking (hoping, actually) that there's one in my firewall too and that I'm just overlooking it. ![]() "This... is my BOOMSTICK!" 1995 Z71 ECSB 5.7L (crate)~4L60E~3:73~GVW 6200~HD towing package~NBS stock wheels~285 BFGs~TB crank 1"~3" dual exhaust~BCT7 scanner~Cobra 29LTD~almost debadged |
#10 |
Is your pa speaker amplified? How many watts does a normal cb send out for the pa... I have mine amplified by a 140watt car audio amp one one channel so its prob rlly like 50 ... its loud
-99' Z56 Police Tahoe-
#11 | |
I have been installing for 15 years and the best option I can recommend for running through the firewall in your truck is to drill where the clutch pedal would go through (assuming it's an automatic). You can see where this is on the firewall by looking next to the brake pedal under the dash. You will see a cut out in the firewall insulation. Just pull the cut out and you will have access to the firewall. Drill in that plate and you will easily see your hole from under the hood. Make sure you install a grommet! |
#12 |
Member ID: 53352
Oh man, that's a great idea! I forgot all about the clutch option. Unfortunately, I already installed my unit (pics comming soon) and drilled elsewhere in my firewall. It's something to definitely keep in mind for the next time though.
#13 | |
Slow-N-Steady
Member ID: 2613
Prov 3:5-6; Jer 29:11
'99 2wd 4dr Tahoe: Ceramic Thorley Tri-Ys | MagnaFlow Cat-back | BellTech Sways | PSC Front-End | Edelbrock IAS | PowerSlots & Hawk LTS | Rebuilt 4L60E | Iraggi HO Alt MySpace
#14 |
Member ID: 24894
Couple small details. Its a parking brake cable not break :)
Where you went up by the fenderwell the factory harness there has that silver tape to reflect the heat from the exhaust, your antenna cable should be protected from the heat also. I usually cover all my wiring with split loom tubing, wither feeding it through the existing or wrapping a bigger one around to help protect the wiring.
2004 Silverado ECSB Z71 5.3L 4L60E
Mods So Far: Bug Deflector, Glove Box Light, Floor Courtesy Lamps, Console Power Port, Cobra 25 NW ST WX, Wilson Little Wil, Surepower 120A Battery Isolator and second battery. BFG AT KO 285/75 R16. Ranch cap with Tahoe z71 roof rack. |
#15 | |
Bump, Bump
Member ID: 47757
![]() ![]() Channel 28. 151 around Md. In my MUDDUCK Truck. working this (Rolling Radios) Stryker 440, with a X Force 2X8 Swingin 2kw. Quack, Quack http://www.cbradioforum.com/ |
#16 | |
Member ID: 24894
I made that reply from my office PC too so no integrated spell checker since we can't have anything but MSIE so we are in the dark ages of browsers.
#17 |
I want to put a PA speaker on my CB radio. I have the wire, CB radio, and a PA speaker like that, but I don't know what to use to connect it with.
#18 | |
Member ID: 72724
Im kind of in the same boat. I have the cb, the speaker, and the antennas and mounts are on the way. But what wire do you use to wire it to the cb? Radioshack guys didnt have a clue but either did i.
#19 |
Slow-N-Steady
Member ID: 2613
Your CB must have a PA jack in order to have PA capabilities. Some CBs don't have this option.
#20 |
Member ID: 40693
Pa to CB is just speaker wire.
Antenna to CB is Coaxial IIRC it is best to use lengths of 18 feet to keep SWR in check. ![]() Only Ride Chevy Never Drive a Ford 98 C1500 EC Step Side, 350 CI, DI/DO Magnaflow, K&N filter, 3.73 gears, red top. |
| Advertisements |
| Thread Tools | |
| Display Modes | |
