Old 06-28-2004, 09:29 AM   #1
99GoldSilverado
www.wildwill.com
99GoldSilverado's Avatar
Member ID: 12441
Post Disable Headlight Twilight Feature (Auto On)
I have read several posts asking for information on how to disable the twilight (auto on) feature on the headlights of 99 FSCs.
I wanted to do this myself so I searched and found several methods of doing it.
This is the easiest. You don't have to take the dash apart or cut any wires. Just a simple in line resistor.
Here it goes:
To disable the auto headlights you need a 1.5K ohm resistor (Radio Shack) and 2 Scotchlok Tap Connectors (Walmart).
First locate the Body Control Module (BCM) which is under the dash, below the steering column. Laying on the floor, this should be visible without removing any dash panels. You should find a purple connector (C3). Unplug it.
Locate the white and gray wires (A4 and A6). I don't remember if white is A4 and gray is A6 or vice versa. It doesn't matter anyway. BTW - there are two gray wires in the connector. The one you want is the one farthest away from the white wire.
Tap the gray wire from the plug (C3) to one end of the resistor and the white wire to the other end. You don't need to cut the wires. Make sure you tape up all wires to prevent a short. You should now have a gray wire coming from C3 tapped to one lead of the resistor and the white wire from C3 tapped to the other resistor lead *. Plug C3 back into the BCM. Start the truck and make sure the lights are off. Throw a dark towel or something over the light sensor on the dash and verify the lights stay off. Try your light switch that has probably never been used and that's it! Takes about 5 minutes.
*You can add a switch here if you want. Just connect one end of the resistor to one of the wires in the connector (doesn't matter which one) and the other end of the resistor to one side of the switch. Then connect a wire from the other side of the switch to the other wire in the connector. This will allow you to turn Twilight Mode on and off.
"There is no doubt about precisely when folks began racing each other in automobiles. It was the day they built the second automobile." --- Richard Petty
05 Harley-Davidson FLHRI: totally tricked out
99 Silverado LS Ext Cab 4X4: 5.3L Vortec, 3.73 rear, K&N, Flowmaster, etc., etc.
Old 06-28-2004, 12:02 PM   #2
JB
2008 NNBS
JB's Avatar
Member ID: 44
nice tech article
I did this to mine and alot of friends a year ago and it works great, I used a switch.
http://www.fullsizechevy.com/forum/s...t&pagenumber=2
2008 Chevy Silverado 1500 RCSB LT1,4/6 drop
my cardomain site
Old 09-10-2004, 02:33 PM   #3
nikon
Vroom Vroom
nikon's Avatar
Member ID: 17569
SWEET!! thanks alot...I really hate those auto headlights....I had to take my whole dash apart to do so on my camaro, this is alot easier
Old 06-17-2005, 02:27 PM   #4
tracetrimble
Member ID: 7417
Re: Disable Headlight Twilight Feature (Auto On)
i did this mod to my 99 a while back. i used a 1.5k ohm resistor, and mounted a maintained pushbutton switch next to the airbag disable switch. it worked great for about 3 weeks, and then quit working at all. the headlights are back to the way they were, as if the switch was not there. i checked the resistance, and i'm still getting 0 and 1.5k ohms at the blade connectors. i used those little snap type wire taps on the factory wires, which i've never really had a problem with in other applications.
has this happened to anyone else? i'm thinking possibly the PCM thinks i've moved to Alaska or something, and compensated for the extra resistance? only problem w/ that is i've left the switch off for a month or so, and it didn't correct itself. did i fry something, or possibly just lose connection somewhere else downstream?
TIA ~Trace
04 2500HD 4x4 Duramax/Allison, CCLB, LS
99 NBS Silverado Z71, 5.3L/4L60E, ECSB, LS
Old 08-03-2005, 01:37 PM   #5
castrol
castrol's Avatar
Member ID: 31362
Uh, can't you guys just push the 'dome over-ride' switch 3 times and disable it that way?
Works on mine.
Old 08-03-2005, 01:38 PM   #6
tracetrimble
Member ID: 7417
that doesn't work on '99 models.
Old 08-03-2005, 02:07 PM   #7
castrol
castrol's Avatar
Member ID: 31362
Really? I thought it worked on all of them. Oh well... just wondering.
Kills the DRL's too.
Old 04-21-2006, 03:47 PM   #8
tracetrimble
Member ID: 7417
Anyone know where the DRL module is on a 99 Silverado?
I did this mod on my Camaro, and it works perfectly: http://www.xse.com/leres/ss/drl.html
I think the pin you ground out is used for a DRL override button on the police packages.
Old 10-17-2007, 05:00 AM   #9
chaz2009
chaz2009's Avatar
Member ID: 58197
Is it possible for a dealer to turn this off with their scan tool ?
Old 11-20-2007, 01:38 PM   #10
savage420
Member ID: 48883
Hey does this first post work on a 02 ?
Also ive tried the push the 'dome over-ride' switch 3 times and disable it that way trick and i dont work ether .
Old 11-24-2007, 05:01 PM   #11
savage420
Member ID: 48883
Anyone?
Old 01-10-2008, 01:51 PM   #12
JB
2008 NNBS
JB's Avatar
Member ID: 44
Yes it will work fine
my cardomain site
Old 01-10-2008, 02:05 PM   #13
savage420
Member ID: 48883
Yeah the push the button crap to disable dont work on all 4 of our GM trucks in our family....i seriously dont think it works on ANY of them as it dont on 3 of my friends rigs also...no biggie though!!!
Old 03-12-2008, 04:29 PM   #14
juicedwagon
Member ID: 83680
i did this on my 02 silverado and it didnt seem to work, are the 02 chevys different?
Old 03-12-2008, 04:38 PM   #15
Nick
Member ID: 936
Because you live in Canada.
Old 03-12-2008, 10:36 PM   #16
savage420
Member ID: 48883
Whats the diff
Anyway i already modified mine with a switch to work with my H.I.D's
Old 03-13-2008, 04:05 PM   #17
Nick
Member ID: 936
Whats the diff
Aren't you guys required to run DRL's?
Old 03-13-2008, 07:45 PM   #18
savage420
Member ID: 48883
Who knows? LOL Nobody says anything to me so im not to worried about it
Old 03-14-2008, 02:15 AM   #19
Gerald
Its just my style
Gerald's Avatar
Member ID: 34064
This is how to dissable them on the 03+.......
This mod will allow full control over your lighting using the manual switch on the dash.
This is copied from Diesel Place,
The wires for the Light Sensor go to the TBC. The "J" connector numbers are molded into the TBC under each connector. The "A/B" are molded on the ends of the connectors and just count wires to get to the right terminal.
Connector J3 terminal A4 = white wire for sensor
Connector J4 terminal B7 = black wire for sensor return
If you have auto climate control the black wire is shared with the left and right solar controls.
You could jump a small piece of wire between J3-A4 (white) and J4-B7 (black) to disable the Light Sensor.
If you have manual climate controls the black wire only goes to the Light Sensor so you could cut J3-A4 (white) and J4-B7 (black) and connect them together. Just be sure to connect the wire on the TBC end and not the ones going to the sensor.
No More Auto Headlights!
He used a little blue wire for the jumper. I found that leaving them pluged into the BCM, and using a small paper clip is alot easier.
Basics are...
Find the J3 plug, then the A4 (white) wire, jump a paper clip from this wire, over to the J4 plug, to the B7(black) wire.
I used heat shrink tubing over the paper clip to only expose 1/2" on both ends so its not to short out on anything.
Hope this will help you guys too!
'04, 10-12 3rd Coast
'88 Toyota pu, 11" lift, on 40s.
'89 Burban, monster in the making
Old 05-01-2008, 05:07 AM   #20
Z71Truckin
Z71Truckin's Avatar
Member ID: 79723
Sorry but i dont get what this does. Does it keep your lights off 24/7. Or what does it do?
