Old 01-11-2007, 09:25 PM   #41
slammins15
V8 S15 Jimmy member
slammins15's Avatar
Member ID: 24837
Re: Fix Those Wipers (Wiper Board Repair)
sounds like a board problem to me
Old 01-12-2007, 07:37 AM   #42
'radolover
'radolover's Avatar
Member ID: 56626
Can't help but notice that it seems all broken weld points (between 1 and 7) are in area of harness connector. Suggests that whomever had responsibility for attaching harness may have been attaching at a critical angle or maybe made a last moment tug on the harness to make sure it was connected.
So it may be that GM used "defective" solder, but it would seem that a larger number of different year's trucks would have affected whereas a heavy-handed assembler would have probably affected only production on their shift, and then probably sporadically.
And since the factory recall was NOT for any solder cracks but for the H2O problem it would seem that this could be an unrecognized GM assemly problem that might be worth GM's attention.
I have to say that it's a puzzlement why this problem apparently doesn't show up in later production vehicles. Without going back over the posts, it seems that up to '93 was about the limit of tjose affected. That doesn't account for solder very well, but it holds water for retirement/resignation.
Just a thought.
Old 01-12-2007, 10:11 AM   #43
slammins15
V8 S15 Jimmy member
slammins15's Avatar
Member ID: 24837
Just a thought.
This problem isn't limited to fsc only to 93 my truck is a 97 s15 jimmy and my uncles 98 fsc had the same issue.
Old 01-12-2007, 11:40 AM   #44
'radolover
'radolover's Avatar
Member ID: 56626
If it carries over to more recent production, like up to '97s, then the same employee(s) may still be doing a bit of rough handling.
And if the same/similar problem is continuing for so long it would STRONGLY suggest that a bad batch of solder is not what's
going on.
Old 01-17-2007, 12:10 PM   #45
lowc10
lowc10's Avatar
Member ID: 40288
i finaly got to check out the motor, it is not like the ones with the boards. so can i change it to one with a board, my wiper controller seems to have more settings than just a high or low.
Old 02-21-2007, 04:09 PM   #46
Ghoster
Ghoster's Avatar
Member ID: 62764
Just want to say thanks to whoever created this thread. I was about to go buy the entire wiper motor assy. I decided to do a little research first, and found out about the pulse board. I pulled mine out, and it had 2 or 3 breaks in it, hard to tell really. It was so corroded and messed up that it wasn't worth repairing. So I just bought the board. Problem solved. Thanks.
Old 02-21-2007, 04:21 PM   #47
slammins15
V8 S15 Jimmy member
slammins15's Avatar
Member ID: 24837
going on.
Its not employess doing the soldering its done by robotics and the problem is caused by not soldering with enough heat so you end up with cold solder joints that crack eventually.
Old 02-28-2007, 12:39 PM   #48
Busted Knuckles
Member ID: 55902
slammins15 is dead-on. I got a couple of months worth of Navy training on circuit card repair. Cold solder joints cause a world of grief and crack just like these described. They may have been wiggled when the solder was in it's plastic state between liquid and solid, may have been cooled too quickly, tough to tell. At any rate, you should put a small spot of flux on every point you intend to resolder so you don't introduce dirt, etc. into the joint and create another problem. Soak a small sponge in alcohol and use that to clean the board when you're finished and don't forget to seal it up good.
Old 03-01-2007, 02:44 PM   #49
Glockem
Starbucks Poser
Member ID: 64380
Originally Posted by TTlord
where is the fix for the rear wiper on a hatch suv?
Yes I would like to know this as well. I have a 1999 Tahoe 4-door and the back windshield wiper is working, but it stops past the correct stopping point for some reason. Roughly 6-7 inches past the stopping point. Is there a separate board for the rear wiper or is it part of the front wiper board?
Old 03-02-2007, 11:26 PM   #50
budnic21
Member ID: 64683
Little late on this but, try an external ground. I called an auto electrical shop and this was what I was told, tried it with a short wire and two alligator clips just to see and worked great. Almost free and fixed my problem. Just a wire from the motor housing to the body.
Old 03-20-2007, 03:29 PM   #51
bowtieboy42
Member ID: 62702
The wipers on my 98 stop working some times. I take it its under warrenty? Where could I go to get this fixed?
98 k1500 3" blocks, AAL, Cranked, K&N drop in, hi flow cats, 305/70/16 BFG MT
Old 03-27-2007, 02:05 AM   #52
gravelback
gravelback's Avatar
Member ID: 59022
I don't think that'd be under warranty unless you have a secondary kinda warranty...it's worth a shot but I don't think many warranties cover electrical stuff.
It's worth a recall check...ask TRITON20 in this thread.
Or just fix it and be done with it (and safe.)
'97 K1500 Cheyenne-ExtCab, 4.3L V6, (pretty much stock...for now...) Modded air intake w/K&N filter and rubber PVC fittings (<$10!), Vortec resonator box removed and "pop-canned", Taylor ThunderVolt 8.2mm wires, color-matched bed cap, over cap ladder-rack...She's a runner!
Old 04-13-2007, 05:34 AM   #53
coondogz71
Member ID: 59915
i plan on doing mine this evening
98 silverado z71 5.7 5spd ext. cab short bed k&n filter tinted windows reverse lights fiberglass cover bug guard
97 cheyenne 4.3 5spd reg. cab 4x4
Old 04-16-2007, 10:57 AM   #54
coondogz71
Member ID: 59915
mines a 98 and there wasnt a recall on it so i done it and they are on every time.
Old 04-18-2007, 07:39 AM   #55
BlazerBax
Member ID: 48062
93 K1500 Blazer here and I have never had a problem with my wipers (knocks on wood). All kinds of issues with the heat/ac units and the blower motor, but no wiper issues.
Old 07-13-2007, 06:02 PM   #56
import_fighter
Member ID: 15908
did this today and fixed my wipers....THANKS :)
Old 12-12-2007, 10:22 PM   #57
WAc1500
Member ID: 77376
Well, f&*k me! I thought I was the only dumb SOB with his hand out the window, in the rain pushing the stupid wiper arm to get it moving again. I too was ready to just suck it up, buy a whole new motor assembly and maybe even a new switch in an attempt to fix this.
Actually, my truck is possessed and hates my wife. Every single time she gets in it, the wipers start this crap. She doesn't even believe me that this doesn't happen nearly as often when she isn't in the truck. I don't know whether to fix this or not since now she'll want to drive it again!
Very cool thread and I will be picking up a soldering iron and some solder this weekend.
Phil
1992 1/2 Ton, Long Bed - 350/700r4
Mods: Edlebrock Performer TBI cam, lifters, springs, shorty headers
After cat flowmaster duals, MSD Blaster Coil, 180 Degree T-Stat
Stock computer and chip, no reprogramming
Old 05-13-2008, 12:52 AM   #58
gmctrucks
Member ID: 58218
Did mine that way years ago still working super easy fix.
Old 05-25-2008, 04:24 PM   #59
RSBAD454
Member ID: 42720
You are absolutely correct...I too have been trained via NASA soldering standards as well as J Standard. I had a similar situtaion with my 88 Honda Hatch back that had an intermittent starting issue. I found the main relay under the dash and pulled the cover off to find bad solder joints. I desoldered all of them and then reflowed with new solder and never had an issue after that. This holds true for the wiper motor control boards on our trucks. Use a good rosin core solder after you desolder and clean with IPA alcohol.
Old 07-04-2008, 07:15 PM   #60
CharlyG
Member ID: 91361
I went to the blob and slobber course in the Navy! J/K
I have the same problem and was about to throw money at parts!!
I love the internet!!!
Edit - I pulled the board and it is the same joint on mine. All the rest look ok, just that one cracked. I just resoldered and will reinstall in the am and do the test!
Well, it fixed the wipers, but not the washer......
1998 Chevy 2500HD ECLB 5.7L Vortec 4L80E 3.73 Posi
