Old 12-30-2004, 08:02 PM   #21
sgarmans
Member ID: 5066
Re: OBS Stock Floor Body-Drop how-to....lay that rocker
Jimmy, Thanks for getting the pictures back! I wanted to see where you cut the frame at the front of the cab. Does it have plenty of clearance? THANKS, Scott
Old 12-31-2004, 01:03 PM   #22
Jimmy P
GM Powertrain Engineer
Jimmy P's Avatar
Member ID: 65
If you have your cab off already it might be kinda tough to get just right but here is a pic of mine:
thats the pass side. I had to pound the lip up with a hammer..if i was to do it again i would have cut further up and made more of a slope. I was a pu$$y about cutting my frame when i first started
1990 454 SS // 1989 Silverado Project // 1999 Silverado Z71
Old 01-01-2005, 08:32 PM   #23
sgarmans
Member ID: 5066
Thanks Jimmy, I know what you mean about cutting the frame! I dont want to cut it any futher in front of the cab than needed.
Old 01-20-2005, 01:11 PM   #24
1998chevy1500
The Big Sky State
1998chevy1500's Avatar
Member ID: 5163
hey does one of the mods want to sticky this so it doesn't get lost??
conrad
“Learn as if you were going to live forever; Live as if you were going to die tomorrow.”
“In dating and mating, what is finally settled for is always a function of what is available.”
Old 01-20-2005, 01:22 PM   #25
CKTA
King of the Assclowns
CKTA's Avatar
Member ID: 66
Done!
Carlisle All Truck national info....
http://www.fullsizechevy.com/forums/...ls-2008-a.html
Old 01-20-2005, 02:49 PM   #26
1998chevy1500
The Big Sky State
Member ID: 5163
thankx
Old 01-20-2005, 05:16 PM   #27
DragginLowChevy
Member ID: 21754
You got any updates for dropping the core support?
If i understand right all you do is cut the frame between the
suspension and the core support and then weld it back in
lower down (as far as your BD was) and brace it. Correct?
Old 01-20-2005, 06:25 PM   #28
Sweet Tea Man
....Makin $hit happen....
Sweet Tea Man's Avatar
Member ID: 2294
cut it off at the shoe horns and drop it down, reweld, and brace. you are correct
jeremy
Originally Posted by Sweet tea man
Dude! We could work for the board of education.
Originally Posted by Crazed179
yeah. "what skills do you have guys?"...."uh....we can put lockers together like a mother ****er"
Old 01-20-2005, 07:06 PM   #29
Jimmy P
Jimmy P's Avatar
Member ID: 65
yea thats prob the best method ...i did it a little differently. Ill get pics up one of these days.
Old 07-03-2005, 09:50 AM   #30
fabitup
Member ID: 19283
we need an update please? I just learned alot in this thread. thank you Jimmy you are officially my hero.....
What type of welding machine did you use to do this? I have a millermatic 135 I dont know if it has the balls needed to do this job. Let me know what you are using. please.
Thanks, Josh
Old 07-03-2005, 10:51 AM   #31
Jimmy P
Jimmy P's Avatar
Member ID: 65
i use a Lincoln precision TIG 275 for just about everything on my truck. You would need something that welds up to 1/4" plate at least for the stock floor frame work.
Old 09-13-2005, 11:02 PM   #32
Low88
Drive and Enjoy.
Low88's Avatar
Member ID: 19385
sorry to bring up an old thread everyone, but do you have any recent pics of your cab floor jimmy... especially the driveshaft notch?
***tehhaterz
they always group them close together, but they never group them close enough to me
88 OBS 2.75" SFBD in progress
05 GTI - fun from the factory.
Old 03-26-2006, 08:32 PM   #33
sack
the underdog
sack's Avatar
Member ID: 5904
so how about those pictures of the core support??
what did you do to drop the bed? i bet it's relatively easy, but doesn't hurt to ask . . .
and just wondering about the x-cab situation, and using 3x4 tubing instead, does that mean you cannot drop it as far? or will there still be room for the 2.5 inches?
'97 under construction . . .
yeah it's static
a couple pics of my mower and custom box work
Old 04-14-2006, 08:08 PM   #34
madramper
Member ID: 45749
Is there any reason why you wouldn't weld the 2x4 to the top of the frame? Then you could cut the bottom off. Rather than drop the body, you would raise the frame.
Any thoughts?
Old 04-14-2006, 08:46 PM   #35
madramper
Member ID: 45749
You may have tranny alignment issues?
Old 04-16-2006, 08:24 PM   #36
Beyond Static©
Xcentric Customs
Beyond Static©'s Avatar
Member ID: 7315
Any thoughts?
then your front end suspension, tranny, and engine would hang too low, as well as needing a bigger notch out back to lay frame. You could Z the frame up front if you really wanted, as well as put a 3" larger notch out back. Thats how the 73-87's are done, but their frames only hang down 1" past the rocker, not 3" like the 88-98's
'98 Camaro Z28/GTP stage 2 5.3 heads/LS6 intake/F15 cam/Pacesetter LT's and ORY/cutout/2" drop/17" z06 wheels/SS hood
Old 04-16-2006, 08:25 PM   #37
cajundragger
fknlow
cajundragger's Avatar
Member ID: 14103
you would also have to pull 3 more inches out of the suspension thats probably already at its limits.
2000 ECSB, 5.3, magna flow cat back, some beat in the back and a killer front stage
Old 04-17-2006, 11:02 AM   #38
madramper
Member ID: 45749
I thought it sounded too easy! And my truck is a 95 Lightning. The frame is almost 4" below the rocker. I wanted to build a frame to ditch the Ibeams. I was going to do a Mustang II IFS up front and a T-bird IRS in the back. But its way out of my budget!
Thanks for the replies!
Old 05-13-2006, 01:25 AM   #39
98350ss
Member ID: 42110
Nice mod *bump*
Old 07-30-2006, 05:23 PM   #40
Imlayd
Imlayd's Avatar
Member ID: 48424
Is this the end or what.I want to see some more. Great job
