Old 08-07-2006, 10:31 AM   #41
Low88
Drive and Enjoy.
Low88's Avatar
Member ID: 19385
Re: OBS Stock Floor Body-Drop how-to....lay that rocker
just wanted to let everyone know that this is veryyyy time consuming, and not as easy as this thread makes it look.
low88 out.
***tehhaterz
they always group them close together, but they never group them close enough to me
88 OBS 2.75" SFBD in progress
05 GTI - fun from the factory.
Old 11-26-2006, 07:27 PM   #42
Low88
Drive and Enjoy.
Low88's Avatar
Member ID: 19385
hope nobody minds if i post my pics up.
My expected/unexpected headaches so far.
1. steering shaft wants to go through the frame.
2. passenger side exhaust manifold = reallllllly tight fit, watch how you modify that frame.
3. leave room for lower radiator hose
4. mechanical fan is not even worth putting back on, I just got a flex-a-lite black magic.
5. Trans tunnel had to be raised on the firewall itself, I thought you only needed to raise inside the cab.
6. Making an exhaust with a cat and muffler and squeezing it under a bodydrop chassis is quite a task
7. tapping holes in a boxed frame is tiresome
8. its pretty easy to modify the stock trans x-member, if you dont want to make a brand new one.
Other than that, everything is going smooth. I have taking my cab on and off down to a 2 minute process, literally... Air truck up, put jackstands under cab, lay truck out. The truck doesnt have a battery at the moment, and I have learned that you can use a 9V battery to operate selonoid vales, LMAO.
***tehhaterz
Old 11-27-2006, 06:05 PM   #43
DjLunchbox
king rigger reppin CAF I
DjLunchbox's Avatar
Member ID: 7624
looks nothing short of craptacular LC, just what i expected btw, what are selonoid vales? is this something new i should be looking into?
Old 11-27-2006, 06:06 PM   #44
Sweet Tea Man
....Makin $hit happen....
Sweet Tea Man's Avatar
Member ID: 2294
must be a northern thing
Originally Posted by Sweet tea man
Dude! We could work for the board of education.
Originally Posted by Crazed179
yeah. "what skills do you have guys?"...."uh....we can put lockers together like a mother ****er"
Old 11-28-2006, 03:44 PM   #45
Low88
Drive and Enjoy.
Low88's Avatar
Member ID: 19385
lol did you post this before or after i got off the phone with your ass. thanks for the veng vs. zeng clarification.
***tehhaterz
Old 01-28-2007, 09:45 PM   #46
giffer87
Bad ass 92
giffer87's Avatar
Member ID: 8470
what size of drop is actually needed to lay rocker? 2.5", 2.75, 3" i guess i could go out and measure mine, but i'm not too sure my body mounts are where theyre suppose to be right now... and do you have to loose your heater box when SFBD?
Old 01-29-2007, 03:51 PM   #47
Low88
Drive and Enjoy.
Low88's Avatar
Member ID: 19385
i went 2 3/4". Its getting shimmed up to about 2.5" which is perfect for laying rocker. I am running 255/45/17's and do not have to tub the firewall, and the heat is staying. If you are all about the big rollers, you will need to ditch the heat or relocate the box when you tub the firewall. You can lay rocker on a 255/35/20 tire though without tubbing the firewall. The firewall will need a little massage though.
***tehhaterz
Old 02-01-2007, 10:12 PM   #48
low_clazz
nfamusairsuspension.com
low_clazz's Avatar
Member ID: 9421
any more updates? mine is getting done as we speak...cant wait.
Old 02-02-2007, 04:22 AM   #49
Low88
Drive and Enjoy.
Low88's Avatar
Member ID: 19385
ill get new pics this weekend. pretty much all the chassis work is done... If my truck was in nice paint and had a nice interior, It would be done by now. Im just trying to go the full 9 yards now.
***tehhaterz
Old 02-04-2007, 08:08 PM   #50
giffer87
Bad ass 92
giffer87's Avatar
Member ID: 8470
Alright thanks for the info, ya ive got 265/35/22 sooo definatly would need to tub the firewall...
Old 02-05-2007, 06:24 PM   #51
Sweet Tea Man
Member ID: 2294
Originally Posted by Low88
If my truck was in nice paint...
when does that stage come?
Old 02-05-2007, 06:52 PM   #52
Low88
Drive and Enjoy.
Low88's Avatar
Member ID: 19385
after tax returns lol
***tehhaterz
Old 03-29-2007, 11:22 AM   #53
chevy6998
From longbed to shorty.
chevy6998's Avatar
Member ID: 23833
what happened to all of the original pictures, this thread use to be a great deal longer?
1989 SCLB, driv 22's, slam rs-72, custom 4-link and wattslink, 1/2 valves, nitrogen
1997 ECSB, stock, but not for long
Old 06-26-2007, 12:21 AM   #54
1l0burb
1l0burb's Avatar
Member ID: 70281
has anyone done a stockfloor on a square body burb
Old 07-07-2007, 11:52 PM   #55
Mr.showtime84
Member ID: 54711
Has anyone done a 97 tahoe 2wd 2dr? Plus I havea set of dropstar 05 24inch rims.........
Old 07-08-2007, 12:09 AM   #56
low94
OVER8TD
low94's Avatar
Status: Online
Member ID: 35681
Anyone have any info on some how reusing the rear section of the frame? Reason I ask is cause I have a 6 link and don't want to redo the suspension.
1994 K1500
9" lift
37" Pro Comps
Old 07-08-2007, 07:31 AM   #57
Low88
Drive and Enjoy.
Low88's Avatar
Member ID: 19385
you don't have to touch the rear section of the frame if you don't want to. you just have to tie the 2x4 into the frame right behind the cab. It has no affect on where your 6 link bolts to.
***tehhaterz
Old 07-08-2007, 09:08 AM   #58
low94
OVER8TD
low94's Avatar
Status: Online
Member ID: 35681
But then how would I lower the bed down?
1994 K1500
9" lift
37" Pro Comps
Old 07-08-2007, 09:11 AM   #59
Jimmy P
GM Powertrain Engineer
Jimmy P's Avatar
Member ID: 65
the bed floor essentially stays in the same place. You section 3" out of the inner bed sides/front wall and lower the outer panels only. You dont do anything with the frame in the back
1990 454 SS // 1989 Silverado Project // 1999 Silverado Z71
Old 07-08-2007, 09:26 AM   #60
low94
OVER8TD
low94's Avatar
Status: Online
Member ID: 35681
so you basically stockfloor the cab and conventional BD the box?
1994 K1500
9" lift
37" Pro Comps
