Old 05-28-2002, 09:44 PM   #1
wolfdog
HELL YEAH!
wolfdog's Avatar
Member ID: 948
servo swap instructions
These are instructions for the 700R4 & 4L60E servo swap. The servo is located on the passenger side about ½ way up the case. You do naot have to drop the tranny, or remove the pan. The pupose of this mod is to get quicker, more positive, firmer shifts. This should only take approximately 20 to 30 min.
1) To start, there is a plate covering the servo, remove this by using a 10mm socket.
2) Remove the retaining ring around the servo cover. Then with a pair of channel lock or vice grip type pliers, gently twist & pull the cover until you can see blue Teflon seal. Pull seal down enough to cut it. ( don’t worry, the new servo will have a new seal w/it. Check to make sure though!)
3) After removing the seal, remove the cover.
4) This next step can be done in two ways. Either remove the entire servo assembly or remove it in pieces. I recommend removeing the whole thing. It’s kinda snug, but can be done.
5) After removal, remove the e-clip holding the spring, the washer then spring.
6) Use either an expensive spring compressor or a $2 pair of c-clamps, clamp the cushion spring retainer and 2nd apply pistion together to remove the metel seal holding it together.
7) Once apart, the servo apply pin should pull through the servo assembly. (Some gentle coaxing w/a rubber mallet may be needed)
8) From here on out, simply replace the stock parts with the new ones & reassemble in reverse order of disassembly. Be sure to coat the new seals/rings with either trans fluid or vasoline.
9) One last thing, you should lightly sand the piston apply pin & the hole where the piston goes through with 400grit or lighter sandpaper on all the new parts until the pin moves freely, otherwise it may bind.
HAVE FUN & TAKE THE TIME TO DO IT RIGHT THE FIRST TIME!!
Old 05-29-2002, 12:21 PM   #2
Y2k+1 Z71
Sand slinger
Y2k+1 Z71's Avatar
Member ID: 225
Hey there bubba, good quick article. Got any pics? What about part numbers for the Vette servo/ misc parts? Add those and it'd be top notch (not bashing, just offering constructive criticism).
Webshots
2001 Silverado Z71
Lift:
Front end by Rancho - Rear end by Superlift (6" Leaf Springs), RS9000's, 4.56's with Auburn Pro LSD, 16x8 AR Bajas with 315.75 Xterrains
Exterior:
SmittyBilt Nerfsteps,Bushwacker Extendafenders, Bug Shield, GM bed rail covers, Xenon Bulbs, Tahoe Chrome grill surround, Billet Bowtie, Stull billet grill, APC clear corners...
Performance:
Helix Power Tower, HPPIII, UPD with homebrew RAM-Air, Flowmaster 50 series dual Catback
Old 05-29-2002, 04:33 PM   #3
wolfdog
HELL YEAH!
wolfdog's Avatar
Member ID: 948
thanks Y2K+1 Z71! i will post pictures/update article as-soon-as i format everything. for know the part #'s are as follows:
Part Numbers:
Piston: 8642079
Housing: 8673039
these too will be added to the revised version.
BTW,,,your input is appreciated, not taken as bashing!:)
Old 05-30-2002, 09:55 AM   #4
CKTA
King of the Assclowns
CKTA's Avatar
Member ID: 66
TTT for 5-8.
Carlisle 2009 All Truck National info....
http://www.fullsizechevy.com/forums/...aug-7-9th.html
Old 05-30-2002, 10:08 AM   #5
CKTA
CKTA's Avatar
Member ID: 66
Originally posted by 5-8CHEVY
So I should just ask him if the servo on mine and that part # are compatible???
Correct, tell him you want the vette servo and run those #'s by him!
Old 06-30-2002, 02:40 PM   #6
'02 SilveradoSS
Member ID: 764
So, you have to cut and remove the seal to get the cover off. If so, I guess that's why I couldn't get mine out.
Old 06-30-2002, 08:12 PM   #7
wolfdog
HELL YEAH!
wolfdog's Avatar
Member ID: 948
yup! the cover seal pretty much has to be cut to get the cover off. the seal will just pull out after being cut.:)
Old 08-29-2002, 04:05 PM   #8
DemoN
Premium Member #19
Insecure fat kid
DemoN's Avatar
Member ID: 721
Very nice tech article....and an interesting mod to consider.
Thanks Wolfer
time to take the truck apart again 5-8;)
Question: i don't have to remove the bed do i? my apartment people REALLY don't like me doing that :kidding:
Hell is oneself; Hell is alone, the other figures in it merely projections.
There is nothing to escape from and nothing to escape to. One is always alone.
Old 08-29-2002, 04:13 PM   #9
97Silverado
Premium Member #5
Original Gold Member
97Silverado's Avatar
Member ID: 347
We could do mine too but that's some scary crap messin' with the tranny.
you need to know what you are doing.....
Much like alcohol, tobacco, and voting there should be an age requirement for computer usage.
"Drag racing helps me get rid of all my extra cash."
Team credit card holder and crew chief - "Hot Rod" Heather JD4193 & Holly "Wood" JD4145
Old 08-29-2002, 04:17 PM   #10
DemoN
Premium Member #19
Insecure fat kid
DemoN's Avatar
Member ID: 721
coward
Old 08-29-2002, 04:52 PM   #11
wolfdog
HELL YEAH!
wolfdog's Avatar
Member ID: 948
Suspension is cake tranny is not.
actually, the servo swap is cake too!
Old 08-29-2002, 04:55 PM   #12
Y2K2Sierra
1 BAD GM
Y2K2Sierra's Avatar
Member ID: 751
The tranny is not that hard at all. I did the whole Transgo shift kit in my truck, not just the servo upgrade. It included dropping the pan and removing the valve plate along with many other things. Not hard to do. Just be careful and take you time. I'm sure you can handle it Izzy!!!
2006 Chevrolet Crew Cab
FOR SALE!!!
Old 08-29-2002, 04:59 PM   #13
wolfdog
HELL YEAH!
wolfdog's Avatar
Member ID: 948
what he said.
Old 08-31-2002, 01:49 PM   #14
Cop_Dodger
ASEP Grad
Member ID: 2065
Don't be Intemidated!
The sirvo isn't hard at all. Just be carefull. Things my get a little messy and make sure you put it all back together correctly.
"American by birth, Southern by God's grace!"
"Decide quickly, make your pitch, nail down the details, don’t worry about the money." - Billy Durant (Founder of General Motors)
Old 09-07-2002, 07:36 PM   #15
AtrickGMC
Member ID: 2568
I already have a shift kit on my truck, would the vette servo still be helpful? Also, my truck is the 4.3L v6, would it still work?
Old 10-09-2006, 10:33 PM   #16
04SilveradoMykk
Cars & Guitars
Member ID: 51778
Re: servo swap instructions
I'm considering the vette servo too... Whats the gain? I already have HPP3 firm shifts and thats pretty cool.
Old 10-12-2006, 03:29 PM   #17
keeler
Shake-N-Bake
keeler's Avatar
Member ID: 29400
The vette servos just firm up the 1-2 shift...
Originally Posted by Sierra Stud
I'm an idoit
2005 Silverado 5.3 Z71
Coming soon: Corsa, BlackBear Tune, vette servo, color matching, small JL System
Old 05-21-2007, 09:08 AM   #18
JoeliusZ28
JoeliusZ28's Avatar
Member ID: 14488
can this be done im combination with the B&M shift improver? also roughly how much are the parts? Im definitely interested in doing this.
-Joel
'98 Z71 SLT ECSB
Old 05-22-2007, 06:06 AM   #19
JoeliusZ28
JoeliusZ28's Avatar
Member ID: 14488
well i ordered one today, ill see how it goes. cant hardly turn down an $18 mod when my truck shifts like crap.
-Joel
'98 Z71 SLT ECSB
Old 06-20-2007, 02:29 PM   #20
JoeliusZ28
JoeliusZ28's Avatar
Member ID: 14488
figured id follow up here. I did the mod. I had about 3 minor heart attacks during the install, but its done. First I couldnt get the apply pin out of one of the stock pistons. Had to take a hammer to it (it didnt just fall out). The next heart attack was when i put it all back together and the snap ring shot out on me the first time it shifted to second blowing trans fluid everywhere. The third heart attack was when i realized I didnt have overdrive, which ended up being because the 2-4 piston was in backwards (unclear instructions).
All in all very good mod to do for $18 and im very happy with it now thats its in correctly. Id recommend doing it to anyone, however give yourself some TIME. it can be done in a half hour but chances are its gonna take you a LOT longer than that. My problem was that i had to do it at a friends house within a time frame, so problems led to panic. --- dont let that happen. I could probably do it in a half hour now that ive done it once, but the first time it definitely took me a while.
-Joel
'98 Z71 SLT ECSB
