Old 06-09-2002, 02:43 PM   #1
GMC K1500 SC
GMC K1500 SC's Avatar
Member ID: 228
Thumbs up Upgrade front brake rotors & Lines:
Before:
After:
W/Stainless steel line:
http://james.jaguar.net/kctrading/Pi...2/SANY0082.JPG
Rear brake line installed:
http://james.jaguar.net/kctrading/Pi...2/SANY0083.JPG
Good idea to bleed/flush your entire brake system with dot 4 fluid. Got the rotors from Summit Racing for $93 each pads VGX were $34.95, Earl's Stainless Steel brake line kit for front and rear was only $69.95. Called them early Thursday morning and received them the next day at 2:30pm...via reg ups ground!!!
When bleeding your system...little trick is to only go half way on the brake pedal when bleeding as this keeps from eating the master cylinder bore seals up...as you don't want to go past the ware area...reason a lot of brake master cylinders go bad after a brake job!
Rotor wighted about 2 lbs more than stock units...also they are solid unlike the factory units which are a composite two piece.
So far so good...instructions say to take it easy on the brakes for 200-500 miles so that the pads and rotors seat in without excessive heat.
Ken
1996 K1500, Built 4340 forged 383 Engine, SRP 8.9 comp. Vortech V1-S-trim SC, 7.3L turbo diesel intercooler, BBK, Thorleys, Crower 401LM, Crower roller rockers 1.5, Custom ported big valve vortec heads, TunerCat Edit Programing, 4.10 gears, BFG 33's
Old 06-15-2002, 11:14 PM   #2
VicRed4.8
Member ID: 1321
The new discs look bada$$
Old 06-16-2002, 08:23 PM   #3
BigChevMan
Know-It-All
BigChevMan's Avatar
Member ID: 272
well? is it a mucho improvement over the stock mushy crap?
Never argue with idiots, they drag you down to there level, then beat you with experience
Old 06-16-2002, 08:28 PM   #4
Loki
In The Mud
Loki's Avatar
Member ID: 52
No doubt....i need to get my pads replaced...thanks for reminding me...
Old 07-07-2002, 10:23 PM   #5
gb7c
Member ID: 1824
Nice!
Nice job, I'm lookin' to upgrade my 95' Chevy brake lines to stainless. Flex hoses and rigid tubing. Any idea where I can get a complete pre-bent brake line kit???
1995 K1500 4x4 EXT. CAB 5.7L
Old 07-28-2002, 07:20 PM   #6
GMC K1500 SC
Member ID: 228
Stops much better with a better pedal feel...now I need to redo the rears!
Ken
Old 10-05-2002, 11:56 PM   #7
GMC K1500 SC
Member ID: 228
After driving it 6,000 mile the pads are holding up great with very little ware...I do get a little squeel but only once in a while...with the stock rotors and pads I use to eat up the pads really quick...also had lots of brake dust...higher recommend this setup!
Ken
Old 10-06-2002, 06:05 PM   #8
BigChevMan
Know-It-All
BigChevMan's Avatar
Member ID: 272
Ken
You can't have them turned though can you? So your stuck payint 93 bucks x2 every time you need rotors?
Old 10-06-2002, 06:30 PM   #9
GMC K1500 SC
Member ID: 228
Only on the ones that don't chafer the holes!
These are chaferd so they can be turn with no problems :)
Ken
Old 11-24-2002, 11:16 AM   #10
GMC K1500 SC
Member ID: 228
After driving it 10,000 miles the pads still look almost like new...with my old rotors they would of been 2/3 wornout!
I do get a little bit of squeel from time to time but not enough to bother me.
Ken
Old 07-21-2003, 05:20 PM   #11
Yukoneer
cut 'em off!
Yukoneer's Avatar
Member ID: 2493
i cant accesss the pics.. need username and pswd :-(
Old 07-21-2003, 11:26 PM   #12
GMC K1500 SC
Member ID: 228
Seem to be working ok now :)
Ken
Old 08-16-2003, 02:41 AM   #13
GForceSS
Up the Irons!
GForceSS's Avatar
Member ID: 6680
Ken
I can vouch for that. I just had my Powerstop rotors turned at a machine shop. No problem. Is that what type yours are?
2008 Chevy Avalanche LTZ. 6.0L, 6" lift, 20" Rev Rims, 35" Toyo M/Ts. All factory options.
Old 08-16-2003, 12:25 PM   #14
GMC K1500 SC
Member ID: 228
Yup same brand :)
Ken
Old 09-08-2003, 07:16 PM   #15
GloNDark
GloNDark's Avatar
Member ID: 8811
Do you have the actual part numbers for the rotors from Summit? I am heading up there this weekend to get some parts for my rock crawler and I have been dying to do something about the brakes on my 97 GMC. THANKS!
Chris
Muffler Bearings - On sale this week only from Glow-Fab for $99. Get yours now!!
Old 12-02-2003, 12:20 PM   #16
9chevy4
Little Andy
9chevy4's Avatar
Member ID: 4838
Just got mine brakes& rotors
Old 07-30-2004, 01:49 PM   #17
sfblho
Member ID: 16831
will these work on 99's also?
Old 09-02-2004, 12:44 AM   #18
GMC K1500 SC
Member ID: 228
Just keep it fresh....now that the 14 bolt is in place I may upgrade to rear disc brakes as well as the 11" drums are boat anchors!
Ken
