#1 |
Built Not Bought
Member ID: 1279
How to burn Proms for TBI trucks
For too long the practice of programming computer chips has remained a voodoo black magic art to many left only for the Tech Nerds and witch doctors. This has left many scared off by fuel injection as a viable performance induction system. Though with advances in technology equipment has become readily available to the public at affordable prices and many die hard enthusiasts have developed their own software programs to feed the need for speed of many speed freaks.
Equipment The equipment needed to get into chip tuning is not very expensive. You need a computer, a programmer, light eraser (optional based on programmer choice), word editor, file definitions, scanning software, and a few spare chips. The total cost for all of this equipment, not including a computer, is usually about $300 or less. We will also discuss about cool toys/options such as emulators allowing for real time tuning. Computer Chips There are two different types of computer chips that can be used. The first is a standard chip, which uses a UV (ultra-violet) light to erase the information stored on it. The other type is a flash programmable chip. A flash programmable chip uses voltage to erase the information. The new information is basically written right over top of the old information. The 87-91 stuff uses a 2732 24 pin chips. I’m pretty sure the 92 stuff uses the same as well. But in 93 with the move to the electronic trans and gm moving to the memcal in the TBI trucks the chips went to a 27C512 28 pin chip. Know if you want the flash programmable version you are looking for a 27SF512. Also another thing is the chip speed which can vary from 250ns to 50 ns but it is commonly agreed that you can use just about any speed without problems. Though, I usually run a 90ns chip. There are chips which are called OTP’s. The OTP means One Time Programmable. Like the name says they are only programmable one time. You don’t want these. Check out www.jameco.com www.digikey.com Adapters In applications with a memcal you will want an adapter so you can put your newly programmed chip in while still retaining the calpack on the memcal. You can use an adapter from a previous chip like jet or Hypertech or you can buy one from Craig Moates at www.moates.net Craig sells all kinds of equipment ranging from cables, emulators such as the AutoProm (More on that later), and chips etc. as well. Check his site out. You can also make your own using an old memcal and a zif socket. The memcal in 93-95 trucks has both the EPROM and calpack (the calpack contains the limp home mode information) in the memcal which is connected to the board via a dual row header connector. A stock memcal looks like this ![]() A memcal with the cover removed ![]() A modified memcal with a ZIF (Zero Insertion Force) Socket ![]() A modded memcal with ZIF and a chip ![]() You can also use an adapter like a Hypertech or a jet. This is what I use because I bought a hyperjunk excuse me Hypertech back before I even knew I could do my own. Here’s what it looks like ![]() Programmer The programmer is what “writes” the .bin (binary) file, or BIN for short, on the computer chips. When using standard erasable chips, any type of programmer can be used. If flash programmable chips are being used, a programmer that is capable of handling flash programmable chips is needed. Most programmers communicate via serial port so make sure that your computer supports this. Many guys use the Pocket Programmer 2 (PP2 for short) which can be found at www.xtronics.com Pocket Programmer 2 Part # I-PP-2 Price 149.95 http://www.xtronics.com/memory/EPROM.htm UV (Ultra Violet) Light Eraser The light eraser is optional depending on which type of chip used. If a standard chip is used an UV (Ultra Violet) light eraser is necessary. The light eraser uses an ultraviolet light to erase any information programmed onto the chip. The light eraser usually takes 15-20 min to erase a chip depending on how many times it has been programmed and then erased. As they get older they take longer to erase. If a flash programmable chip is used, then a light eraser is not needed. I use the DataRase II DataRase II Part # ER2-ND www.digikey.com Word Editor The word editor is used to read the BIN, which is the information on the computer chips that control engine management, and make modifications to the various values in the BIN. There are many different editors to choose from. Choosing one will depend on how much money you are willing to spend and how popular of an ECM (Engine Control Module) the vehicle has. Winbin is a very popular word editor. Winbin is free and that is part of the reason why it is so popular. It is a very good program, but file definitions are hard to find for it for some ECM types. There are only file definitions for roughly five of the most popular ECM. File definitions tell the word editor where to read the information from the computer chip. Tunercat is an excellent program that almost every programmer probably owns. Tunercat costs $80 for the editor and another $20 for each file definition. Tunercat comes with the $42 definition file. This definition file is for 87-92 TBI GM trucks. It is very easy to get file definitions for any GM ECM or Holden ECM. Tunercat has also introduced TunercatRT (RT meaning Real Time) which allows it to be used with an emulator for real time programming changes to be made. Another of the more popular editors is GMEPRO. GMEPRO costs $100 for the editor itself and another $30 for each file definition. Another program which is becoming quite popular in recent times is Tunerpro. This program not only changes bin files it can also datalog when used with the appropriate .ads file. TunerproRT has a built in scanning/datalogging feature since it was developed to be used with the AutoProm emulator (more on that later) so it can simultaneously edit bins and datalog (a BIG thanks to HaulinA$$ for all of that info) Check out http://tunerpro.markmansur.com/ for information on it. It is free but I highly recommend you donate $30 to register it. Scanning Software The scanning software reads the data stream from the ALDL (Assembly Line Data Link) port and displays the engine/power train information allowing the tuner to know what to change. The best part is that the scanning software can be found for free on the Internet. There are two different types of scanning software for the two different types of GM computer systems. The early 87-91 TBI (Throttle Body Injection) systems all have a 160 baud rate and for this you can us WinALDL. WinALDL can be downloaded for free from http://w1.601.telia.com/~u60113744/...ldl/winaldl.htm WinALDL was created by Jonas Bylund. I have not been able to get WinALDL to work on the later 92-95 TBI vehicles. I believe this is because the later ECM’s have an 8192 baud rate which is indicated by the fact the computer sends its information to pin M on the ALDL connector compared to the 87-91 which send to pin E. All TPI (Tuned Port Injection) systems have an 8192 baud rate. These systems can use software created by Craig Moates. It can be downloaded at no cost from www.moates.net Again another one to check out is the Tunerpro program. But when using this software make sure to donate money to these guys. They have invested all of their time and effort to create software which they have made free to everyone but would greatly appreciate any rewards for their efforts. Another great datalogging software package is also available. It is Datamaster and it is my datalogging software of choice. It’s a full blown professional package but at only $100 it is well worth it. More info can be found at http://www.ttspowersystems.com/diagnostic.htm ALDL Cable Both of these types of software need an ALDL cable to connect a computer to the ALDL port. There are two mainly different cables. There is a cable for 160 baud rate ECM’s and another for the 8192 baud rate. There are some schematics that show how to build an ALDL cable that will work with both types of ECM’s and this is the cable Ive built and use. The schematics for the cable I use can be found at http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm The cables for the 160 baud rate ECM’s receive data from the computer through pin E while the 8192 baud rate ECM’s receive the data through pin M of the ALDL port. Cool Toys/Equipment Emulators Emulators are a great tuning tool if you can afford one. The AutoProm made by Craig Moates is a great choice and allows for datalogging and programming modifications at the same time especially when used in conjunction with TunerProRT (RT being Real Time). The ability to change values in real time can also be a curse if it is not used properly. Remember if you have to drive do not try and tune at the same time. Let me repeat that. DO NOT TRY TO TUNE AND DRIVE AT THE SAME TIME. If you are doing this get someone who you trust to drive while you tune or vice versa. Another thing to remember is to go slow with changes and make abrupt changes. What Changes Can Be Made? There are many changes that can be made to an engine’s operating parameters in a computer chip. There is a full list of parameters that can be changed when using any of the definition files with Tunercat at http://www.tunercat.com/tnr_desc/do_tc.html Getting Started Many times the beginning tuner will want to dive right in and want to burn the perfect chip. This is not possible. The average tuner will burn anywhere between 10-200 chips in search of the “perfect” chip. I say “perfect” with quotes because this is really a mythical thing since you can never have a perfect chip as there is always something can be modified a little. But a good chip can be had quite easily and a great chip can be had with lots of time and effort. Quite often what happens is that the first time tuner will post a question similar to this: What do I need to modify in the BIN for my 1994 C1500 with a TBI 383, with a Holley 2” TBI unit, with 90 lb injectors, Holley TBI intake, heavily ported and polished World Products Motown 220 heads, Comp cams 218/226 cam, 1 5/8” headers, dual exhaust, 160* stat, 4.10 gears, 2400 rpm stall, and a shift kit??!!?? If only it was that easy to tell someone what to do. When first starting out programming, the beginner tuner should start out very slowly. Begin with the easy stuff and slowly start to work into harder and harder tuning modifications like 3D tables. Most BIN’s can be broken into three elements that the tuner can change. These are flags, constants, and tables. Flags are basically switches. They are either On or Off. Some examples are: 1. Enabling/Disabling Functions 2. Enabling/Disabling Diagnostics (EGR, VSS) Constants are single values. The values remain constant no matter what the operating conditions. Some examples are: 1. Injector Flow Rate 2. Minimum Base Pulse Width (BPW) both Async and Sync 3. Fuel Cutoff speed (mph and rpm) 4. Torque Converter Lock and Unlock Speeds Tables are sets of values that are relative to each other. There are two dimensional (2D) and three-dimensional tables. Some examples would be: 1. Target Idle vs. Coolant Temp. (2D) 2. Pump Shot vs. Differential TPS (2D) 3. Volumetric Efficiency (VE) vs. RPM vs. MAP (3D) The tuner should start slowly with flags, once you have mastered that then move onto constants and then onto 2D tables. Finally after you have mastered these, then the tuner can move onto 3D tables. This allows you to become accustomed to your new software, equipment, your car, and what changes need to be made. Now we can break down the radical combination suggested earlier into simpler questions the tuner should be asking himself. 1. I am using 90 lb injectors. What do I need to modify to compensate for the larger injectors? 2. Modifying the intake system with the Holley TBI unit, Holley TBI Intake, and heads will have what effect on the Volumetric Efficiency and airflow characteristics of the engine? 3. What am I seeing when using the scan tool? Is there any knock retard and what are the fuel trims (BLM and INT) at various conditions? 4. How does a bigger cam affect the fuel curve? Some of these questions relate to actually changing the BIN while others relate to general engine theory. Being able to program a BIN requires a good knowledge of engine theory and a way to see how your engine is running. The truck is equipped with a Holley TBI intake, which does not have enough room to mount an EGR valve on it. The owner is probably getting a check engine light that indicates an EGR valve not functioning properly. I would suggest getting started by disabling the EGR function and then burning a new chip. Once you have burned the new chip, see if this fixes the check engine light. If it does you have successfully worked with flags. The combination uses 90 lb per hour injectors on a 383. Since the 90 lb injectors are bigger than the stock 61 lb injectors and the cylinder volume (per cylinder) of the 383 is bigger that that of a 350. The tuner should then start modifying some of the constants such as the Injector Flow constant in order to work with the larger fuel injectors. He should also change the Cylinder Volume (per cylinder) to compensate for the larger cylinder volumes of a 383 over 350. A reasonable place to begin with 2D tables for the above combination would be the Target Idle RPM vs. Coolant Temperature table. The cam is much bigger than stock and probably requires a higher idle. Unlike constants in which you only have to change one value in tables, you will have to change multiple values. There are different idle speed settings for different coolant temperatures. I have only scratched the surface of possible modifications that can be made. The only person who can really decide what is right for their combination is the owner. Tim Siford from Thirdgen.org best stated the art of tuning when he said: “Please note that everything you need regarding advanced techniques as they relate to BIN modification is not listed in an article for you to read anywhere on the internet. What you need to know cannot be found in some book that you can buy on Amazon.com. They exist in scattered articles, message board subjects, mailing list discussions, and old archives.” For more info on tuning theory read my other tech article PROM Burning Theory 101 in which I get much more in depth on the actual tuning aspect and theory behind which modifications need made and where. Good books to read are: How to tune and modify Chevrolet Fuel Injection by Ben Watson Other sites to check out are: Thirdgen.org both the diy prom section of the message forum and the Programming PROM’s for your Thirdgen Fuel Injected F-Body: Part 1 Introduction located HERE Josh *DISCLAIMER* The tuner is responsible for all damage incurred through their actions or inactions. I take no responsibility for any changes made, damage done, or for the accuracy of any information provided
94 Burban - too much to list
04 Dmax |
#2 |
shake & bake
Member ID: 658
Great job!
![]() I am still running the stock chip I know I need a custom chip but I really dont want to pay the 300 and still have to learn by trial and error what values should be changed.
08 TBSS
91 HD 3/4 ton 03 Z71 Tahoe ![]()
#3 |
Built Not Bought
Member ID: 1279
Thanks. Ive got a lot of time in it. This was originally for a paper I wrote and I thought alot of guys could use it. Really it is pretty easy If you understand engine theory. Some good stuff to read if you have the time is Robert Rauscher's papers. If you want maybe later on once I get some more tuning experience I might be able to try and help you out with a chip. I want to get some more experience before Id do anything for someone else though.
Josh
04 Dmax |
#4 |
Member ID: 1451
Way to go...Very cool article.
2002 GMC
2/4 Hotchkis, 20x8 Centerline Lancers, X-Pipe w/Flowmaster 40's, Escalade handles, LS1 Edit, LT1 Fans. |
#5 | |
shake & bake
Member ID: 658
Thanks. I'll see what I can find. Thanks for the offer. The main reason I don't have a custom burnt chip in it is because I think to do it properly, the tuner must have the truck in front of them on a dyno.
08 TBSS
#6 |
Built Not Bought
Member ID: 1279
Heres a bunch of links I have that you guys can probably use. Pretty soon Ill have some pics of my modified memcal with a zif socket in it.
Well here they are. winbin file definitions and lots of other stuff ftp://ftp.diy-efi.org/incoming/ thirdgen.org diy prom page http://www.thirdgen.org/techbb2/foru...?s=&forumid=16 thirdgen.org prom burning article http://www.thirdgen.org/newdesign/tech/promintro.shtml WinALDL (Application list, how to build a interface cable, etc) http://w1.601.telia.com/~u60113744/s...dl/winaldl.htm DIY EFI bins, and lots of other great things ftp://ftp.diy-efi.org/pub/gmecm/ Craig Moates page (zif to ecm adapters, tpi scanning software, etc) http://moates.net/gmecm/index.html AKM cables(buy various interface cables and some scanning software w/ links to lots of other software) http://www.akmcables.com/ ECM guide for gm cars ftp://ftp.diy-efi.org/incoming/gmecmlist.html Chevytalk efi forum http://www.chevytalk.org/threads/pos...t=&Board=UBB12 DIY EFI main page (links to lots of stuff) http://www.diy-efi.org/diy_efi/ How GM EFI works (great explanation of most terms you'll need to know and some various links in the second link which are helpful) http://www.customefis.com/GMEFI.html http://www.customefis.com/index.html Im sure there are more but I cant think of any more. If you have anymore to add add them. Josh
04 Dmax |
#7 |
One of the Few
Member ID: 1110
do you think that burning your own prom would be much harder if you had a superchareger amungst other mods like heads and intake?
adam |
#8 |
Built Not Bought
Member ID: 1279
Im not 100% sure on how they tune for a blown application. But here is my theory. Since a 2 bar map (or even a 3 bar map) is going to put out the same voltage range as the stock map except that instead of vacuum it reads boost. So I think youd need to delete every other column in the table then shift everything over and that would be for non boost situations and then youd fill in the rest of the table. though Im not sure on that. You could try thirdgen or diy-efi to see what they say. Im assuming you already have a chip to start from then. If so that would help alot because you can get a feel for what was done. If not I could definitely be done so long as you take thge time to educate yourself and dont mind spending some time tuning. Any other ?'s let me know
Josh |
#9 |
One of the Few
Member ID: 1110
I love tinkering with my truck, and after I massaged all other parts of my truck over and over...the engine is next on the list. I have decent mods to the engine already like my wipple, msd stuff, and e-fans, but Someday I would like to put an intake, vortec heads, and cam on. I do not want to get rid of the whipple just make it all that much better. Whipple gives you a chip to replace the fatory one, but they are setup to go on a stock motor. I know a bunch of burning will be necessary. I got the truck dynoed with air fuel readings, and the guys there said my air fuel curve was unreal. There wasn't a ripple in the thing just an everso slight dip down then back up. With the new mods I would expect to get back to that point through the proper settings on the chip. So I can read the settings off the new chip and go from there? This is not a near future install, but the research is. I read your tech article and will start with the links you provide. Thanx and expect more questions to come.
adam |
#10 |
Built Not Bought
Member ID: 1279
Adam,
Hey no worries about the ?'s. How do you think I learned. Im still learning. But having that whipple chip will make it much easiar on you. You can use that as a baseline and use it to see what they did. In fact if you do start burning chips and you copy that .bin file from the chip I wouldnt mind having a copy ;) So I can figure out how they did it so when I go to TT mine I'll know. Josh |
#11 |
One of the Few
Member ID: 1110
will do. now just got to do some reading....at least the money to do it will accumulate. so much to read no time to buy and burn cash on other things. I was searching for stuff on bbc tbi and i came across the impalassforum.com, and their forum is the same format as this one. They also have an entire forum for pcm programming and engine management. fyi.
adam |
#12 |
Built Not Bought
Member ID: 1279
Would you happen to mean http://www.impalassforum.com/cgi-bin/ultimatebb.cgi Im a member there also. We're thinking about buying an Imp SS so I joined. Good place with some knowledgeable people. I also bought an LT1 intake complete from TB to Injectors, all roller cam stuff (roller lifters, spider plate, lifter guides, pushrods etc) for 140
Waiting on the guy to call and tell me how much shipping is gonna be.Josh |
#13 |
One of the Few
Member ID: 1110
yeah thats the one. i love the 94-96 impalas. Was thinking about a caprice to mod...i actually fit in them, and the insurance company would choke me to death with bills if my car said ss on it from the factory. It would give sleeper a whole new meaning.
adam |
#14 |
One of the Few
Member ID: 1110
well i understand what you mean by your modified memcal with installed zif socket. I was thinking last night that i want to do this as soon as i can cause i have a couple constants that i need to change....i.e speed limiter or fuel cut off.
adam |
#15 |
One of the Few
Member ID: 1110
oh i understand. I read the thirdgen page....i know i have a memcal and was gonna ask you which meathod you used. I will go the same route most likely cause soemwhere i have a dynosoures chip kicking around, which is great cause it is a piggy back like the jet or whatever. Just got to find it. I am glad i have it cause I liked the way my truck shifted much better with the dynosource's "chip" much better compared to stock, and they turned off the speed limiter or at least raised it. So that will give me a great place to compare bins to get some of the things done that I want to right off. I have two memcals [stock and whipple] and that dynosources piggyback. When I get going I will gladly give you the bins to the two non stock proms.
Okay now a question. When you go with the piggy back...you can put a zif on the piggy back if it does not have one correct? And the second part is are you supposed to erase the the prom in the memcal when you run it attached to the piggyback[after you read the bin from it and save it on a computer of course]? I am pretty excited about being able to do this. adam |
#16 |
Built Not Bought
Member ID: 1279
Yea you can install a zif socket in place of the standard socket on the piggyback. I plan to do this soon. But for right now I just keep pulling the chips out of the socket on the piggyback. Just use a small screwdriver and gently pry them up and out of the socket. Try to pry evenly on each side otherwise you'll bend the pins on the chip. Pretty easy to do and Ive done it. The zif socket is nice because you dont have to worry about bending pins putting them in and removing them and with the standard socket over time it wears the pins on the chip thinner so they bend easiar. At least this is what ive heard from some guys but those chips also have had a thousand or more erase/burn cycles on them. Also when erasing chips dont erase them to long or it will destroy them. Ive been doing mine for 8 min. But Im gonna buy a new burner so I can do flash programmable chips. Plus the new burner will burn a chip in under a minute vs teh 8 it takes with my old school burner.
Josh
04 Dmax |
#17 |
One of the Few
Member ID: 1110
i think i am going to get a pocket programmer. Reading the webpage on it you can do FLASH, UVEPROM, EEPROMs. The software is windows based and it has "very, very" fast program times, which could be 10 i guess, but i assume 1-2 would be more like it. Is this a good choice. The thirdgen guy seems pretty impressed with it. and for an editor i think i will go with tunercat
#18 |
Built Not Bought
Member ID: 1279
I have tunercat and love it. The graphing feature is awesome and it helps me out alot especially making sure you dont have any holes in the fuel and spark tables. Ive heard alot of good things about the procket programmer. I dont have one but everyone says they are good. What year is your truck. You can download tunercat for free and use it for 30 days and if you have a 1227747 the download comes with the correct file definition. You can also download datamaster and use it for 20 runs for free. Datamaster
I really like it. You'll need an interface cable. If you want Ive got a schematic for the one i made i could send ya. It will do both 160 and 8192 baud ecms.Josh |
#19 |
One of the Few
Member ID: 1110
I have a 95. I have a different ecm. I have a $0D 16196395 or
16197427 94 - 95 C/K Truck, Van, 4.3L, 5.7L & 7.4L according to tunercat. I have my factory memcal infront of me and the number on top of it is 16200094, if that is relative to anything i don't know I was looking at this cable. Fully Assembled OBDI Cable w/OBDII Connector For OBDI cars with an OBDII connector This is a fully assembled cable. Most '95 model cars have this configuration. It will plug directly into your OBDII style ALDL port, no soldering is required. $ 65 Shipped to your door , but i will definitely take the schematic. I beleive I am 8192 baud rate. I downloaded the scanning software from Craig Moates. |
#20 |
Built Not Bought
Member ID: 1279
Ive got a 94 and have the 16196935 with the $0D definition file also. On the top of the ecm next to the 16196935 should be a group of 4 letters (BLJF for example thats what mine is) and this will be the broadcast code which is what program you have on your chip. Moates has scanning software for us trucks now. I did not know this. Last time i looked which was a while ago he didnt have anythign for us. THough he said he was working on something. I did not know the 95's had the obd2 aldl port. Thats odd makes things a bit more interesting. $65 that aint bad. Does it have molded cable ends or is just a crimp on style connector which plugs into it. Im trying to see If i can find molded calbe ends cheap and if I can Ill start making them for you guys for cheap. The cheapest Ive found with molded cable ends is $100.
