#41 |
Member ID: 33136
Re: Waterpump replacement for '96-'99 Vortec motors.
Sweet Victory. Did it last night. Got the Autozone new unit for 50 bucks. Had to rent the tool for the big nut removal. Very nice. Took my time cleaned it good. New fluid, ready for winter.
By the way this site is great, just reading the old posts really helped Thanks for the help.
"Stupid is as stupid does Sir"
99 Z56 Tahoe 5.7
#42 |
Did my 97 Silverado tonight. The job was a piece of cake - the hardest part was getting fan off. I used a 10 MM closed-end wrench and wedged it against the tensioner and a large pliers to loosen the nut. WD-40 helped as well.
Hopefully I got her sealed up well without leaks. Took about 1 1/2 hours to do it right, and I didn't have any extra bolts at the end which is good for me.
1997 Silverado Ext cab Z71 - 350...like new
Part of a GM family that has been buying GM trucks since 1956....proud to be a Chevy man |
#43 | |
Member ID: 46656
you didnt do something right then... |
#44 |
Homesick NBer
Member ID: 31582
Location: New Brunswick, Canada(working in Edmonton, AB)
i had to remove my fan the other day, thought the timing chain went, luckily no, it was the distributor cap, anyway it was the first time i ever had to wedge a bar into the 10mm bolts in order to tap the big nut loose, i was shocked, normally i get the big adjustable, and tap it with a hammer and its loose, but not this time.
1997 GMC Sierra 4x4 4.3L 4L60E KOSS CD player,16mpg,3.73 gears z71 skid plates 89 W/T Grille, fender flares coming.
![]() GM trained 2nd year apprentice at a Chev Dealer |
#45 | ||
Member ID: 59022
Can somebody please post some pics of these bad fittings and what they used to replace them.. Thanks
'97 K1500 Cheyenne-ExtCab, 4.3L V6, (pretty much stock...for now...) Modded air intake w/K&N filter and rubber PVC fittings (<$10!), Vortec resonator box removed and "pop-canned", Taylor ThunderVolt 8.2mm wires, color-matched bed cap, over cap ladder-rack...She's a runner!
#46 | |
Homesick NBer
Member ID: 31582
on 96 and up this fittings is on the intake, on the pass side of the engine. you can't miss it. the line you quoted from me was about the 95 tbi engine, where it is on top of the water pump, the fitting is the same but in diff spot. these fittings are made of aluminum, or some type of really soft metal. here is the best pic of i have of where it is on the 96-99 vortecs. http://i15.photobucket.com/albums/a3...e_view96up.jpg here is a pic of what some people use in its place(larger of course, i know its a pipe thread, can't remember the exact size, EDIT Dec 21, 2007 - Found out its 1/2 pipe thread. http://www.conexmetals.com/brass_hos...bs_nipples.htm
![]() GM trained 2nd year apprentice at a Chev Dealer Last edited by kenman1717 : 12-21-2007 at 09:37 AM. |
#47 |
Member ID: 47178
I rented the pulley holder and nut wrench from Auto Zone today. It didn't work for me. The nut wrench was slightly big and the pulley holder wouldn't fit over the pulley bolts securely enough to keep it from spinning, even with the belt still on. Took it back and I think I'm going to squirt it down with WD-40 tonight since its getting dark, and then whack at it with my big hammer and adjustable wrench tomorrow. Hope 50 whacks does the trick.
#48 |
OBS Preservation Society
Member ID: 70906
sounds easy i got to do mine this week sometime
![]() ![]() 1996 Chevy RCSB 350, 4x4, 4L60-E, 3" True duels, 3" PA body Lift, T-bars Maxed, 315/75/16 Toyo open country M/T's
#49 |
I need to do this job now. Great thread.
I was wondering if anyone knows if the Bosch 100% New Water Pumps any good? |
#50 |
You may want read this link before you start your water pump project:
http://gmfullsize.com/forum/showthre...ght=WATER+PUMP |
#51 |
Guys , I just got done changing my water pump on my 98 4x4 5.7
I decided to try the 15" Cresent wrench on the big nut with a few taps with a big ball peen before I started making a tool to hold the fan pulley. It took 8 or 10 taps and not hard ones either and she broke loose. Boy am I glad I tried that first. As usual I refer to this site before I attempt any repair on my truck. Every post has value here , thanks very much guys. You saved my butt again. ![]()
1998 reg cab Z71
#52 |
This is an awesome write-up. It helped me out. I wanted to add what I could to help out others.
A few pointers for others attempting this work: I was able to get the fan clutch nut loose by putting a 10mm wrench on the pulley-to-water pump bolts. I then put a prybar from the radiator support down to one of the casting bosses on the old water pump. The pulley spins, but the 10mm wrench jams on the prybar. Two taps with a rubber mallet on my 15" Crescent wrench and she was free. I can only say that those 6pt. Craftsman 10mm wrenches are pretty tough. If I had to do this again (or did it frequently for a living) I would make up a set of dowel pins to screw into the block. Then aligning the pump would be very easy. I could take out one dowel pin at a time and replace it with the bolt. But I did not take the time to see what thread size/pitch would be needed on the end of the dowel pins. Don't forget that you might get a little weeping out of the new pump. It takes a little bit for the new seal to become water tight. I bought my new thermostat at the dealer for a shocking $12. Torques: Water pump to block: 30 ft-lbs Water pump to pulley: 20 ft-lbs Thermostat housing: 20 ft-lbs (I don't know how much to put on the fan clutch nut) |
| Advertisements |
| Thread Tools | |
| Display Modes | |
