Old 07-12-2004, 07:33 PM   #81
uihockey2
uihockey2's Avatar
Member ID: 2767
no, the hole in the stock filter is much too big for the pipe, and there is no way to clamp it. ill just have to find a filter with a 3.5" hole.
Old 07-12-2004, 09:49 PM   #82
seansmitty42
Member ID: 16091
ive got the fipk 2 kit and it is badass. when i added it i know that it bumped the horses and torque up alot. plus the intake is louder than my exhaust which is two 40 series mufflers.
bada** rides are built not bought.
Old 07-12-2004, 10:33 PM   #83
4x4K1500
Classic's Rule
4x4K1500's Avatar
Member ID: 13631
Does anyone know if the pipe is replacable the pipe from the MAF to TB
Old 10-10-2004, 03:53 PM   #84
nebraskaz71
Forum Leader
nebraskaz71's Avatar
Member ID: 84
Re: Home made air intake for '96-'99 Vortec trucks.
I'm thinkn bout tryin to make new tube from maf to tb and then using the stock elbow to connect to maf and filter and just use lower part of box to hold filter, then remove silencer and i think it might work?
No its not stock height!
Click the signature!
Old 10-11-2004, 07:31 PM   #85
cooker2003
What tires...?
cooker2003's Avatar
Member ID: 11239
Here is a pic of my intake I made out of 3.5" mandrel bent exhaust tubing, a couple fernco couplers, a k&n air filter, and some galvanized sheet metal that I used for my intake. Seems to work good, the heat shield is painted black along with the exhaust tubing, and around the edges I just stuck some 1/2" rubber hose to clean up the rough edges and guard from scraping up the underside of the hood.
The filter cost me about $50, the tubing was around $20, and the couplers were about $6. The heat shield was just made out of some scrap I had lying around. It was relatively inexpensive compared to the kits from K&N, etc, and works good.
97 GMC K1500 Z71, Locker, 285 Discoverer STT's, Wester's Programming, Vette Servo, Rollpan, 2600 stall Converter, some other goodies...
Old 10-12-2004, 07:33 AM   #86
nebraskaz71
Forum Leader
Member ID: 84
How much do u want to make one of those cooker? :)
Old 10-12-2004, 03:39 PM   #87
cooker2003
What tires...?
cooker2003's Avatar
Member ID: 11239
Hmm, I'm not really sure, just pay for the parts and maybe a few extra dollars to cover my time
I am sure we could work out a deal for ya - shoot me a PM sometime
Dave
Old 11-01-2004, 05:56 PM   #88
JEEP FARM
JEEP FARM's Avatar
Member ID: 13324
Yes I am also interested in knowing!
Thanks, Jay
I love JEEPS but I love them more when they are powered by the mighty bow tie!
Old 11-04-2004, 12:02 PM   #89
HardcoreZ28
Owner RPM Resto & Custom
HardcoreZ28's Avatar
Member ID: 20208
Are most of you guys running the filter element open or inside the stock intake box? Cooker I like your design because it blocks a lot of the engine heat I bet. How do you have that shield for the filter attached in there? Any pics?
Also how much just for the mandrel bent pipe?
--== RPM Resto & Custom ==--
1997 1500 Pickup Z71
4" Suspension Lift
Torsion Bars Cranked 1.5 with Ford keys
5.5" Angled Rear Blocks
35 x 12.5 BFG All-Terrains
Old 11-04-2004, 04:45 PM   #90
cooker2003
What tires...?
cooker2003's Avatar
Member ID: 11239
The shield is attached to the wheel well from underneath, as well as to the inner fender with a bolt and wingnut, it fits in nice and snug too next to the battery, etc.
I can probably get some pics if you want them.
I got the exhaust pipe from a local Truck Shop, and I believe it cost me around $23.
Old 04-08-2005, 07:28 AM   #91
Mn02Sierra
formerly 97silvyz71
Mn02Sierra's Avatar
Member ID: 3034
could you post another picture of this up please?
Thanks!
Old 04-12-2005, 12:47 AM   #92
panchovilla209
Member ID: 25333
might be a dumb question but how do you block off the silencer?
Old 04-12-2005, 10:11 AM   #93
cooker2003
What tires...?
cooker2003's Avatar
Member ID: 11239
Thanks!
here ya go:
Old 04-12-2005, 11:53 PM   #94
ByRoN L
Praise the lowered!
ByRoN L's Avatar
Member ID: 26094
Thumbs up Re: Home made air intake for '96-'99 Vortec trucks.
That looks pretty good. I like the k&n with the box around it a little cleaner looking but your way is a nice cheap way to start.
Old 05-16-2005, 07:36 PM   #95
Bigtown88
2 n da pink, 1 n da stink
Bigtown88's Avatar
Member ID: 27758
I made an air intake this weekend using the info on the tech section. I think it was by CKTA. I also fabricated a heat shield out of galvanized sheet metal I picked up at Home Depot. Can tell an increase in throttle response but haven't been able to check gas mileage yet but will at the next refill. The next thing I'll do is eliminate the slinky with some hard pipe. Here are some pics of the before and after.
96 K1500 Z71 ECSB 5.7, Wait4me Tune, Dual Magnaflow SS Cat-Back, K&N CAI
Old 06-25-2005, 03:02 PM   #96
scottx
Member ID: 26373
Here's my version of the home made intake. It's on a 1996 Silverado with a 350. I plan to move the battery to the bed and convert it to cold air through the radiator support one of these days.
Before:
After:
Old 07-11-2005, 05:46 AM   #97
XXL
XXL's Avatar
Member ID: 19065
Any problems you forsee with this method? I've simply replaced the coupler-pipe-coupler method in CKTA's method with just a coupler connecting the throttle body throat to the MAF. I'll chuck on a K&N to the end of that for now, then fab up a shield/duct to get some colder air out of the fenderwell.
Old 07-11-2005, 05:53 AM   #98
CKTA
King of the Assclowns
CKTA's Avatar
Member ID: 66
The only things i see is that the elbow is very restrictive and the filter sits right over the manifold.
Carlisle All Truck national info....
http://www.fullsizechevy.com/forums/...ls-2008-a.html
Old 07-13-2005, 08:36 PM   #99
XXL
XXL's Avatar
Member ID: 19065
Originally Posted by juztyn
what model in particular k&n filter did you use?? and i have a 4.3 and a big airbox (pipe runs into the back of the airbox) so do i just take the whole thing out?? thanks...
Anyone got a K&N pn#? I'm doing a lookup on their site based on dimensions and these both look pretty good. Just wondering what people have been actually using.
E-0773 (though may be hard to find)
RU-1785
Old 07-13-2005, 11:31 PM   #100
98RhinoZ71
Member ID: 13355
I have a K&N FIPK would it do anything if i descreened my MAF has anyone descreened one with the FIPK on it? how did it run did you loose mpg? more power?...
