Old 01-16-2008, 07:01 PM   #181
mike2/4
Member ID: 78046
Re: Rear End Ratio RPO Codes Here
does an one no before i go mesher if a rear end from a 84 1500 will go wright in my 89 or are they different. Thanks
Old 02-04-2008, 06:19 PM   #182
pmrolfe
Run What You Brung
Member ID: 82807
is the GT4 an open diff?
1994 GMC 1500 stepside
-4" lift with 33's on American Racing Outlaw's
-two 10" subs
-eclipse deck
-dual flowmaster exhaust (no cat)
-Tranny rebuilt w/ HD internals, custom
converter
-Turbo Action shift kit
-Custom pinstriping
-3.73's
-edelbrock headers awaiting install
-2" cowl hood
Old 02-04-2008, 06:54 PM   #183
pmrolfe
Run What You Brung
Member ID: 82807
I tried to swap out an 87 10 bolt but it was a no go, brakes were way too big and the axle itself was 2-4 inches shorter. while the 87 was also a half ton like my 94, it wasnt even close.
-two 10" subs
-eclipse deck
converter
-Custom pinstriping
-3.73's
-2" cowl hood
Old 03-19-2008, 12:06 PM   #184
88Vic
88Vic's Avatar
Member ID: 83790
Mine is GU6, which is apparently 3.42, now how do I know is it's posi or open without trying to do a burnout?
http://www.grandmarq.net/vb/attachme...3&d=1203533989
95 Sierra 1500 "Warlock"
305 V8, 5-Speed Manual
Old 03-22-2008, 06:09 PM   #185
92blackchev
92blackchev's Avatar
Member ID: 78039
Where can you look if the stickers in the glove box are worn out?
92 Chevy 350tbi
175,000 mi
Rebuilt Motor
Rebuilt Tranny with shift kit
Dual Exhaust
265's
Old 04-05-2008, 09:18 PM   #186
chrisyarbrough
Member ID: 86673
i have a 1992 z71 ext cab with a 350 my door sticker and glove box sticker is wore out. tag is missing on rear but i got these numbers off the ring gear 3988517 11-41 G.M.K can anyone tell me what it means
Old 04-16-2008, 11:06 PM   #187
78freak
Member ID: 87740
i have a 78 chevy k20 and the info i got on the gear ratio's are 3.92 front and a 4.56 in the rear is this possible
Old 04-25-2008, 07:38 AM   #188
TransAmRobber
Member ID: 88239
If You Want The Rpo Codes For 1973-1987 Chevy Fullsize Trucks Go To Chuckschevytruckpages.com For One Of The Most Complete Lists I've Seen
Hope I Help'd
Old 04-26-2008, 04:18 PM   #189
kenman1717
Homesick NBer
Member ID: 31582
Location: New Brunswick, Canada(working in Edmonton, AB)
if you need to find your rpo codes if the list in the glovebox is worn off, take your vin into a dealer, they should be able to print you out the list.
1997 GMC Sierra 4x4 4.3L 4L60E KOSS CD player,16mpg,3.73 gears z71 skid plates 89 W/T Grille, fender flares coming.
GM trained 2nd year apprentice at a Chev Dealer
Old 04-28-2008, 07:50 PM   #190
94_Lifted_Z71
94_Lifted_Z71's Avatar
Member ID: 76832
I bought a 93 Chevy ECSB and someone has swapped out the rearend from the 10 bolt to a 14, where is the marking on the rear end to find out what gear ratio is in it. The only reason I know they changed them is because I ran the vin and it was supposed to have a 10 bolt. I am pretty sure it has a locker or posi in the 14 bolt because both tires hook up if it spins.
94 Chevy ECSB
Old 05-16-2008, 10:11 PM   #191
wjonnyd5
Member ID: 89205
41-11 is a 3.73
Old 06-22-2008, 08:57 AM   #192
ahhwataday
Member ID: 91188
daaaaaammm. I loooked at mine and I have gt5 g80. So its 4.10 posi
-Roy
