Old 05-16-2008, 04:36 AM   #221
RICK98Z
Lift Laws Suck
Member ID: 141
Re: Rain leaking into cab
Update: As per instructed by someone on gm-trucks.com I removed the black strip along the drivers side of the window. It has like 5 torx screws holding in on. Then I siliconed the area next to the top of the windshield where the roof seam overlaps the pillar seam. Checked it this morning in the rain and...dry floor! WOO HOO!!!!
Rick - 04 Chevy 2500 CrewCab 4x4 - 6"Procomp Lift w/35" Xterrains on 16x8 AR Pythons
http://community.webshots.com/user/rick98z
Old 05-16-2008, 05:02 AM   #222
CKTA
King of the Assclowns
CKTA's Avatar
Member ID: 66
Where are those 5 screws? Under the black moldng? Do you lift/pry it up to get to them?
Carlisle All Truck national info....
http://www.fullsizechevy.com/forums/...ls-2008-a.html
Old 05-16-2008, 05:16 AM   #223
RICK98Z
Lift Laws Suck
Member ID: 141
You pry back the door weatherstrip to get to them. The black molding strip has a lip that fits up into the door weatherstriping. I will try to get some after photos of where I siliconed when it stops raining here...
Old 05-16-2008, 05:18 AM   #224
CKTA
CKTA's Avatar
Member ID: 66
Ohh, this is for NBS trucks only right. I was wondering why I never saw that on my OBS trucks.
Old 05-16-2008, 07:52 AM   #225
RICK98Z
Lift Laws Suck
Member ID: 141
Yes this was for my 04'...NBS only
Old 05-18-2008, 05:18 PM   #226
RICK98Z
Lift Laws Suck
Member ID: 141
Here is the actual location of my repair work:
Old 06-08-2008, 06:58 PM   #227
tfaciszewski
Member ID: 56948
Re: Confirmed Fix For Passenger Side Leak!
I have a K3500 93 that is leaking like you described. I put silicone on the screw the second from the right on the passenger side and it still leaks. I am not sure which screw would leak into the air intake. Any help would be really appreciated. It leaks whenever it rains. thanks,tom
Old 06-10-2008, 11:49 AM   #228
1998 Yukon SLT
1998 Yukon SLT's Avatar
Member ID: 12781
On OBS:
Remove the plastic cowl. On of the cowl's anchor point is above
the air intake, this is the one that stips out and causes the leak, and it usualy happens when you have your windshield replaced.
I siliconed the crap out of the hole, let it dry, put more on then put the cowl back on. No more leak.
K&N FIPK
Flowmaster Force II Catback
Hypertech Power Programmed
Old 06-26-2008, 04:57 PM   #229
mikesec
Member ID: 91146
Thumbs up Re: Rain leaking into cab
ok,here we go i like most of you guys have a leaking problem on the pass. side of the cab, no it is not the heater core, a/c vent relief line. from what what i compiled from this site is uderneath the block off plate there is a fresh air vent. the seal on the vent needs to be re-sealed because the factory seal is junk. use plenty of black rvt dont be cautious on this. then reinstall the vent block off plate and put the cowl and wiper arms on. paint the area if you want but it is not needed
crossing the fingers hope it works once the rvt sets up
i will keep you guys posted
i was told by a friend at the local chevy dealership that on all 1996-2000 c/k trucks have this problem because the cowl was reformed in 1995 my farther has a 1988 k3500 and we removed the cowl on his truck and compaired it to my 1998 and they were completely different
ps: the truck only leaks when it is parked @ an angle because of the water pressure build-up against the vent wall/ seam
__________________________________________________ _______________
http://www.fullsizechevy.com/forums/...-friendly.html
thanx fire730
Old 06-28-2008, 05:18 PM   #230
fire730
fire730's Avatar
Member ID: 71873
Post #196 of this thread I have a link to another thread I made with pics of how to do what you are talking about with the fresh air vent seal.
1998 Tahoe 4D 2WD - Daily driver stock for now
2008 VUE - Wife's Daily
1993 Integra - Auto-X car
1995 F250 ECLB
Old 06-30-2008, 06:35 PM   #231
mikesec
Member ID: 91146
thax fire730 your thread helped me repair that leak , **leak fixed**
Old 06-30-2008, 11:15 PM   #232
fire730
fire730's Avatar
Member ID: 71873
Glad I could help. It completely stopped my leak and it was pretty bad before I fixed it.
1995 F250 ECLB
