11-06-2004, 03:02 PM
#21
Re: Rain leaking into cab
FINALLY, success!!! I found the main leak on my 99 nbs ext. cab. It was rushing in around the cab vent on the passengers rear corner of the cab. I bought a new one from the dealer. All of $7.52!!!! I can't believe how much water was running in around it!!! I also can't believe the vent was only $7.52 from the dealership.
Now to figure out where the wind noise is coming from in the passengers rear. I think it is the third door glass seal. Atleast it's not leaking water...lol.
12-31-2004, 04:31 PM
#22
Blown daily
Add me to the list....97' Yukon, and I hear water in the blower motor too....Grrrrr....
Jason
1997 Yukon heavily modded
2005 Lexus IS 300
1991 RS/Z28 heavily modded
1969 Camaro SS
1957 Chevy 150
1994 Chevy 2500
2004 Big Bear Choppers Venom Pro Street
http://www.fquick.com/RU-QWIK
01-03-2005, 11:21 AM
#23
Beware The Evil CrankToe
I feel so special to be in this club too. my 98 Ho does the same damn thing, It runs all the way down to hte floor, and even makes its way back to under the back seat!! The side of the carpet is stained from it!!!
It sometimes leaks around the top of the windshield by the rearview mirror also.
~Dave~
1999 GMC Sierra Ex-Cab Z71
2001 GMC Sierra Ex-Cab *Totalled by my son 9/11/09*
1986 Chevy SWB -Purchased 3/14/08 sold Oct. 08
1986 Chevy SWB **STOLEN** 6/26/05
AIM Screenname Jester84
01-12-2005, 05:38 PM
#24
Shelter dogs are custom.
Just adding one more to the list. My 2000 OBS just started doing it a few months ago. It seems to only be a problem when it is parked. Luckily, my floor mats hold a lot of water.
2000 K3500(OBS) 7.4L,4L80E,CC,DRW
01-13-2005, 01:21 PM
#25
It sounds like we ought to get a class action suit going, mine leaks also. I was going to post this question today. It must be raining in other parts of the country too.
02-08-2005, 02:29 PM
#26
Future drag racer
Add me to the list too. '96 OBS. Had the leak since i bought it (used) a few years ago, only happens when it's sitting in the rain, not moving. Haven't bothered to try and chase it down.
02-08-2005, 10:49 PM
#27
I just fixed my 95 this past weekend, the driver side cowl area had a void in the seam sealer that was hard as hell to find but leaked alot runing my carpet. As soon as i can figure how to resize my pictures i will post them on the repair!
02-09-2005, 06:42 PM
#28
Here are the pic,s. I removed the fender and found that all i needed to remove was the small part of the driver side cowl to get to the leak. A little clear RTV sealed the leak now i need to find some molded vinyl flooring like the one that came in the work trucks to replace the wet stinky carpet that i removed. The screw driver shows where the void was located and the third picture shows the RTV applied. Also the void was only visible looking from the center of the truck looking to the outside.
02-09-2005, 06:46 PM
#29
This is all that needed to be removed to fix the leak i had. It was much easier to spot the leak without the fender and there was some leaves trapped in there that i removed also.
02-09-2005, 06:54 PM
#30
Water leak found!
To anyone interested in the maintence fourm i have some pictures of my repair from water leaking into the driver side cab of my 95.
02-09-2005, 08:01 PM
#31
Eric, your void was on the driver's side, right, but where was the water coming into the truck?
Mine, like most here I believe get water on the passenger side mat. This is driving me nuts, please someone help.
02-09-2005, 11:16 PM
#32
I may have also had some luck.The water was running down the corner of floor and kick panel soaking the carpet. Eric got me into the cowel. Nothing visable but, I went ahead and sealed (W/RTV) inside the cowel (where the wiper arms are). There is a seam there too and is where water travels toward the drain hole, just like a street gutter. I ran water for hours (the whole superbowl) and dry.
02-10-2005, 05:59 AM
#33
Mine was leaking behind the kick pannel whwere the emergency brake pedal is dow to the bottom of the door soaking the pannel. Under the rocker pannel trim there was at least 1/8" of standing water.
02-11-2005, 10:57 AM
#34
VC PIMP
Re: Water leak found!
post them up
02-11-2005, 10:58 AM
#35
House on the HILL!
Originally Posted by zorro_sn
post them up
02-11-2005, 02:28 PM
#36
So far I have not seen water on the drivers side. I know part of the problem on ours is the windshield. Its leaking at the top. Just dont think that is the major problem. Gonna fix that and see if I can find anything else. Its pretty much ruined the carpet on the passenger side. It makes its way all the way back to the back carpet under the rear seats.
~Dave~
02-11-2005, 05:30 PM
#37
Originally Posted by CKTA
Post #28 and #29. Some pictures are not that clear sorry!
02-11-2005, 06:13 PM
#38
NOT A SHOWTRUCK!!
mine does it on both sides but theres a reason on the passenger side lol mine doesnt leak enough to worry about it though on the drivers side, I will get to it eventually but right now its no biggie
here is the reason the passenger side leaks
04' GMC Ext Cab 2500hd 4x4
98' Ext Cab K1500
97' Stepside S-dime Lowered w/c5 vette wheels
89' K5 Blazer sittin on 38.5 SX's
77' SCSB K-10 w/396BB & 42" TSL's
02-11-2005, 07:48 PM
#39
Well, it's been raining for 24hrs here and no more leaky!!!
I'm thinking the one screw that hold the small cowl cover may have had somthing to do with it too. I sealed it up since it leads into cab and is a little stripped. So far so good. By the way Mine would build up at the rocker panel also
02-12-2005, 10:37 AM
#40
No,not that ugly box car
After having throughly torn apart and examining the area, I had the same thought. I was going to seal that end cowl screw with some black RTV, too, since it's out in the heat and weather all the time, but the cap on my RTV had cracked after the last use and dried up my whole tube. Unfortunately, I never did get around to buying a new tube. I've been far too preoccupied with lots of important things....like cringing at the picture of 98bluebowtie's truck  and other assorted...things
2005 Dodge Ram 1500 QCSB 4x4
***Yeah, it's got a Hemi!  ***
***2001 Pontiac Grand Prix GTP***
---Nicely Modded and Hauls...Kids ;o)
*2005 Chevy Avalanche Z-71 5.3*
Gone-Lemon Tree Extraordinaire
1998 GMC Sierra ECSB Z-71 5.7
~~~~I miss you dearly!~~~~
| Thread Tools |
| Display Modes |
Linear Mode
