Old 05-22-2006, 04:51 AM   #101
CKTA
King of the Assclowns
CKTA's Avatar
Member ID: 66
Re: Rain leaking into cab
Found it!
After my last post on here Friday it POURED out. Right after it stopped I went out side (where the truck was sitting on level ground) and there was water puddled in the door sill area. I did some looking around and where I originally siliconed (see post #59) the water was leaking in right where I stopped the silicone. So the water must puddle up somewhere because it was still dripping in from BEHIND the seam sealer after the rain.
I took the truck home and blew it apart, cleaned and dried everything. I even took off the cowl and siliconed the outter edge scwers like everyone has been doing. I also applied alot of silicone over the previous area and brough it up as far as I could reach.
I hope that fixes the problem (I'll still be keeping the truck apart incase) because I CAN NOT find where it is leaking from. Short of cutting the truck/cab apart I don't think I'll ever find it. If the leak continues I think I will make a "channel" out of silicone down to the sill plate area and drill a hole so the water drains out!
Carlisle 2009 All Truck National info....
http://www.fullsizechevy.com/forums/...aug-7-9th.html
Old 05-24-2006, 06:05 PM   #102
Quink
Registered Noob
Quink's Avatar
Member ID: 46987
After washing my truck today, I noticed that the leak doesn't start right away. It also kept dripping for a while after I was done. I siliconed all the cowl screws, we'll see what happens...
I need a pic...
98 z71 ext cab, 5.7L
Old 05-25-2006, 11:03 AM   #103
remelad
Member ID: 48131
Confirmed Fix For Passenger Side Leak!
I have just read this whole thread looking for a cause of leak on a customers vehicle.
Water was running out the blower motor box as most are experiencing. I pull the cowl panels and looked around. I sealed the 2 right holes above the blocked off area of the cowl. The back screw hole is above the fresh air vent and water was just running into the fresh air vent from this hole. Sealed it with silicone and all is well!!
None of the screws enter the passenger compartment but those 1 hole DOES go through the cowl directly above the fresh air vent! This was verified with a borescope.
Chad M. Germer
Owner - D & C Auto Center
Old 05-27-2006, 08:57 PM   #104
Quink
Registered Noob
Quink's Avatar
Member ID: 46987
mmmmmm borescope.
Quick T-storm yesterday, no leak.
We'll see...
I need a pic...
Old 06-02-2006, 11:16 PM   #105
sirhcp
'00 Yukon SLT 5.3
sirhcp's Avatar
Member ID: 30986
Re: Confirmed Fix For Passenger Side Leak!
Any chance that we can get a pic or two of where we need to place the silicone?
Thanks!
'00 Yukon 5.3L Vortec
CAI, Muffler...Sooner
W4MP Tune...Later
I fornicate and play hockey cuz they are the two most fun things to do in cold weather.
Old 06-04-2006, 09:32 AM   #106
Quink
Registered Noob
Quink's Avatar
Member ID: 46987
Rained all day yesterday, no leak...
I need a pic...
Old 06-05-2006, 08:05 PM   #107
w.snider
Member ID: 46880
How much does a weather strip kit cost?
Old 06-06-2006, 07:32 AM   #108
CKTA
CKTA's Avatar
Member ID: 66
Hard to tell, but I think I still have a little leak. If that's the case...........I can't reach/get to where it is leaking. And if that's what the deal is...it's time to drill a hole in the sill area and just let it drain out. It will kill me to do that tho. I still have the carpet spaced up and the kick and sill off. Has'nt rained hard enough to tell if it does still leak.
Old 06-08-2006, 05:36 AM   #109
CKTA
CKTA's Avatar
Member ID: 66
Well it rained like a mofo all day yesterday. Came out of work to find the whole sill area filled w/ water. Still can't see where it's coming in (has to be behind the dash).
Time to drill a hole.
Old 06-08-2006, 07:48 AM   #110
DearJimmy
Premium Member #82
K1500
Member ID: 14628
For those who have their cab apart where they can see everything I have an idea. Maybe wipe a line with a wet sponge and somehow get some chalk or flower in the wet line. Then next time it rains it will show the path of water. If you don't see a path then it's a drip from above. When a path is found you can make small lines of powder higher and higher till an area is found. What do you think?
Old 06-08-2006, 11:38 AM   #111
Quink
Registered Noob
Quink's Avatar
Member ID: 46987
Rained about 4" yesterday. No leak!!!!!!!!!!!!!!!!!!!!!!!!!!
I need a pic...
Old 06-08-2006, 12:29 PM   #112
CKTA
CKTA's Avatar
Member ID: 66
What exactly did you seal up?
Old 06-10-2006, 03:14 AM   #113
matuva
Member ID: 34691
Any pics of what to plug seal , silicon or else to solve that problem?
I've been looking hard for several times but didn't succeed in finding wich way the water goes in
1996 Chevy K1500 Xcab
6.5L turbo diesel
Reflash ECM from HeathDiesel
TurboMaster from HeathDiesel
As like K & N cone filter
Stock exhaust with removed soot trap
Old 06-10-2006, 06:55 PM   #114
johnnymag3
Member ID: 49031
Thumbs up Re: Rain leaking into cab
I have the same problem,1989 Z71---short bed stepside
-=-=-=-= but I have another answer..I see that the cover over the fresh air intake goes directly to the floor in the cab.This is under the cowl trim, and is on the passenger side only. It looks like a block off plate in the top of the cowl. If you look close, it has seam sealer from the factory...IT GETS DRY, AND FORM CRACKS THAT LEAK then drip into the cab/heat ducts...You need to seal this plate, or the water will drip onto the blower area, then on the floormat, or down the firewall to make a real puddle in the door sill area........please look into this scenario, as I have sealed up mine, and it appears to be the culprit so far...
Old 06-11-2006, 05:48 PM   #115
johnnymag3
Member ID: 49031
Ok, things were fine until I watered down the area with the last screw on the cowl trim...pass. side. I took a wire, and pushed it through the screw hole, and guess where it came out....directly behind the ecm module, on top of the blower case. I took out the screw, and sealed it up, and left the screw out...not really needed anyway.no more leak...I soaked this baby, and THINGS ARE COOL NOW...I HATED THIS FOR SO LONG, BUT NO MORE WATER....Let me know if I can help further...johnny
Old 06-11-2006, 06:34 PM   #116
matuva
Member ID: 34691
any pics?
6.5L turbo diesel
Old 06-12-2006, 04:12 AM   #117
johnnymag3
Member ID: 49031
I can try to post pics, but we still have dial up here in new york where I live The cable and phone people are still asleep I will do my best to get something posted after work today...
Old 06-12-2006, 03:29 PM   #118
Quink
Registered Noob
Quink's Avatar
Member ID: 46987
I took out all the plastic cowl covers, and siliconed every screw hole (the screws to the cowl cover), let it set up for a bit, then put everything back together and siliconed again over the screws this time. I'm not sure which screw was the culprit, so I did them all.
I need a pic...
Old 06-12-2006, 07:44 PM   #119
matuva
Member ID: 34691
by cowl covers, do you mean the plastic grills just bottom of the windscreen? or is it something inside...I'm french, and even the dictionary wasn't a great help for me .
That's also why I'm asking some pics
6.5L turbo diesel
Old 06-12-2006, 10:03 PM   #120
Quink
Registered Noob
Quink's Avatar
Member ID: 46987
Yes the plastic grills. I'll try to get some pics tomorrow.
I need a pic...
