#1 |
Member ID: 87709
Toe in was @0.17 deg.
I have a completely stock 02 k1500 w/ z71 pk. I went to 3 places to get an est. on fixing my front end which shook over every lil bump. The 1st estimate was for a pitman arm (i replaced this 18 mo ago), the 2nd was for a pitman and idler assembly, and the third was realigned with the only problem being that the TOE was at 0.17 degs (spec is between -0.05 to 0.15 degs). The truck is handling the lil bumps much better now but the steering still seems not as tight before i noticed these probs. My question to you guys is-
Can the toe off by .02 degs cause so much of a difference on a stock set up? Thanks for all the help in advance (both past and present!)
2002 Silverado 1500 4.8L
#2 |
Redneck By Heritage
Member ID: 71235
Re: Toe in was @0.17 deg.
toe affects tire wear only unless you have some excessive ammount. if it was me id lok over the underside yourself you can tell if it bad or not.
1985 GMC K1500 - show/play truck
83 chevy c10 - lowered finally and sitting on bags (just need air) 92 toyota truck - gas getter / mud toy 91 chevy C1500 - new daily driver |
#3 |
Member ID: 87709
OK... is 0.02 degrees an excessive amount? on the right wheel? I did look at it... nothing is shaking/popping ball joints are good and recent (both uppers replaced 4 months ago). The first two estimates that i got said that they could not even align my truck until i replaced the parts specified in my first post... then the 3rd place just aligned it with out sying anything.
The total TOE was changed from .28 degs to .18 overall... can this make a big difference besides the tire wear issue?
#4 | |
Status:
Online
Member ID: 87774
A lot of shops are just "toe and go" without looking at other specs or issues. That's not saying they're right or wrong. If your toe is out, it can definitely cause some f-ed up tire wear.
1999 Tahoe LS 2-Door 4x4 w/ 3.73 G80. Custom tune from Justin @ Blackbear and a Vette 1 - 2 servo.
Brakestands make for great aroma therapy. |
#5 |
Member ID: 87709
#6 |
Redneck By Heritage
Member ID: 71235
no...that ammount was not excessive.
#7 |
15 years of alignments. Spec on those trucks is .10 + or - .10. If you push the button on the machine that says reduce tolerances it will drop the tolerances to .05+or-. Then the display shows red and the tech sells the unknowing customer and alignment because its "out of spec". Ive had to work with several guys over the uears that did that and its sad. .10 off of spec will not make ANY difference. .20 may show up on long term tire wear. .30 will show up fairly early. .02 is a crook trying to take your money. Raise it up and set it back down and it will probably change .02. Ass holes like that make it hard for the honest techs to make a living.
Nick |
| Advertisements |
| Thread Tools | |
| Display Modes | |
