Old 10-16-2006, 06:35 PM   #41
lorado
bigjohn
lorado's Avatar
Member ID: 39594
Re: Chevy Lean **updated 9/19/06**
noted....
.....SOLD
Old 10-21-2006, 07:12 PM   #42
FIREGOD42
Member ID: 56769
I agree with the fuel idea. The Toyota I had before the Silverado leaned bad when full of fuel. Leveled out when low. Think about it this way; 20 gallons of fuel at roughly 10 lb per gallon all on the left side. Take measurement at both fuel levels and see what happens. Just a thought.
Old 11-11-2006, 12:21 PM   #43
jdpolzin
Member ID: 51275
I took my truck in to have them install these spacers but the dealership has to try to find a set. GM must not make many of them?? I have been waiting for months now. I just want to get them on so I can lower my truck!! -------Jeremy
Old 11-15-2006, 06:24 PM   #44
ZRACE1
Member ID: 57551
Re: Chevy Lean
Originally Posted by 69SS
My whole left side leans. I checked the clearance from wheel well to the tire on all 4 corners. I figured it had something to do with the gas tank being mounted on the left side.
It probably leans because the battery and fuel cell plus driver are all on the left side. My 2001 Silverado does this also. I swapped springs from one side to the other and it remained the same. I think I need a 1" spacer that goes under the spring to fix the problem.
Old 11-18-2006, 02:34 AM   #45
78C-10SWB
Member ID: 2835
GM Parts Direct carries them. The spacer is $6.60 and the u-bolt is $8.88 plus shipping.
Does the spacer just lifts the left side (driver's side up to balance the right side being lower?
Old 11-19-2006, 12:16 PM   #46
lorado
bigjohn
lorado's Avatar
Member ID: 39594
the spacer brought my 02 back to with-in spec. i think its about an eighth of an " difference now.
.....SOLD
Old 11-22-2006, 07:33 PM   #47
BewstAdd1ct
Member ID: 21435
gasoline is about 6.25 lb/gal, and the spring rate should accomodate a mere 125lbs without much of a change in ride height.
Old 11-26-2006, 01:41 PM   #48
Blazer79
Member ID: 28748
I own a 2001 1/2 ton 2WD, i went to the extent of changing the whole coil spring on the LF and it didn't make much of a difference. I also thought of another cause too, if you have a weak LR leaf spring, it would do the same thing. It would lift the RF higher than the LF. I corrected that by putting a set of air shocks on the rear, and pumping the LR more than the RR.
Old 11-27-2006, 04:38 PM   #49
poboychevy
poboychevy's Avatar
Status: Online
Member ID: 38615
the problem is in the left rear of the truck, next time you see a transport truck look at the way the chevy,s are tie down. i work for a chevy dealership as an auto body tech and a few years ago we got paid by gm to correct the tweak on the frame. the problem is these truck are tied down on the front, and only on the left rear, and they actually twist the frame down a bit from the backside of the cab.
Old 12-05-2006, 05:47 PM   #50
lorado
bigjohn
lorado's Avatar
Member ID: 39594
so......what method did you use to correct the frame tweek
.....SOLD
Old 12-10-2006, 12:12 PM   #51
jdpolzin
Member ID: 51275
This spacer for the drivers rear only lifts the truck 1/2" right? I am about 1 1/8" off with the front level. Can I use two spacers and the same u-bolts? Will these spacers cause anyproblems with a drop kit?
Old 12-11-2006, 09:47 PM   #52
lorado
bigjohn
lorado's Avatar
Member ID: 39594
before you do that just buy a 1" block from your auto parts store. And before that, try swaping leafspring, and your coils(left to right). and even before that check and mesure on a very flat surface, with the wheels straight and no load, with even tire pressure(this assumes your shocks are good also)that it still sits unlevel. its just that there are a lot of variables when it comes to the "chevy lean"
.....SOLD
Old 12-12-2006, 02:46 PM   #53
jdpolzin
Member ID: 51275
Yeah I have been through the whole truck trying to fix this ever since I bought it. The leafs have been changed out with new ones an the whole nine yards. The truck needs to be lifted on the drivers rear 1 1/8" to be level. I would like to accomplish the difference without using lifting blocks and using shackles instead. I just dont like the idea of have blocks to raise it and then shackles to lower it. If I can ise the different hoes in the 2" lowering shackles, that the way I'd like to go. Will this work? Is that the reason for the two holes in the belltech shackles?
Old 12-23-2006, 11:23 AM   #54
Blazer79
Member ID: 28748
I just ordered the shackles and spacer, from my local dealer. so i hope that it fixes the problem. Now that you mention it that seems like the easiest fix
Old 12-23-2006, 12:45 PM   #55
jdpolzin
Member ID: 51275
I ended up getting McGauphy's lowering shackles. They are adjustable between 1" and 2" so this will work since I am lowering the truck anyways. Now I just have to put the whole kit on!!! -----Jeremy
Old 03-10-2007, 09:43 PM   #56
redrocker
redrocker's Avatar
Member ID: 64563
Thanks for the info on the lean I bought the parts today and fixed it in about 20 minutes sit level now. Thanks again.
Old 03-14-2007, 05:50 PM   #57
jdreddish
Member ID: 64576
Indeed, thanks for the info !!
I have been searching high & low to fix the lean.
I have a 2006 Silverado Z-71 Crew Cab. I was measuring fender height before I installed new ford torsion keys. I noticed my driver's side rear was about 1/2" lower.
The only problem is my truck already has 2" blocks on it, this would mean I have to stack them which I have heard is a NO NO.
Any other advice ?
Old 07-02-2007, 01:39 AM   #58
LAGA
Member ID: 67881
I have a 07 1500 2WD NBS that is 3/4 inch lower on the driver side. Will this be fixed under warranty if I bring it back to the dealer?
Old 07-28-2007, 02:20 AM   #59
lorado
bigjohn
lorado's Avatar
Member ID: 39594
probably not. for some reason the dealership is only happy to see you when you are spending money
.....SOLD
Old 07-30-2007, 03:16 PM   #60
Nick
Member ID: 936
The TSB says they will fix anything over .59", so I guess you'd qualify.
